Question about IBM ThinkPad R51 Notebook
Hello there is a wire that must run from my mother board to the screen....i cracked off a arm on my screen in which i see a wire that runs maybe up the screen....so after time this wire wore now its open......so what would you think i should do, it won'[t turn on now?
Install Ethernet Driver
Posted on Feb 14, 2008
    Genius:
  • 1,003 Answers
I WOULD SEARCH EBAY FOR REPLACEMENT PARTS TO REPLACE THE WORN PARTS THAT ARE BROKEN on your LAPTOP if that isnt sucessful start pricing a replacement computer
Posted on Feb 02, 2008
Hello everyone. Just wondering do I need an optical drive for my brand new pic I just built? And I just installed my motherboard and the graphics card together but nothing is working on the screen.
use the cd that came with the mother board as it has all the drivers to make the mother board work and to line up the graphic card
if the was a cd for the card run that as well
other than that talk to a IT geek shop and get ideas
Sep 14, 2015 | ASUS Computers & Internet
Found electrics bad on compressor.Replaced with 3 in 1 kit.Compressor runs fine but condensor fan motor will not come on.I took the start capacitor out of the circuit but I have a wire that went from the...
why didn't you buy the overload and relay?i would get that 3 in 1 out of there,order the correct parts,most likely if the condenser fan motor failed the compressor was running to hot and cooked the overload and relay but this has a mother board in it that runs almost everything on this machine,you can't remove the cap or other parts so if i were you i would order the correct parts,put that cap back in and order a new condenser fan motor,if this machine is like 8 to 10 years and you never updated the mother board this also could be your problem,look at the mother board if it doesn't have all 7 of the relays in it it's not the newest board,also have you noticed the evap fan in the freezer maybe revving up or changing speeds that's another way to tell if you have a bad board if you noticed the fans speeding up or slowing down,here's a video hope this helps but get that 3in1 out of there and order the correct parts
https://www.youtube.com/watch?v=7m2XWHqr-n4
Jan 07, 2018 | GE PDS22MCR Bottom Freezer Refrigerator
I dropped my T4220 and now the screen is blank and its beeping. There are no visible cracks on the screen or the casing... The fan is on and nothing else :( Any help pls...
There could be anything from a wire off to a hair line crack on the mother board. If nothing much works apart from the fan, it is possible the mother board is now damaged.
Feb 15, 2011 | Fujitsu LifeBook T4220 Tablet PC
Gigabyte GA-945GCMX-S2 Motherboard having display..
At first I thought your screen went black during the start up process. After seeing the bios screen. In which case I would've said it was a bios setting for the display. Then I realized that I think you mean that their is no display at all. When you push the power button. Only the monitor led light. So, it may be a problem with your RAM stick/s. You should make sure that they are properly seated in the mother board. If they are new, make sure they are compatible with that motherboard. If you can you should swap them out with known good ram sticks. You could also try installing a video card and see if you can get display to work through that one. Make sure your main power supply wire connector is pushed in all the way. Swap the power supply with a known good one if you can. If still can't get it to work you may want to take the motherboard out and inspect it for burns, cracks, and anything that doesn't look right. Maybe contact the manufacturer of the motherboard and ask them what you can check. hope this helps.
Sep 17, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
Tv only turns on, will go to soyo screen then black screen. when you can get the menu it only has symbles and no words can not turn off with out unplugging. never has a picture
Sounds like the Main Mother Board is the problem. Basically, it's the brain inside the TV. Controls and functions is that board's job.
Soyo parts are hard to come by. You can try running the number off the mother board on the internet and maybe a supplier will pop up.
Their Soyo.com web site isn't working. So, I'm thing they maybe out of business.
If you have some electronic experance and if your lucky, the heatsink on the chip processor is the problem.
Aug 05, 2009 | Soyo DYLT032D 32 in. LCD Television
My dell was hit by lightning and now i cant get it to boot up
hi there;
really,lightning has a great power voltages supply,thousand of volts was supplied in one strikes of lightning.this depend how much voltage was induces on your computer,mostly your avr and psu might be damage by checking if there is power determining the fans inside avr and psu if running maybe you have the power,and some led light are blinking ,some how to be sure you can use multi tester if you have knowledge on this.basic approach if you have black out screen and good power supply,pull out ide cable of hardisk and cd room from mother board,you can run pc w/o them to check your start windows if will open run your pc if still black screen,take another video card and memory card try to replace them and rn your pc,if windows open fine if not maybe you have damage the mother board from lightning.replacing defective devices can put back your windows open.best regards
Jul 24, 2009 | Dell Dimension 2400 PC Desktop
Mother Board Failure Where do you get a replacement.
ebay!
Dell 32" W3202MH,W3706MH 01004-2960 Main Video Board ... - eBay
https://www.ebay.com/itm/...W3706MH...Motherboard.../162597765902?_...
  1. Cached
US$59.99 - ‎In stock Model: W3202MH,W3706MH. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. Type: Main Video Board Motherboard Unit. ' eBay!
Dell Main Board 01004-2960 for W3202mh W3706mh ' eBay
https://www.ebay.com > ... > TV Boards, Parts & Components
  1. Cached
Used condition; • Returns accepted - 60 days money back or item exchange. Model: W3202MH,W3706MH. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. Type: Main Video Board Motherboard Unit. See details.
W3202mh W3706mh ' TV Repair Parts & Components Online
https://tvrepaircomponents.com/...motherboard.../discount-w3202mh-w3706mh__part_... Get the best deals on Part in our clearance section in addition to deals on motherboard board, board video motherboard, main video motherboard, main unit, un.
Dell TV Main Board ' eBay
https://www.ebay.ca > ... > TV Boards, Parts & Components > Dell TV Main Board
  1. Cached
Dell 32" W3202MH,W3706MH 01004-2960 Main Video Board Motherboard Unit. Model: W3202MH,W3706MH. Type: Main Video Board Motherboard Unit. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. C $74.81.
DELL 37" W3706MC 01004-3190 Main Video Board Motherboard Unit
https://www.ebay.ca > ... > TV, Video & Audio Parts > TV Boards, Parts & Components
  1. Cached
SKU: 01004-3190. Brand: DELL; Condition: Used; Notes: Please be sure that the BOARD Part Number and picture on your motherboard is EXACTLY as shown above. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV.
Mar 04, 2018 | Dell W3706MH 37 in. LCD HDTV
Broken flat screen tv
If you have not yet fixed this and haven't trashed the set I may have a solution.
I have a 50HP66 that has a good screen but bad sustain boards.
I will buy the boards from you...Easy to remove. Then you can use that money to buy a new TV.
Fixing a cracked screen is not practical. IE. Replacing the whole screen.
These sets are made to be sent to the land fill when the warranty is up.
Maybe we should have our lawmakers force companies to have minimum warranties for large toxic products that end up in the trash. Then they might make them last more than a year.
Sep 17, 2008 | Televison & Video
Emachine T4060 power supply
I have to assume you mean
Will the cooling fans run if it is still powered by mother board and disconencted from the mount ,such as processor or chipset ??
Yes it would , but is a very dangerous thing to do ,as it could easily short against anything within the case
Be more specific with your problem maybe someone can help you better
Nov 14, 2007 | E-Machines eMachines Desktop PC
IBM ThinkPad R51 Notebook Logo
74 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
