Question about Epson Stylus CX4800 All-In-One InkJet Printer
New printer clogged
Go this free CX4800 with laptop purchase. Gave to granddaughter. Hooked it up and it worked fine. Cartridge ran (black) out of ink so she removed it. By the time I purchased a new one and installed it I think ink dried up in printer nozzle or something like that. I see commercial products claiming it will fix the problem. Fairly pricey to buy. Anything else I can use and how do I do this. I have no idea. Thanks.
  • Illinoisg Feb 28, 2008
    I don't know how people run the cleaner cycle on the CX4800. I try to run mine and it says "ink out" and won't run. I hear the ink slosh around inside the cartidge, I poke a needle in the end of the cartridge and ink comes out, but the red light keeps flashing and it refuses to print and refuses to run the cleaner cycle when ink is out. I try to print black and white and it won't print black because one of the colors is out. I must replace all 4 cartridges after printing a few page.
  • 43 Answers
Do the cleaning cycle>go to printers and faxes right click on CX4800 go to printing preferences go to utility/maintainance and head cleaning do it 3 times
Posted on Feb 02, 2008
I ran out of the other color cartridges, and just bought a new black ink cartridge only. So can it work without the other color cartridges, and only on the black ink cartridge, because every time I try to...
No many of the printers will need to have both the color and the black cartridges to work...
You will have to purchase and install a new cartridge to get it working correctly.
heatman101
May 17, 2011 | Brother MFC-290C Printer
Ink cardridge replacement
Try cleaning the print heads (that option should be on your printer's menu). It does use up some ink, but in my experience with Epson printers, it needs to be done way too often. If that doesn't work, try another new black ink cartridge. I just had the same problem with an HP printer that was fixed by using another new cartridge.
May 06, 2010 | Epson Stylus CX4800 All-In-One InkJet...
My Epson Stylus CX4200 will not print because my Cyan ink is out. I tried printing in black and white only but still won't print because of the one empty cartridge. Is there any way I can still print...
I have a CX4800 and after clicking Print, I click Properties, then check Black ink only (is this how you are printing black and white - or is your document black and white)
If you haven't tried this option - it is worth a shot.
Mar 01, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
Cyan ink empty but i only want to print black
pHi
The majority of printers out there will not let you print if
a particular color is empty. Especially on inkjets. This prevents the nozzles from clogging up.
Thanks adi
Jan 11, 2010 | Epson Stylus CX4800 All-In-One InkJet...
I have installed a new black ink cartridge. "Ink is out" comes up when I try to print. It is properly installed and is the second new black ink cartridge this has happened with. The "On" and 'Ink" lights...
I have installed all new cartridges. "Ink is out" comes up when I try to print. It is properly installed and is the second set of ink cartridge this has happened with. The "On" and 'Ink" lights do not stop flashing. The printer does not see the new cartridges.
Jan 04, 2010 | Epson Stylus CX4800 All-In-One InkJet...
No black print
I just installed a new black ink cartridge and it won't print. My new color one will. It worked fine until it ran out of ink and I replaced it with a new one.
Dec 06, 2008 | Dell A940 All-In-One InkJet Printer
Restart after replace ink cartridge
my CX4800 has done the same thing. I ran the utilities dozens of times, replaced every cartridge and it feeds papers the print head moves like it's printing but nothing is imaged on the paper.
Searching the web is my last chance to fix it before i toss this 18 month old printer and never buy an epson again.
Aug 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson CX4800 dried ink
You can use the "Clean Print Heads" function if your printer allows and provides such an option. You can find this option via the printer proprties (Start > Printers and Faxes, right click your printer and select Properties. The clean options will usually be on the Maintenance tab)
May 27, 2008 | Epson Stylus CX4800 All-In-One InkJet...
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Epson Stylus CX4800 All-In-One InkJet Printer Logo
69 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
