Question about Garmin Nuvi 660 GPS Receiver
Nuvi 660 Volume
When the volume is turned all the way up the sound is still too faint to be easily heard. Can the output be increased?
  • Chris Pike May 11, 2010
    Navaho, Here's some "real" information for you. It sounds like the audio output stage may be defective or you have a defective internal speaker.
    Try plugging a pair of headphones into the unit and see if you have plenty of volume there. If you do, the speaker is defective. If the sound is still weak, then the audio output stage is defective. That stage is common to both the speaker and headphone jack.
    If the sound is okay on the headphones and you don't want to spend the money or hassle having the Nuvi fixed, you can buy a FM transmitter and plug it into the headphone jack and play the Nuvi through your car stereo. You can pick one up at Best Buy. They are used on Ipod's and CD players.
    Sonyhoppes, since you appear to hang out in the Nuvi 660 portion of this site, I challeging you to actually provide a "real" and "solid" solution to any of the questions here and without flaming others.
    Perhaps I am just expecting too much out of you. No doubt you will blow off the challenge and just insult me to elude the fact that you are nothing more than an "appliance operator" with little or no knowledge or experience in anything.
    If you spent half as much of your time actually helping people than flaming them, you could actually acquire a reputable reputation here and gain respect among your peers.
    So blow off the challenge and continue to insult.... you'll just be proving my point and my opinion of you.
I had the same problem with my unit. I went back to The Source and they told me it was normal. I had a garmin streetpilot before the nuvi and the sound was much better.
The streetpilot has 2 speakers and the nuvi only has one. I had another problem with my nuvi and I exchanged it for another one and the volume problem is gone.
Use the male voices over the womans they seem to be recorded louder.
My problem is over
Posted on Feb 05, 2008
6ya staff
SOURCE:
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
No sound
First check if your nuvi is not on mute by touching the button next to the volume that reads mute, then you try to increase the volume. To increase the volume:
  1. from the main menu,
  2. Touch the volume,
  3. Then you adjust it with the left and right direction button to increase it or reduce it.
If that does not solve the problem, then you need to reset the nuvi, by holding the power button for about 15 seconds. It will restart itself. Or you can remove the battery and install it back in. If that does not solve the problem, then it is an internal problem.
Dec 29, 2010 | Garmin GPS
Garmin Nuvi 610- working perfectly then sudden crackling and now loss of sound/or at best crackly and intermiitent sound- but map/navigation and on-screen directions fine
Check the audio output setting on the nuvi. There is a possibility that the FM Transmitter setting has been turned on or that the device has been muted.
To check the audio output setting:
  1. Touch the Speaker icon below the Wrench icon.
  2. At the bottom of the screen, touch Audio Output.
  3. Make sure that the Internal Speaker is selected and touch OK (660, 670, 680, and 5000 models only).
  4. Make sure that the MUTE box does not have a check mark in it. If it does, touch the box to clear the selection.
  5. Make sure the volume level is at a reasonable percent level.
Sep 24, 2010 | Garmin Nuvi 610 GPS Receiver
No sound
Aug 13, 2009 | Garmin Nuvi 660 GPS Receiver
No voice to Garmin Nuvi 660
In case it is a software problem try this and see if it will fix it......follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
Jan 17, 2009 | Garmin Nuvi 660 GPS Receiver
Shows directions, but no longer speaks
Is it possible you've turned the volume right down?
Jul 09, 2008 | Garmin Nuvi 660 GPS Receiver
No Sound
You might have just turned the volume all the way down. Page 4 of your manual tells you how to adjust your volume.
Apr 22, 2008 | Garmin Nuvi 660 GPS Receiver
Stop transfering voice from Sony Ericson P910i and Garmin Nuvi 660
Can you update the firmware on your unit
my k800i sony phone had a problem synchronising and would freeze, then one day the nuvi 660 updated the firmware by itself and has been fine since, only problem being the volume, a bit low when trying to contest with large diesel engine, onboard speaker keen to distort over 80% volume
Feb 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
105 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
