Question about Garmin nuvi 350 GPS Receiver
Nuvi 260 I have a nuvi 260 that has, up until now, worked just fine. When I went to use it today, all it does is repeatedly show a pop up stating "Updating GPS Firmware 1%" This is followed by another pop up stating "GPS Firmware Update Complete". It can't "acquire satellites" either. Please help me!!
  • 2 more comments
  • stevie wynn Mar 21, 2008
    i have the same problem with the message updating gps firmware 1% and gps firmware update complete, ive updated all the downloads and the message still comes up. its annoying
  • Russ Fleming Mar 28, 2008
    Basically the same as caroship's problem 'cept mine is a nuvi 200. It is a cycle consisting of "updating GPS Firmware 1%", "GPS Firmware Update complete", "Acquiring Satellites", which it is unable to do. Then it starts all over. It was working/operating just fine, then it quit and started the update firmware cycle
    sherlauque@yahoo.com
  • tehcg Apr 18, 2008
    I have the same problem as Stevie, but on my Nuvi 200W. Downloaded the firmware (version 3.1) several times, but the problem is still there. Very annoying
  • tehcg May 11, 2010
    I have same problem as Stevie on my Nuvi 200W. Tried reinstalling firmware update (version 3.1) several time using webupdater, but problem still there. Have reported problem to techsupp@garmin.com, no response todate.
    Any other suggestion?
Call Garmin tech support and they will walk you through the sequence for reloading the chipset firmware. This involves deleting files from the Nuvi before reloading the firmware. It stopped my unit from repeating the "Downloading Firmware.." message, but I was still not able to acquire the satellites afterwards and had to send my unit in.
Posted on Jul 10, 2008
Sounds like you did an incomplete firmware update. Go here:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp and do it again. It should fix it.
Posted on Feb 01, 2008
I dropped my Garming Nuvi 260 this past weekend and when I turn it on it goes to a screen saying Updating GPS Firmware 1% then jumps to Updating GPS Firmware Complete. It keeps popping up with these...
Inspect the bottom of your Nuvi 260. According to the owner's manual, some models have a small "Reset" button on the bottom. If yours does, you'll use this to reset the Nuvi 260.Press and hold the "Reset" button for several seconds, until the Nuvi powers off and powers back on. Next try
to slide the power switch on top all the way to the left to reset your Nuvi if it does not have a "Reset" button. Performing this action resets the system.
Next try a hard reset.
Slide the power switch to "Off."
Press your finger against the screen in the lower-right corner. Hold your finger in this position.
Slide the power switch to "On" to turn the Nuvi on. Continue holding your finger on the screen until the pop-up window appears. When it does, press "Yes" to reset your Nuvi to its factory settings.
Hope this works but dropping may have caused internal damage. If this does not work you may have to send it back to Garmin for service. I will attach a link for Garmin. Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/
May 30, 2011 | Garmin nuvi 260W GPS Receiver
Tip
Nuvi 255W Delete Phone Numbers
Garmin Nuvi 255W Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 255W, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 255W.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 255W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 255W WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 265WT Delete Phone Numbers
Garmin Nuvi 265WT Delete Phone Numbers
Would you like to erase the phonebook entries on your Garmin Nuvi 265WT, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 265WT.
Follow these three steps to take to get your Nuvi 265WT running like new:
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Change Nuvi 265WT Home Phone Number here.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 23, 2010 | Garmin n?vi 265WT Car GPS Receiver
My Garmin nuvi 1390 quit working while driving in Denver Colorado today. How do you get it to come back on again. Does it require batteries?
Your Garmin went into hibernation mode. This is due to the fact that it went below 38 degrees. This triggers this so called "sleep mode". To undo this state, simply hold the power button down for 15-30 seconds until it comes on again.
Aug 20, 2010 | Garmin nuvi 1390T Car GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
Try performing a reset of the unit. Hold down the bottom right of the touchscreen and turn the unit on. It will ask you whether you want to reset allk data. Choose yes and try again. This should solve your problem. Hope this helps.
Feb 20, 2009 | Garmin Nuvi 660 GPS Receiver
So what happens when you connect it to the PC?
Make sure no sd cards are installed while you do this.
download and install web updater, run it it gets to a screen where it looks for the gps, plug the usb cable into the GPS (no USB hubs please!!!) Make sure it detects the GPS before you continue. Select the updates you need (don't install all the languages !!) after this is done the program will report the downloads are on the garmin, unplug the unit and it will reboot and whilst rebooting it will install the updates....so don't touch it until it reboots again and displays the regular screen....and make sure the batery is fully charged before you do this...!
Jul 23, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 260
Check to make sure that the unit is not in demo mode. Go through the menus to find where the demo mode is located. Cycle it on and off.
If this does not work, I suggest calling Garmin tech support to find out if they have a simple solution.
In the worse case you will have to send the GPS in for service.
Jerry G.
Jul 01, 2008 | Garmin n?vi 260W GPS
Same here - garmin nuvi 310 - bought it last year around March, said dowloading gps and then can't get a signal/satellite?? Will phone garmin tomo
Apr 18, 2008 | GPS
my garmin nuvi200 keeps on searches for satellite,but it couldnt able to pick up signal. A question mark over a map is always im seeing througout
Apr 06, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 250w freeze up
EXact same model and exactly the same problem for me.
Mar 04, 2008 | GPS
Garmin nuvi 350 GPS Receiver Logo
828 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
