Question about Dryers
Commercial heating system
Could you tell me what i need to heat large commercial area with run off hot water.
  • WASHER111 Feb 02, 2008
    thankyou for this help.
  • 240 Answers
Posted on Feb 02, 2008
  • James Greene
    James Greene Feb 02, 2008
    I am a washer and dryer man, but thought it might help you a little. Thanks for the reply.
Want to shut off my hotwater heater and still run my boilerhave base board heat
Turn off water but leave heat on - Possible? - Handyman WIRE ...
handymanwire.com > ... > Heating and Air Conditioning
Jan 14, 2003 - 10 posts
My hot water baseboard heating system is a closed system. ... Could I shut off the main water and leave the boiler and heat going for ... If one is not installed, install one and rely on that to save the boiler from the damage of running out of ... I do not wantto have city water push my antifreeze out of the system ...
What's the best temperature to set my hot water baseboard ...
greenhomeguide.com/.../whats-the-best-temperature-to-set-my-hot-water...
Nov 21, 2010 - With hot water baseboard heating, is it better to keep the heat at 60+ degrees ... a hot water heating system where water is heated in a hot water boiler and then ... by setting the thermostat to lower the heat when you don't need it on. ... Not only do I turn my heat down when I leave for work in the am but also ...
Jan 17, 2016 | Water Heaters
I HAVE WORCESTER 24SI BOILER , THE HEATING IS WORKING BUT NO HOT WATER THANKS.
Hi Mustafa, you are going to need a Gas Engineer to fix this one. It could either be the Hot water sensor or the flow switch that activates the water to come on. Good Luck.
Jan 03, 2015 | Water Water Heaters
I just renter a house with a Rinnai R94LS water heater. The house and heater are 3 years old. 50-70% of the time I get a shower, the hot water suddenly stops after just 5-10 minutes and goes completely...
Its a tankless heater. It will heat water as long as it senses a large enough flow of water. Either the flow sensor is bad, or not sensitive enough, or you are using less water than it is set to work at. Try keeping a large flow running. Instead of a trickle, shut it off entirely.
Apr 09, 2017 | Heating & Cooling
Make a electric water heater elements come on at same time
1) You want simultaneous operation.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#simultaneous
2) Installation REQUIRES bigger circuit breaker and bigger wire.
Or 2 circuit breakers and 2 wires
Or change both elements to 2000 watt.
http://waterheatertimer.org/Color-codewire.html
3) MUST add ECO-protected thermostat to lower part of tank.
4) Warranty will be void.
5) If tank is rusted, the added heat and expansion could hasten rupture.
http://waterheatertimer.org/Replace-anode-rod.html
6) As general rule, the health department will not allow this tank conversion for restaurant code to meet dish washing consumption unless manufacturer certifies tank.
But manufacturer will not certify ordinary residential water heater for commercial simultaneous application. Commercial simultaneous tanks can cost 2-4 thousand so they can meet restaurant code and deliver sustained high temperatures for washing dishes.
6) Also consider Hatco booster heater for commercial dish washing.
This type heater has 2 sets of non-simultaneous elements to heat large tank of hot water.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 21, 2012 | Rheem Water Heaters
How to design and calculate the solar heat panel for hot water system for the concentrated 100 nos. staff toilets and changing rooms of commercial building in Beijing. What is the basic and ancillary...
Usually toilets do not require hot water.
Is the plumbing divided into hot and cold water pipes?
If toilets are hooked to hot water, how many flushes and how many gallons per flush per day.
What is the expected consumption per each worker?
What is the latitude from equator, and expected solar input. Further north, and hazy atmosphere reduce input. Beijing has smog I believe.
How often is the solar panel going to cleaned of smog and dirt for maximum collection?
If the area has hard water, then the entire system is prone to sediment build-up and failure unless water is artificially softened.
Solar water heater temperatures can exceed 180 degrees at times. This temperature will damage storage tank that is not made for that temperature.
Most solar water heater systems have pressure regulating valve and expansion tank to accommodate occasional high temperature and pressure.
A good fellow to contact might be at following website:
http://www.builditsolar.com/Projects/WaterHeating/water_heating.htm
Solar collectors are usually connected to a circulating pump, and then the heated water is stored in a tank.
The pump circulates water continually from solar collectors through a storage tank.
This type of system would use ordinary tank-type water heater for storage.
Most of these systems also utilize a back-up heating element inside the tank.
More complicated systems circulate special liquid through spiral tubes inside the water heater.
This type of heater would be an indirect water heater.
Indirect heaters are used for solar collectors, and used with boilers, or any outside heat source.
http://www.bockwaterheaters.com/Products/products_coil_tank_water_heaters.html
http://www.hotwater.com/products/residential/cirrex_solar.html
http://waterheatertimer.org/images/solar-water-heaters-on-roof_lbiRv_5784111-500x282.jpg
Oct 05, 2011 | Water Heaters
THE MR. COFFEE COMMERCIAL COFFEE BREWER MODEL MRCTB. IT DOESN'T HAVE ANY LABEL. MY QUESTION IS JUST NEED TO KNOW IF I CAN USE THIS IN 110 V OR 220 V. SINCE IT IS COMMERCIAL.
Hope you can help. Water runs though pot but the water is not hot whatsoever. Heating element burned out?
Commercial Brewer 8543
Apr 20, 2010 | Bloomfield 8543 Coffee Maker
Commercial glass sterilizer draining hot water tank
SOUNDS LIKE THE TIMER RUNS CONTINUOUSLY, DOES IT RUN WITH THE DOOR OPEN. HOW DOES IT GET WATER IF IT IS NOT "ON" THE WATER INLET VALVE COULD BE LEAKING INTO THE UNIT, BUT UNLESS ON SHOULD JUST OVERFLOW UNLESS IT AUTOMATICALLY SENSES AND HEATS THE WATER . IT MAY BE AS SIMPLE AS A TIMER OTHER THAN THAT CAN YOU JUST TURN OFF THE UNIT WITH A SWITCH, MIGHT BE CHEAPER........
Mar 08, 2010 | Dishwashers
Diswasher not heating water
check your connections under the sink. A dishwasher (unless it is a commercial one) is not built to heat water the water is supplied via the water heater via the sink angle stop. The dishwasher does however have a heating element inside used to dry the dishes. I would check the hot water side of the sink where the dishwasher is connected to see if the problem could be in that area. Check your setting on the machine. Good Luck on your repairs
Dave
Sep 15, 2009 | Dishwashers
Bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Feb 13, 2009 | Bunn Coffee Makers & Espresso Machines
Dryers Logo
Top Dryers Experts
Marvin
Marvin
