Question about Gaggia Titanium Espresso Machine
My gaggia titanium says it's brew unit is blocked
My gaggia titanium coffee machine says it's brew unit is blocked is it an easy repair?
  • Gaggia Expert
  • 109 Answers
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Posted on Feb 22, 2010
SOURCE:
I removed the brew unit to rinse when I accidentally dropped it. It broke into various pieces. Where can I buy a new brewing unit for the gaggia titanium espresso machine?
Hi, Any domestic coffee machine repairer can get you one. They might even have one in stock, but they canbe very expensive. Up to $300. I do have some contacts in Brisbane that may even have second hand one. Im a repairer Dazza
Sep 05, 2011 | Gaggia Titanium Espresso Machine
We have a five year old Gaggia Titanium regularly descaled. In recent weeks the flow of coffee has considerably slowed to a drip and we now get a message saying 'Brew Unit Missing'. The machine also now...
Remove the brew unit, find the 2 screws above the top shower the connects the discharge tube to spout. Remove screws and carefully remove spring and ball some have a plastic seat at end of spring. Clean tube make sure there is no coffee grounds blocking tube, reassemble and test.
Aug 23, 2010 | Gaggia Titanium Espresso Machine
Leaks water from bottom when brewing coffee or using steam unit
If it is coffee colored water, check the chamber under the white plastic valve behind the brew unit, that might be blocked with coffee grounds. If it is clean water one of the lines might need new o-rings.
Apr 14, 2010 | Gaggia Titanium Espresso Machine
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Grinder blocked
Check the chute from the grinder to the brew unit.
Oct 06, 2009 | Gaggia Titanium Espresso Machine
Gaggia Titanium Brew Unit Blocked
Check the shower screen on the brew unit.
Aug 04, 2009 | Saeco Incanto Classic Espresso Machine
Hi I have a gaggia titanium coffee machine it has comme up with an error message the the brewunit is blocked i have decalcified machine but no joy can you help
Remove brew unit, If you have the key that came with the machine use it to remove the shower screens and check for blockage.
Mar 29, 2009 | Gaggia Titanium Espresso Machine
Gaggia titanium is leaking water
Mine had the same problem. Take out the dreg drawer and brew unit. Then you will see a plastic cover roughly in the middle of the machine (behind where the brew unit was) that is held in place by two philips screws. Unscrew the screws and take out that small cover. It is probably filled with coffee grounds that prevent water from dripping out through a dripping hole. Clean out the grounds and you should be all set.
Gerwin Schalk Albany, NY
Dec 16, 2008 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
771 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
