Question about Pioneer VSX-D511 Receiver
PIoneer VSX-D510 power issue! pleas help!
My receiver will power up, after about 5 seconds it will say power off and then it will turn itself off. can anybody tell me what the problem could be thanks
  • pledgeMaster Feb 02, 2008
    everything is disconnected and it does the same thing, does this mean i have to bring it somewhere to get it repaired or would it be possible to repair myself? thanks
  • Anonymous Mar 14, 2014
    when amp turned on after a few seconds says power off and will not play
    Problem Solver:
  • 8 Answers
Must be the protection circuits kicking in. One or more amp channels must have blown.
Posted on Feb 02, 2008
  • Noel Guiriba
    Noel Guiriba Feb 02, 2008
    First make sure the problem is with the receiver. Disconnect everything from the back, including the speakers, then try and turn it on again. If the problem persists, the most likely problem is a bad output channel.
  • Noel Guiriba
    It would be best to have it repaired by an authorized Pioneer repair shop. They will use the right parts and tune the receiver to specs when they are done. Get quotes first. If the cost if fairly high, it's probably best to just get a new one.
Resetting vsx-d510
On the remote controller, press and hold "remote setup" and 0 simultaneously for about 5 seconds. When it's successful the remote display will blink 3 times.
Feb 21, 2012 | Pioneer VSX-D510 Receiver
How to hook it up with sub dvd
Not sure what a "sub dvd' is but here's the manual. The Subwoofer Pre Out would provide a Line Level feed for a powered subwoofer, once it is configured to do so.
Page 14.
http://www.retrevo.com/support/Pioneer-VSX-D510-Receivers-manual/id/385ci969/t/2/
Jan 30, 2011 | Pioneer VSX-D510 Receiver
PIONEER AMP ERROR
Most probably you have one of the power amplifier modules bad. They are the PAC010 and PAC011 type. You can remove one and power up the receiver. If it powers-up normaly it's that one.... (50% chance) Otherwise remove both and it should power up normally. Beware that these parts are expensive... Most times just with a new part the problem is solved. YMMV. Good luck
Jul 14, 2009 | Pioneer VSX-D510 Receiver
Pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Jun 21, 2009 | Pioneer VSX-D510 Receiver
Weird issue with Pioneer VSX-D510 and "tone"-setup
clean the all push buttons by using isoprpylalchohol.(surgical spirit)and dry well .i think all the buttons are short by itself.the problem is still there please check the power supplu secondary side smoothing condencers related to system control power section.
nuwan
Oct 02, 2008 | Pioneer VSX-D510 Receiver
Pioneer vsx-d510 coaxial dvd connection problem
I recommend you use an optical connection. Your VSX-D510 has only one optical input, but I believe it is assignable. Use a good optical cable and connect directly to your DVR. Follow the manual to assign the input and it should work.
Good luck
Nov 16, 2007 | Pioneer VSX-D510 Receiver
Pioneer VSX D510 Reciever (power supply or the main amp circuit problem)
I'm having the same problem. I read on a kind of VSX-D510 eletronic manual tha says POWER OFF "When displayed, it's the case where DC is in the output of AMP".
Do you know what does it means? How can I solve the problem?
Aug 21, 2007 | Pioneer VSX-D510 Receiver
Pioneer VSX-D511 Receiver Logo
260 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
