Question about Epson DFX-9000 Matrix Printer
Manuals parts listing
Hi i have a problem with a DFX 9000. When either the fron or back tractors rotate to park the paper i get a loud shuddering noise like gears missing although it cant be as the gears would make the noise when winding forward.Possibly a motor or clutch problem.when watching it reverse the paper the paper guide above the print head chatters back and forward causing the noise. Does any one know what the cause could be , the soloution and the part number if i require a part.or where i could get a copy of a parts manual
Robert
  • robertleekin Feb 19, 2009
    There are two possible causes for this.
    #1, the belt tensioner on the printer's left side is not adjusted properly and causing the belt to jump teeth on the drive side.
    #2, one or more teeth is broken or damaged to the point that it slips when the guide rotates in reverse.
    Sometimes, simply adjusting the gear positioning on the right side and the tension of the belt on the left side will be sufficient to fix this behavior, others require replacing one or more gears. The sited manuals are useless for this issue.
    Genius:
  • 3,422 Answers
Here are the manual links it will solve all your problems..
Click on the first and second
first
Second
You need to have adobe acrobat reader to view the manual in pdf format.
Click here to download it if u don't have..
Goodluck,
Don't forget to arte me as fixya..
Posted on Feb 01, 2008
Dfx-9000 drives font tractors down wards.
you have to clean the 2 sensors (optical) on the cr unit because they detects always paper
Jul 05, 2014 | Epson DFX-9000 Matrix Printer
Error : paper jam Epson DFX-9000
I find problem printer epson dfx-9000 with mesage
error : 0E
turn off printer
help solution this problem ????
Sep 14, 2010 | Epson DFX-9000 Dot Matrix Printer
We are getting a grinding noise when feeding paper
Hi Chezicke:
You have gears on the left side of the printer that drive the tractor assembly, they may be worn or loose and not messhing as they should to drive form feed. Remove left side cover to check gears.
pdouglasss
Jan 08, 2009 | Epson DFX-9000 Matrix Printer
Re dfx -9000
Please perform the following steps to ensure your printer is physically functioning.
1. Turn the printer off and disconnect the interface cable.
2. Load plain, single part tractor paper into the printer.
3. Press the LOAD/EJECT button while turning on the printer.
NOTE: The self test prints over several pages. After the first or second page has printed, press PAUSE and turn the printer off.
If this self test prints correctly, then the printer hardware is functioning correctly.
>Try printing from other applications.
>Check cables as they can cause communication errors.
>Re-install the driver.
>Go to support.epson.com for more information & documentation.
Sep 08, 2008 | Epson DFX-9000 Matrix Printer
Papaer out error
Paper detection switch on tractor feed unit is probably faulty. Replace the tractor feeds.
Jul 15, 2008 | Epson DFX-9000 Matrix Printer
Line feeds
Hi-
When you said line feed do you mean the Top of form?
hope this helps
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
Keep me posted if you have inquiries, thanks!
Jun 18, 2008 | Epson DFX-9000 Matrix Printer
Noisey vibration
Dear Rab,
Hope this solves your problem. I understand that you are having problem only on the reversei side tractor feed problem. We have encountered same problem even in different models and brands. Please check the Lever Paper Fed Selector is engaged well, so that the gears give less space clearance to each other. Please check the tractor tray is locked tightly both ends. Please check if the grease on the paper tray and contacting gears are not dried up. Please check also the paper path if there are remains or clogged parts of paper perforation holes. Finally check the flatten (stainless still or hard plastic) paper against the roller if not to tight. You can check manually by turning the paper roller knobs back and forth. But take NOTE: Turn Off the power in doing so, it may destroy the knob. Have a nice day.
Best regards,
Rosener Guyano
Feb 02, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
426 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
