Question about Sanyo DS31520 31" TV
Picture larger than screen...
The picture appears to be zoomed, noticeably cutting the lower and upper portion of the picture(no ticker on ESPN.)  The owner's manual mentions several options for screen size, but all I get on mine is 16:9 and 4:3.  Any ideas how to "re-size" the picture?
changed pix settings
    Scholar:
  • 133 Answers
If you go to 4:3 mode and the picture is still cutoff then i would assume the tv has a problem with the horizontal or the pinchusion correction circuit . This would be the only two areas that would cause this problem . Check the format section of your menu to make sure it is not in zoom mode or otherwise if it is not then you have a problem with one of two above mentioned circuit problems . Good luck
Posted on Mar 03, 2008
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
Jan 15, 2011 | Mitsubishi WS-73909 73" Rear Projection...
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
Screen adjustments??
On the remote, if you use the right and left keys on the pad with the OK sign in the middle, it will adjust the screen to several sizes including Cinema, 16:9, 4:3, Zoom, etc. I, personally, use 16:9 because I, like you, need to see the ticker symbols at the bottom. I hope this helps.
Sep 17, 2008 | RCA HD56W58 56" TV
Digital LIfestyles 32
On your remote control you should see a zoom or picture size button. Try changing this back to 16:9. I expect that your screen got zoomed either on purpose or by accident by someone. Some people zoom in the picture to eliminate the aspect ratio areas at the top and bottom and/or sides.
This should be your problem, just un-zoom the picture
Sep 09, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Sony 46" Rear Projection HDTV Bad Picture
Hello, I also have the kp53xbr45 and I am looking for a red bulb, where can I find one at a good price? Thanks
Feb 09, 2008 | Sony KP-53XBR45 53" Rear Projection...
Over projection on apex hd 51"
try to go to menu using ur remote and adjust the v-size/vertical size....
Jan 29, 2008 | Apex Digital GB51HD09 51" Rear Projection...
Wierd problem
HD projection televisions have seperate convergence alignment for 480i-1080i thus your problem when you use your XBOX360. The "No sensor data" that shows up is due to the fact that the sensors need to be initilized after doing the convergence in 1080i mode. You will probably need a technician to do the alignment because if it is out that much then a template needs to be used to get it corrected. For now you can put your XBOX in a lower display mode until repairs are done.
Jan 30, 2007 | Samsung HCN4226W 42" Rear Projection...
Sanyo DS31520 31" TV Logo
459 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
