Question about Samsung SCH-a870 Cellular Phone
Samsung sch-s870 not pairing with uconnect on my cell
I can get my phone to find uconnect in my new car but it will not pair with my phone. please help
  • 3 more comments
  • dmf8 Feb 03, 2008
    can someone help me
  • Anonymous Feb 25, 2008
    same phone same problem
  • fishy1234 Feb 25, 2008
    same phone same problem not pairing up with uconnect. Called Uconnect rep told me my phone is not the problem
  • Anonymous Mar 15, 2014
    uconnect having a hard time pairing current phone
  • John Harrison
    John Harrison Aug 07, 2014
    I'm having trouble with uconnect & S3 phone uconnect won't do update
Same phone same problem, possibly software update might help
Posted on Feb 25, 2008
I can’t download my iPhone 8 phone book into my 2012 Grand Cherokee Uconnect.
Turn iPhone Bluetooth On:First you want to make sure that Bluetooth is functioning on your iPhone. Click on the Settings icon from the iPhone desktop. From the settings screen click General to show the iPhone General Settings as displayed in the below image. Notice you can see if Bluetooth is on or off from this screen. General Settings screen you can click on Bluetooth to configure the Bluetooth settings. On the Bluetooth screen shown below click to the left of Off to turn Bluetooth On.
  1. Begin Uconnect Setup:Now that Bluetooth is operational on the iPhone you can start the Uconnect process. Click the Uconnect button on the rear view mirror to begin. The voice from the Uconnect system will ask you to verbally select one of the options from the menu. Once Uconnect asks for your input say "Setup" to begin the process of syncing the iPhone.
  2. Start Phone Pairing:Once you say setup in the above step the Uconnect system will list numerous options available from the setup menu. One of these options is "Phone Pairing" so when the Uconnect system asks for the choices from the setup menu say "Phone Pairing".
  3. Pair a Phone:In the Phone Pairing menu you can modify current entries or begin pairing a new phone. After Uconnect lists all of the choices you should say "Pair a Phone" to begin the process of pairing the iPhone.
  4. Uconnect Pin Code:The first step in pairing a phone is setting the Bluetooth Pin Code that authorizes that phone to pair with the Uconnect system. When asked for the Pin Code say any four digit combination such as "1 - 2 - 3 - 4". Uconnect will repeat back the Pin Code so you can verify it has recorded properly.
  5. Connect iPhone To Uconnect:After you have set the Pin Code for the Uconnect system you need to view the iPhone's Bluetooth Settings screen which you can get to following the steps in Step 1 above. Before the Uconnect system shows up in Bluetooth the Bluetooth Settings screen will look similar to the below where you may have other Bluetooth devices showing or not.After a couple seconds the Uconnect system will display as "Hands Free" as shown in the below image. Notice it states that it is not yet paired,,,,,
  6. Click on the Hands Free device showing in the Bluetooth devices list above. This will open a new screen as shown in the below image that prompts you for the Pin Code you specified in Step 5.
    Enter the Pin Code and then click the Connect button in the top right corner of the above window. This will pair the iPhone with Uconnect and take you back to the Bluetooth devices screen where the Uconnect Hands Free device will now show Connected as shown in the below image.
    After the device is connected you will be prompted by the Uconnect voice again so proceed to the below steps.
  7. Phone Name & Priority: After connecting the iPhone you will then name the phone and set a priority between one and seven. Name the phone anything you would like and if this is your primary phone set the priority to one so this phone always connects at a higher priority than any other phone.
  8. Verify & Test:Now have a friend dial your cell phone while you are in your car to see if the music volume lowers and the Uconnect voice tells you there is an incoming call from a certain number. To make calls you can press the Uconnect button and follow the voice prompts.
  9. The Uconnect system is a great way to safely use your cell phone in the car.
Jan 13, 2018 | Cars & Trucks
Why won't uconnect work in 2013 chrysler200
There are a few things to note. The pairing has to occur between the Uconnect device in the Chrysler 200 and the Samsung S3 using bluetooth. I noticed there are 4 possible Uconnect systems available. Depending on which one you have you can check the recommended cell phone to go with it. Samsung S4 is defnitely compatible to all of the of them and SIII also with some. But that does not mean SIII will not work with others. It just means it may not have been tested.
Go to this link and select the vehicle model and year and then follow the instructions to get to the correct pairing instruction. If SIII is not listed I would still check S4. Should not be much different.
Chrysler Uconnect
Aug 07, 2014 | Chrysler Cars & Trucks
I have a Samsung SGH-c417 cellphone and a 2011 Jeep Grand Cherokee Laredo with Uconnect. What is the pin number to pair the bluetooth with the UConnect?
If your UConnect system is Mopar's, the passkey is hardcoded to '0000' (four zeros). Nevertheless, if it is factory mounted (i.e. the one which comes mounted in the internal mirror), you will be prompted to choose any four-digit number you can think of (e.g. the same '0000'), provided that you enter that same number on your phone when pairing them with each other.
For further instructions, please, take a look at this page, select your car's year and model, click on the 'OWNER SUPPORT' tab and select the UConnect system present in your car.
Hope you are able to sort your problems out soon.
Regards, Carlos
Nov 07, 2010 | Samsung Cell Phones
How do i work bluetooth on a samsung n150
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 25, 2010 | Samsung SCH-n150
How do i get the passkey code number for a samsung sch-u450
Hello and Welcome to FixYa!
You need to enter the same passkey on both ends, when pairing some bluetooth devices. There is no default passkey. You can enter any digit(s), for say you can enter 1234 on both sides to pair or to recieve data from other bluetooth devices.
Best of Luck,
Do RATE the solution, If found helpful,
Concerned.
Jun 14, 2010 | Samsung SCH-U450 Cell Phone
Need set-up Information for Blue Tooth phone in Chrysler Pacifia 2005
I found the link below containing a download of the .pdf file and also pasted the phone pairing portion below it. These instructions are exactly the same as when pairing to my system in my '08 Caliber,so they're probably universal. Keep in mind, though, that the system just may not be fully compatible with your phone. EVERYTHING that Chrysler makes is EXTREMELY finicky-and you may be doing everything right! Before you begin, set your phone into its pairing or "find me" mode, then press the UConnect button. I hope this helps! Good luck.
http://dcxtraining1.com/dcxtraining1/docs/ExperienceFreedom_UConnect.pdf
Linking to UConnect – Required for First-time Use of Each Mobile Phone
To complete the pairing process, the mobile-phone owner’s manual will need to be referenced. One of the following vehicle-specific Web sites will also provide detailed instructions for pairing with the phone: www.chrysler.com/uconnect, www.dodge.com/uconnect and www.jeep.com/uconnect.
• Press the Phone icon button to begin
• After the Ready prompt and subsequent beep, say Set Up Phone Pairing
• When prompted, after the voice or beep, say Pair a Phone
• You will be asked to say a four-digit PIN that will be needed later to enter into your mobile phone. You can use any four-digit PIN. You will not need to remember the PIN after the initial pairing process
• For identification purposes, you will be prompted to give the UConnect system a name for your mobile phone. Each mobile phone that is being paired should be given a unique phone name
• You then will be asked to give your mobile phone a priority level between one and seven, one being highest priority. The priority allows the UConnect system to know which mobile phone to use if multiple mobile phones are in the vehicle at the same time
Making a Phone Call
• After the Ready prompt, say Dial
• The system will prompt you to say the number you wish to dial
Making a Phone Call Using Your UConnect Phonebook
• After the Ready prompt, say Call followed by the name and designation of a phonebook entry you wish to dial – for example Call, then John Doe, then Work
Terminating a Phone Call
To end a call in progress, press the Phone icon button. All calls in progress will
be terminated.
Phone Redial
• After the Ready prompt, say Redial
• The UConnect system will call the last number that was dialed on your mobile phone. This may not be the last number dialed by the UConnect system
Answering or Rejecting an Incoming Call - No Call Currently in Progress
When you receive a call on your mobile phone, the UConnect system will interrupt the stereo audio to ask if you would like to answer the call. Press the Phone icon button to answer the call. To reject the call, press the Phone icon button until you hear a single beep indicating that the incoming call was rejected.
UCONNECT
CHRYSLER GROUP TECHNOLOGY 17
Dec 29, 2009 | 2005 Chrysler Pacifica
My 2006 Jeep Grand Cherokee uconnect will provide prompts-voice or otherwise so I cannot connect my compatible Samsung Phone. My phone shows Uconnect on screen but when I do search on my phone it fails to...
check jeep.com/uconnect just to make sure the model is ok. Sometime your cell phone provider can update the software to make it work better with the device.
Oct 28, 2009 | 2006 Jeep Grand Cherokee
Uconnect auto pairing
Check with jeep.com/uconnect to make sure it is compatible. The phone is the problem 9 time out of 10. The cell phone provider can upgrade the software to make it compatible with the uconnect.
Oct 24, 2009 | 2006 Jeep Commander
Pairing a moto bt h505 to a metropcs samsung sch-r410 cell phone
Try typing in 0000 four zeros that should be the default passcode unless someone has changed it
Dec 13, 2008 | Cell Phones
Samsung SCH-a870 Cellular Phone Logo
610 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
