Canon BJC-1000 printer
My printer was working fine until the ink ran out. refilled the ink and now it won't print. It says error to LPT1 problem sending doc to the printer. In the screen where it says capture printer port then type in network path , the box for network path is empty. What is the network path and is this the problem?
  • ahewitt57 Feb 04, 2008
    The ink was refilled at Office Max. I need to know what to type in for the network path. can some please help?
  • ahewitt57 Feb 12, 2008
  • 106 Answers
Maybe you dont reffil you cartridges properly,try to install new cartridges
Posted on Feb 01, 2008
BJC 85 not printing after head replacement
I have similar problem. Print head won't print, then I clean with alcohol, and get rid of old ink inside. But then head seems to just shut down. I have several print heads and printers that have plenty of ink, but head won't work. I refuse to think the print head will break so easily. I used my BJC 85 for YEARS with no problem whatsoever, and suddenly, since last winter, I have 4 printers that have stopped printing.
I usually end up just buying another used printer on ebay until that one stops printing.
Terry tlworkroom@lycos.com
Feb 28, 2010 | Canon BJC 85 InkJet Printer
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
No yellow printing from my color cartridges
The nozzles that the yellow ink flows thru are clogged. Try the print head cleaning utility. Right click on the printer, select PROPERTIES, select the MAINTENANCE TAB and press the PRINTHEAD CLEANING button. If that doesnt work, turn off printer, open front cover and move the ink carriage toward the center. You should see a small rectangular cotton sponge pad thats covered with old inks. Put several drops of Windex on it so that its nicely soaked and return ink carriage. Turn on printer and run the print head cleaning utility again. Then let it sit overnight. The next day, try printing a test page.
Jun 17, 2009 | Canon BJC 1000 InkJet Printer
Printer won't print
It always helps to replace with the correct brand as cheaper versions do fail, also if you had replaced it with a BC-20 from Canon, the supplier may replace it for you. It would be a good idea to trust the printer at this stage, try a Canon BC-20
Sep 07, 2008 | Canon BJC 4300 InkJet Printer
Canon MP180
There is no way to reset the ink levels on the new canon cartridges. you need to turn off the ink status monitor :(
You'll know it's time to refill again when your printing starts to fade, streak, or discolor.
Aug 24, 2008 | Canon MP610 Photo All-In-One Printer
Isn't printing at all...
try replacing the cartridge with the new one
Mar 14, 2008 | Canon BJC 80 InkJet Printer
Canon bjc-85 printer doesn't print anymore
Have you tried changing the green carrier? That solved my problems with no ink.
Dec 04, 2007 | Canon BJC 85 InkJet Printer
Canon Copier
TRY UNINSTALLING THE DRIVES COMPLETELY  THEN REINSTALLING THEM.........mAKE SURE YOU HAVE THE SAME EXACT CARTRIDGE
Oct 09, 2007 | Canon BJC 8200 InkJet Printer
Canon bjc-80 - no print appears but cartridge & paper move normally
I had this problem too. It turned out there was old dry ink in there clogging up the printerhead and it was fixed after I ran the cleaning programme several times. However I can't for the lifeof me remember how to do that now. I know I found it online but it has since vanished. Maybe check your manual?
Nov 12, 2006 | Canon BJC 80 InkJet Printer
103 people viewed this question
jasbo
jasbo
