Question about Victor 1240 Calculator
Paper Roll Replacement
Does anyone know where to get a replacement paper holder? Mine broke in an office move. The calculator is still in great shape. Any suggestions will be helpful!
  • Lentom Jan 10, 2009
    I also need a paper holder for a TI-8250 Texas Instruments calculator. The calculator is in excellent condition but the paper holder broke.
  • 106 Answers
I work i mservice ,but for that model i don`t have a holder,but if you want i vill send you a universal holder.
beljin sasa
[email protected]
Posted on Feb 01, 2008
6ya staff
SOURCE:
Paper won't feed into slot on Canon P26-DH 111
Could not find anything directly about a Canon P26-DH III calculator but, here are steps I found for a similar model. Please let us know if this does the trick for your situation or not. Thanks & Good Luck.!
Installing a Replacement Roll
Move the power switch in the upper right corner of the calculator to the "Off" position. (or wherever it may be on your model)
Push the wire roll holder back so it protrudes from the back of the calculator. Place the replacement roll on the holder so the paper's end extends from the bottom of the roll.
Cut the paper's end diagonally and insert it into the slot in the back of the calculator.
Step
Move the power switch to the "PRT" position to turn on the calculator.
Oct 14, 2017 | Canon Office Equipment & Supplies
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    How do I change the paper tape roll on casio HR-100TM?
    Pull about a foot of paper loose from the roll so it's easier to handle. Put the paper from the new roll in the back slot, and hit "FEED" this will feed it through; after you have it through, roll up any lose paper, mount roll in holder, done, Should take about 3 minutes
    Mar 02, 2011 | Casio HR-100TMPlus Calculator
    Will not feed paper
    PAPER ROLL REPLACEMENT
    Never insert paper roll if torn. Doing so will cause paper to
    jam.
    Always cut leading edge with scissors first.
    1) Insert the leading edge of the paper roll into the opening.
    (Fig. 1)
    2) Turn the power on and feed the paper by pressing . (Fig.
    2)
    3) Lift the attached metal paper holder up and insert the paper
    roll to the paper holder. (Fig. 3)
    DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
    DAMAGE TO PRINTING MECHANISM.
    Dec 19, 2010 | Sharp EL-1801AII Calculator
    We can't get the paper to go into the machine?
    Installing the Paper Roll
    1. Lift the paper holder so that it extends behind the calculator.
    2. Make sure the calculator is plugged into an easily accessible
    electrical outlet near the calculator.
    3. Move the POWER switch to ON.
    4. Insert the end of the paper into the paper slot on the back of the
    calculator as shown. To avoid paper jams, use quality bond paper.
    5.While feeding the paper into the slot, press and hold up arrow.
    6. Place the paper roll on the paper holder.
    Note: To prevent damaging the printer (which may void the warranty),
    move the POWER switch to ON when operating the calculator without
    paper.
    Nov 27, 2010 | Texas Instruments TI-5045 SVC Calculator
    The paper roll holder is broken on one side. Can
    For most models, the holders can be replaced. You can try Universal Paper Arm Holders if you can't find one for your specific model.
    Mar 25, 2010 | Office Equipment & Supplies
    Broken Paper Roll Holder
    You must google to find the manufacture to find if anything is still available; but I have 2 ideas : 1. form a hard wire loop (from coat hanger or #12 guage steel wire) and attach this wire loopto the back of calculator case with screws (you'll need to make an eye loop at one end for the screw to go through). 2. make a small wood block that sits on the desk or table and make a wire loop that is held by the wood block and of course the paper roll is held by the wire loop. Goodluck, Macgivor.
    Dec 07, 2009 | Victor 1430-3 Calculator
    I have a Canon P23-DHV calculator and I cannot remember how to load the paper into it. I tried to read some of the solutions but could not ger any of them to open so I could actually see the solutions
    1. cut the paper/tape cleanly on a slight diagonal
    2. hang the paper/tape so it comes from under the roll
    3. insert the fresh cut into the slot on the back (between the power plug and tape roll holder)
    4. press the FEED button to advance the paper.
    Now, does anyone know how to turn off this blasted auto-shut-off feature????
    Jan 24, 2009 | Canon P23-DHV Calculator
    Replacement for broken paper roll holder
    There are universal glue on paper holders available email [email protected]
    Feb 13, 2008 | Canon P23-DH Calculator
    Victor 1240 Calculator Logo
    323 people viewed this question
    Top Victor Office Equipment & Supplies Experts
    k24674
    Lawrence Oravetz
    Andrew Taylor
    Andrew Taylor
    Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
