Question about Sony KDF-E50A10 50 in. LCD HDTV
Sony KDFE50A10 Just shows snow, buttons do not repond
I have a Sony KDFE50A10, when I turn it on, it just shows snow (and I dont mean the weather channel). None of the buttons respond (TV/Video, volume, channels). I tried using a remote, and I can turn it on and off, but I cant change the inputs or get a menu or anything, Any idea what is causing this and how to fix it?
Thanks, Jose
  • SteelNitrous Feb 03, 2008
    No, I was using a universal from my Time warner box. No, I dont have the owners manual. I will give the memory stick thing a try, but I dont see it working. The tv/video button is not working, so I cant change which inputs I am accesing. I took the whole tv apart, I didnt see any disconnected hook-ups, (ie from the front panel to the rear board. Do you think Sony would still cover the warranty if I dont tell them that I took it all apart and put it back together?
    Sergeant:
  • 261 Answers
Do you have the correct remote? That would be my first question. But most sony remotes will change channels and turn set on and off. Do you have the owners manual? If i'm not mistaken, that thing has a memory stick input doesn't it? Try that and let me know what happens. Thank you and good luck. Jay
Posted on Feb 01, 2008
  • Jay Henderson
    Jay Henderson Feb 06, 2008
    No, don't mention it. But look for any sony remote and try changing the video inputs that way. Did you say the buttons on the front panel don't work? They should. Make sure in the menu you don't have them disabled. Let me know. Jay
Video lines
Very common problem usually caused by a defective B Block.
Jul 07, 2010 | Sony KDFE50A10 50" HDTV
Tip
How to Know What Kind of Snow Blower to Buy.
Snow blowers are great for places where snow is a regular feature in the weather as uncleared snow can not only block access but also cause a danger.
There are 4 very different styles of snow blowers and i'll explain some of the differences.
Width:
The width measurement ie 24 inches or 26 inches, makes a big difference to the ease with which you can turn the snow blower. So if using a wider machine might be a challenge for you - bear it in mind.
Snow chute:
Some machines allow you to direct the direction of the snow chute ie you can make it go left or right. Some machines need you to direct the snow output ie whether it goes up and down using a manual button. Where as more expensive machines tend to have one handle that allows you to control all the directional factors.
Engine Size:
The smaller engines are not as powerful as the bigger ones. If the area you plan to use it has moderate to light snow, you might be fine with a smaller engine, but if the snow you need to clear is heavy and frequent, you should consider a bigger engine. The larger engine sizes allow the snow blowers to turn faster and more powerfully.
Stay safe and make sure that you dont' let children play around with snow blowing equipment.
on Jan 02, 2014 | Garden
SONY KDFE50A10 HAS A UNEVEN BLUE BLOB ON SCREEN
optical block is famous for causing that sympton in a Sony
Jun 19, 2010 | Sony KDFE50A10 50" HDTV
Powers off with a blinking standby light for 45 blinks
Yes, its clear symptoms of weak lamp that is going to end of its working life, soon tv will show you lamp light.
Replace lamp to solve the issue, lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
May 25, 2010 | Sony KDFE50A10 50" HDTV
My Jandy PDA has stopped working. It started to
need new PDA hand held make sure to replace with same model old ones 800 MHz new ones 900 MHz means change antenna also
Apr 05, 2010 | Jandy AQUALINK RS TELELINK KIT
50 inch lcd turns on for about one minute then turns it self off
Sony KDFE50A10 shuts down after 1 min is most likely bulb failure. XL-2400
Normal after a few years of use. Only test is to replace bulb. If in Canada look here:
Sony Gallery
easyab
Feb 28, 2010 | Sony KDFE50A10 50" HDTV
I have a code of 6 red flashes on my KDS E50-A10 Sony TV. I was told to replace the lamp and I have just done that, but I still have 6 flasing re light code and no picture. any idea what's next?
6 times red light blink shows error in power supply (GT) board because of no 12 volts output for some reason.
Replace GT board to fix the problem.
Let me know if you need GT board part number info.
Thanks.
Dec 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
I have a Sony KDFE50A10 50 inch HDTV When I turn it on for it has the lines verticle on it it takes a few minutes and then clears...tv or cable?
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or vertical lines.You will need to replace the light engine.God bless you!
Oct 20, 2009 | Sony KDFE50A10 50" HDTV
Sony kdfe50a10 blinking green light
did you find out the answer to this problem as we have the exact same issue? thanks
Sep 22, 2009 | Sony (XL-2400) Projector Lamp for...
Kdfe50a10 Sony lcd projection TV. No red color
Make sure you get colors by bringing the TV menu and see if looks normal, if it does
maybe the problem us the signal source
Apr 03, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 50 in. LCD HDTV Logo
110 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
