Question about Dell E193FP 19" LCD Monitor
Opening the back plate of a dell e193fp
How do i open the back plate of a dell e193fp lcd screen
    Novelist:
  • 138 Answers
Go check this website. Hope it help!!
http://www.ccfldirect.com/lcdtutorial.html
Posted on Feb 03, 2008
  • Somsak Tantong
    Somsak Tantong Feb 07, 2008
    Ok first, power off, take the monitor off from its stand and face it
    up. You first, have to take the front frame out by using very thin flat
    screw driver. Be careful! you might break the screen if you push too
    much force. Start from the bottom edge of the screen where you can see
    little rectangular cavities. A thin flat screw driver will fit it and
    try to pry it to separate the font frame from the back. Try to do this
    for all of the cavities gradually together. After that, loose 4 screws
    from the back and it will be easily to pull off.
Hey thanks for the help it worked great
Posted on Feb 07, 2008
I have a Dell E193FP Monitor. The power light is green, but the screen is blank.
There are two cables connected at the back of the monitor. one for the power and one for the video . Make sure the one for the video is securely fitted.
Hope that helps.
Thank you.
Dennis
Sep 08, 2014 | Dell E193FP 19" LCD Monitor
The monitor goes blank. the power light is still on but after about a second it goes out. id i turn the power switch off and then back on it will cme out and go out again within a second. Dell E193FP
It can be blown transistors, bad fuse, bad caps.
See the inside of the monitor here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E193FP/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Nov 06, 2010 | Dell E193FP 19" Flat Panel LCD Monitor
Monitor will not come on screen is black
Please look at these pictures here so you know what to look for: http://s807.photobucket.com/albums/yy352/budm/Dell%20E193FP/
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Post back so we can guide you further.
Apr 08, 2010 | Dell E193FP 19" LCD Monitor
Dell E193FP 19" LCD Monitor to work with vista
Go to Start, Control Panel, Personalize, Display Settings, Adapter, List All Modes, then select the mode you want.
Good luck
Feb 15, 2010 | Dell E193FP 19" LCD Monitor
My Dell E193FP boots up with the computer and then
Seems to be a very common problem with this screen. Im taking one apart as we speak to try to discover the problem. In the mean time - check that the Power Input isnt loose, and you can wiggle it around. Usually means the power is arcing onto the board
Sep 01, 2009 | Dell E193FP 19" LCD Monitor
Will the E193FP work with my computer?
I would suggest , check the monitor connections again. Dell flat panels are plug and play and donnot require additional drivers.
Make sure , you have not connected , both the analog (vga cable with a blue connector) and the digital (dvi cable with a white connector) to the back of your computer.
Refer to the the link below , to troubleshoot the monitor
http://support.dell.com/support/edocs/monitors/E193FP/En/trouble.htm
Thanks
Proton
Nov 10, 2008 | Dell E193FP 19" Flat Panel LCD Monitor
White screen
one of three items..
video card or driver is kaput...try driver first from dell support site
then, could be monitor..open menu..do the degauss
if not those..then mother board is eternally unhappy
Oct 09, 2008 | Dell E193FP 19" Flat Panel LCD Monitor
most all the dells open by gently prying off the front bezel
it snaps in place around the edges.
be gentle and don't put any pressure on the lcd or you will leave marks forever.
Feb 02, 2008 | Dell E193FP 19" LCD Monitor
Dell E193FP 19" LCD Monitor Logo
443 people viewed this question
Alun Cox
