Question about Maytag PYE2300AY Electric Dryer
When energized, the heating elements glow for only about 5 seconds. A click is heard and the elements stop glowing. After about 3 minutes, a click is heard, and the elements glow again, only for a couple of seconds, they don't even get to full glow, a click is heard, then the elements shut off again. I thought it was the Control Thermostat and replaced that, but it made no difference. Thoughts? Thank you!
  • 3 more comments
  • FWE002 Feb 03, 2008
    Hello Jimster!
    Thanks for your reply! Ooops, yes I had the door open. I popped the top and ran it (door closed now) and the coils heat for about 30 seconds, then off for 15 seconds, on for 30, etc... The coils are all lit. So, it does seem to be working correctly. There is no lint built up anywhere in the system. The hose vents to the outside of the house about 3' off the ground. The loovers are wide open, air is blowing outside like crazy.
    Here's the problem. Dryer is 7 years old. I use it once a week for two loads. It used to take one cycle, about 45 minutes, to dry the clothes on either low or regular heat settings. Then it started taking longer, up to two cycles, 90 minutes. The last couple of weeks some of the clothes are still a little damp after the two cycles. I replaced the Control Thermostat; did a load today. One cycle - clothes still very damp. Two cycles - clothes dry. Hmmm.. a few less items in this load, though.
    Another thought... is the spin cycle in the washer not getting enough water out? So, I'll do a load in the wash and let it go through 2 spin cycles and see what happens in the dryer.
    I'll welcome any further thoughts you have!
    Thanks again!
    I put the load through two spin cycles, but frankly, they did not seem dryer after the second cycle as compared to the first.
    This time I dried the load on the timed cycle instead of on the auto dry cycle (using the moisture sensor). The clothes were dry in about 45 minutes! How it should be!
    So, can you explain to me how the moisture sensor and auto dry cycle works? Does the sensor just sense wet and dry, so that when it senses the clothes are dry, it shuts it off? Or, does it sense DEGREE of wetness/dryness so, that as the clothes dry, perhaps the heat coils don't come on as often or do not stay on (duration) as long? If it is the second, then I could see how a faulty moisture sensor would cause the clothes not to dry in one cycle. The sensor thinks the clothes are drying, so advances the timer, then shuts off; yet the clothes are still wet.
  • FWE002 Feb 04, 2008
    ARGHH! Apparently I don't have moisture sensors! I replaced the Control Thermostat, so now what?
  • FWE002 Feb 07, 2008
    I replaced the Control Thermostat, which is in the front on the blower. I did not inspect the wires closely, but did not see anything wrong when removing them from the original thermostat and replacing them in the new one. But I can take a closer look.
    The auto cycle (the cycle I'm having a problem with) runs the normal length of time, which is around 45 minutes. It's just that the 45 minutes USED to dry the clothes. Now the 45 minutes leaves them pretty damp still.
  • leondia Mar 16, 2008
    Same problem with clothes not drying completely, but I also hear a "noise" associated with this. Thought maybe too many items were in dryer, but same problem when no clothes inside. What is the first thing I should start replacing?
  • 56 Answers
Mine did the same thing. Pull the plastic shroud off the inside of the front panel, where the lint trap is. I did this and mine was nearly completely plugged. No way to see it or know it if you don't remove it from the front panel (you have to remove the front panel, two screws top left and top right. Make a mental note to do this at least once a year. Every six months would be even better.
Posted on Feb 11, 2012
  • Mike Teter Feb 11, 2012
  • 240 Answers
First off, how are you looking to check this situation. Either way, it would be normal for this to happen. When you are looking at the elements heating, you more than likely have the door open to see them. The heater will do what they call "short cycling" because the airflow has outside source air getting into the heat stream. The door and lid almost always has to be shut for this system to work correctly. You can sometimes crack the top just enough to see the element heat. Usually, if the element is coming on at all, then the system should be fine. If you have a dryer thats not drying your clothes completely, its more than likely you have a ventilation issue (i.e vent tube restriction, grass growing in the end of the vent, etc). Also remember these Maytags have two thermostats on them most of the time. One directly over the top of the element, and one in the fan housing at the front of the unit. Try those, if there isnt a change, write me back and will look from there. Good Luck!!!!
Posted on Feb 02, 2008
  • James Greene
    James Greene Feb 03, 2008
    I would guess maybe tha you might feel the clothes being to wet coming out of the washer, but it is a possibility for sure. You would happen to know if that dryer has an automatic setting on it do you? Didnt know if you were using that cycle, or timed dry cycle. If using timed dry cycle, try using the automatic heavy or regular cycle to see if that helps. If you are using the automatic cycle, you may have a problem with the sensor (which in this case is the thermostat in the front). Let me know.
  • James Greene
    James Greene Feb 06, 2008
    Ok, let me ask you this. You said you replaced the control thermostat is that correct? Was this the thermostat up on top by the element, or the thermostat down front bottom by the fan unit. If you replaced the one up top, that is a high limit thermostat. The actual control thermostat is down by the fan unit itself. You will have a (I believe) orande wire that runs from that thermostat up to the timer. That wire is actually the wire that transfers the signal from the thermostat to the timer for the operation of the moisture sensor. Check that wire to be sure it isnt broken or loose. If that wasnt the thermostat you replaced, that may be the problem. If you did replace that one, that wire may be bad, or you could have a timer problem. Let me know, and will go from there. Talk to you soon..
Should the heater element in a tumble dryer actually glow red?
If your dryer is electric, then yes. The metal coils in the dryers element are energized with electricity with causes them to heat and when metal gets hot, it will glow.
Jun 03, 2012 | Dryers
Model # pye2300ayw it seems to run fine but no heat?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Jan 18, 2011 | Maytag PYE2300AY Electric Dryer
PYE2300AYW dryer doesn't heat up, but vent system ...
May 20, 2010 | Maytag PYE2300AY Electric Dryer
Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Feb 27, 2009 | Maytag PYE2300AY Electric Dryer
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer: pye2300ayw
yes, it will. you should be able to take off the panel on the bottom of the front of the dryer. way in the back is the heating element. do not put your hands in there with the power on, but start the dryer and look in there and you will see if the heating element comes on. it will be like looking inside your toaster.
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
The heater in Maytag MDE2400AyW does not all elements glow only the ones in the middle
HI thanks for your question. the element is probably broken. and part of it is touching the frame, of the element housing. remove element and look for a break. but unplug dryer first. thanks the appliance doc. please rate my answer. thanks.
Oct 05, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
980 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
