Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ed5fhgxkq02 whirlpool water dispenser wont work
The water dispenser dosent work on my ed5fhgxkq02 whirlpool fridge. I was wondering if anyone could tell me how to get front cover off dispenser and any ideas on what is wrong. thanks
  • chris aube May 11, 2010
    when pushing in paddle can you hear any hum from rear of refrig on the freezer side?
    Problem Solver:
  • 6 Answers
Under the cover is two slots take a flat head screwdriver and lightly pry out.the cover wthen will come off
Posted on Mar 04, 2008
Whirlpool refrigerator WSF26C2EXF01 water dispenser not working
This sounds like the water inlet valve has gone bad.. First before u replace it check to see that you have water coming to back of fridge as it could be restricted causing no water to reach the fridge.
Apr 04, 2014 | Whirlpool Refrigerators
Hot point refrigarator changed leaky water valve. now wont get water out of dispenser. turned water on double checked all connections. bad valve?
It seems problem in this fridge could be related to many issues as each must be explored and could be water filter problem or problem might related to water line problem such as creased line or clogged line or damaged water inlet valve or water dispenser control switch on front of fridge
Dec 06, 2013 | Whirlpool GD2SHGX Refrigerator
Hi, I have a side by side S20D RBB32-A/G Fridge Freezer with ice and water dispenser. The frezeer and fridge stopped working. I called a local repairer who took away a part for repair. However, the fridge...
Try checking the mesh screen which is in the water line where the water supply connects to the water inlet valve on the back. It can get stopped up with sediment.
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Low water flow from "ice magic plus"
Have you tried replacing the inline filter? and if you have remove the filter and place a large bowel next to the water line and open it up and see if water flows from the line, if it flows fast then it's a problem with the fridge if it folws slow you have a problem with the water connection. Check that can get back to me if you need more help.
Avid101
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Has anyone successfully fixed his or her water dispenser?
I have had a few where the water switch housing that holds the switch breaks and does not allow the arm to hit the switch to turn water on. that is one thing it could be ethier way not to big of an expence to get fixed
Feb 23, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Just Purchased a Whirlpool Fridge Side-by-side?
it will start making ice within 24 hrs you should be able to get water out the door but it wont be cold but it takes 24 hr for the box to get cold and stabilized
Dec 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side-by-side refrigerator - 2 problems
I would suggest that you get a certified person to come out and look at it you very well could have bent the doors in the move.
but... if you want to do it yourself.
click here for a walkthrough
for your drip:
Flush air from the water system the first time it is used and after replacing the filter. Air trapped in the water line or filter may slowly travel through the coiled water reservoir to the dispenser, pushing any water ahead of it. This can cause the dispenser to drip. Water needs to completely fill the lines for all air to be cleared.
  • Use a sturdy container to press and hold the water dispenser bar for 5 seconds, then release it for 5 seconds. Repeat until the water begins to flow. Once the water begins to flow, continue pressing and releasing the dispenser bar (5 seconds on, 5 seconds off) for an additional 2 minutes. Repeat if dripping starts again because air can re-enter from the water supply.
  • As air is cleared from the system, water may spurt from the water dispenser.
  • Make sure the refrigerator is connected to a cold water supply.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Jan 26, 2008 | Refrigerators
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
371 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
