Question about Freezers
Freezer seal I have an iceline upright freezer and I think the door was left open for a while, now the door won't seal tight shut. this has happened before and the engineer told me what to do (something like tilting the freezer?) but I cannot for the life of me remember what it was, can anyone help please!
Take the door seal off and leave in the sun to soften then put it back on or take off door and use a hair dryer to soften then put back on.
Posted on Apr 23, 2008
  • 417 Answers
Turn the machine on to full empty all contents and leave for about 30 minutes then try to close door if doesn't work check the seal for splits.
Thanks J
Posted on Feb 16, 2008
Old whirlpool upright freezer. door left slightly ajar.light on inside. Rubber around door warm. won't seal.some things starting to thaw.shut door.should I do anything else
Seal needs to be replaced around door. Make sure magnetic strip is tight against sides of refrigerator, even if you have to cut the outside so it lays flat against the sides.
May 03, 2015 | Whirlpool Freezers
Freezer door has mosture on the outside
You need to order and replace the door gasket. Also check and be sure there the hight adjustment is correct, meaning the door is centered on the opening and not off set to where it can seal.hope this helps
Aug 10, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door seal not tight on upright freezer
Check the door sits straight and square on the front. You can "adjust" with the heel of your hand to make it sit flat against the frame. Even a poor seal shouldn't make frozen food thaw - check and clean the condenser and fan
May 08, 2012 | Kenmore 16.7 cu. ft. / 473 liter Upright...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Gasket doesn't seal at top of door.
you could use a hair dryer to attempt to remold the gasket to the door
other than that i think you would have to replace the gasket
May 27, 2009 | Frigidaire 11.6 cu. ft. / 328 liter...
Freezer door does not close tightly.
You can try replacing the seals and or adjusting the hinges.
That may work.
Be aware that if the unit is over 10 years old it is probably using twice as much power as a new one would and costing you an extra $75 to $100 annually to run over a new unit. Could be more than that if the door seals are not tight as well.
Jan 01, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer vaccum seal not working
check the gasket and make sure that it it not pinched and letting in air whe the door closes. primaryly around where the hinges are.;
Dec 27, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Not Freezing
Check the door seal all the way around. We purchased one recently that was slightly dented (not noticeably and the seal was not tight.) You need to get in touch with whomever you purchased it from immediately so that it can be repaired or replaced.
Aug 18, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
540 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
