Question about Maxon Radio SL55, SP130, SP140, SP150 Compatible Battery
SL55 Not Transmitting/Recieving
Ok, Ive got two maxon SL55's both fully charged but i cant get them to talk to each other, when one of them is transmitting (on the same channel or other) the other turns yellow on the TX but no sound.
I have also got a Zycomm 5016 which dosent pick up anything.
Thanks J
The two radios are on different CTCSS Tones
Posted on Nov 22, 2008
Reprograming these radios is required as thay are on repeater freqs ie tx hi freq, rx lo freq
Posted on Apr 07, 2008
Realistic trc 443 cb quits transmitting and recieving
Sounds like the weather alert system is getting activated.
Jul 26, 2010 | Uniden PC78ELITE 40-Channels Base CB Radio
My battery wont keep its charge or charge properly ive tested the
Go to an auto parts store and buy a load tester for the battery. It doesn't cost much and sometimes if you bring the battery there they will test it for you with a load tester. It may have a dead cell which won't allow it to hold a charge or put out enough power. If you need a battery, some shops will install them for free. Good luck.
Apr 20, 2010 | Renault Sport Cars & Trucks
I have a maxon sl55-u2 frequency radio only channels 1 to 4 work. why is this?
Only 4 channels have been programmed, you will need a programming cable to plug it into a computer and use the maxon software to programme the other channels to whatever frequency you need.
Nov 15, 2009 | Maxon Radio SL55, SP130, SP140, SP150...
Not able to transmit or recieve on cb radio in car
It could be your ant. a broken coax wire or a bad ground could cause this a could a broken or shorted wire on your mic.
Jun 02, 2009 | Maxon Radio Communications
Rushing sound (noise) galaxy 88 HL
RUSHING SOUND ?
1. Get the noise then disconnect the coax and see if noise goes away on receive, if noise goes away then address the ground on your antenna,
if noise still there then address the ground wire from power source
Mar 30, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Maxon mcb30 which way to turn the mod
RV 2 is the modulation pod that needs to be turned
Mar 18, 2009 | Maxon MCB-30 40-Channels Base CB Radio
I have a Maxon handheld cb - it squeals when keyed can not talk.
sounds like you are getting a feedback squeal.. try taking a wire and attaching to you handheld and grounding it to something.. that might work.. i know i have to have my mic on my cb grounded to my radio or i get a feedback squeal...
Jan 02, 2009 | Maxon HCB-10C CB Radio
Maxon MCB 10 A
I'm not sure about your particular model but many CB radios use the microphone push-to-talk switch to kill the speaker while the radio is transmitting. If you don't have the correct microphone or if the cord has a broken wire it can cause the radio to have no sound. Another possibility is that the speaker is bad. There is probably an external speaker jack on the back of the radio. You could try plugging a different speaker or even an earphone in the jack to see if you get sound there.
Mar 07, 2007 | Maxon SP-100G (4 Channels) 2-Way Radio
Maxon Radio SL55, SP130, SP140, SP150 Compatible Battery Logo
300 people viewed this question
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
