Question about Car Audio & Video
Shogun pajero 1990 rev counter
Rev counter just stoped working but everything else works help please
  • 2 more comments
  • stellasmoss Feb 01, 2008
    rev counter on my 1990 shogun pajero just stop working but everthing else is fine please help
  • Anonymous Jul 31, 2008
    Rev counter suddenly stopped working.
    It does work now and again
  • Cordie Heaney Aug 26, 2008
    My boyfriend has exactly the same probolem on his Pajero - took it to a garage and they said they couldn't fix it as it was Digital........what to do??????
    Same problem - although this time it's a digital one.....any help out there????
I think your problem is not the cable, and it could only be the plastic drive from the gearbox first
get this checked
hope it helped
jj
Posted on Oct 21, 2008
  • 4,102 Answers
Hi i think your going to need to replace the speedo cable this goes from the back of the dash display through the bulk head then into the back of the gear box.
When you remove the old one remember how it came out as they can be fidly to do.
Im not 100% sure how much of the dash has to come out untill the display is free and you can get to the back of it.
The cables are not expensive but can be tricky to replace if you are unsure about working on vehicles.
Even if you took it to garage to get done it should not cost that much anyway if your going to do it yourself its best to buy the part before you reomve the old one so as you can follow the old one with the new one.
where it goes into the back of the rev counter this should just be hand tight and should undo the cap that holds it into the rev counter then it should pull out.
Where it goes into the gearbox you will need big spanners im not sure of size but usually about 17 or 19 spanner udon this and ot should pull out its splined into the gearbox once removed you will know if the cable is damaged by turning one end and see if the other end turns or not.
In the rare case that this cable is fine then you might find that the rev counter needs replacing this is not likely to be the problem though as they usually last as long as the car.
The gearbox end should have no problems so i would remove rev cable first and check this youll find it will have split in half.
If you need further assistance let me know or let me know if the rev counter is digital then let me know ok then i help you with that ok
Posted on Feb 01, 2008
Rev counter not working
This shows that a variable current is being given to the rev counter as it should beCheck all connections for dirt , corrosion & fastness especially the rev counter earthIf all the above are good then the rev counter itself has blown
Dec 29, 2011 | 1990 Yamaha FZR 600
I have a Pajero Junior but haven't seen before the 3 gear cars... Asked the dealer if that was faulty and they said the automatic ones have 3 speeds only... Is this true??? I think it's just faulty
Pajero Jnr auto has a three speed box. Like me, I imagine that you think it revs too high in top gear. I believe there is an overdrive available, but I am still looking. Mine revs at about 4000 at 60mph.
Dec 15, 2010 | 1990 Mitsubishi Minivan
Honda CBR 125 rev counter is not working
Hi, Stevieparkin for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.fireblades.org/forums/honda-fireblade/67966-hi-everyone-allso-rev-counter-problem.html
Tachometer Needle Doesn Move
Honda CBR125R Owner Manual service
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR125RW Owner Manual
Aug 17, 2010 | 2006 Honda CBR 125 R
Hi, My rev counter has suddenly stoped working after i diconected my battery. Also the low oil warning light is flashing constantly even though there is sufficiant oil. Help please! Regards Stan. P.S. The...
Hi Stan, are you didn.t connect back battery in wrong way? If the battery terminals has being turned around only for a second you might damage lots of electronic units in the car.If not the problem seems happened incidentaly.Any way the signal for the rev counter coming from the ECM. Oil level lamp can be a sensor
May 01, 2010 | 1995 Volkswagen Golf
My shogun exhaust glow red and wont rev over 3000 revs
possibly a bad manifold atmospheric pressure sensor or exhast system may be plugged.
Nov 15, 2009 | 1990 Mitsubishi Sigma
I have a 1989 mk2 gti and my rev counter stoped working pls help
rev counter? Do you mean the rpm gauge? if so, you need ot replace the instrument cluster.
Nov 26, 2008 | Volkswagen GTI Cars & Trucks
Cruise control not working 1995 Shogun/Pajero/Montero
hi... I am facing the problem before. You need to change one control ring(yellow in colour)inside the steering.You have to open the steering n there is one yellow ring inside the steering box.That control ring quit expensive but sometime you can get it secondhand.thank you
Oct 02, 2008 | 1995 Mitsubishi Montero
Car Audio & Video Logo
886 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
