Question about E-Machines eMachines Desktop PC
E machine no power
Hi i have a emachine 3310 and my cpu wont turn on no lights nothing ,changed the power supply but nothing even the fan does not come on in the unit i get a green light on the motherboard but no power or sign of life helpppppppp
  • Anonymous Feb 05, 2008
    nothinh working could my motherboard be fixed there is a green light comes on when i switch the power supply on but no life
  • 20 Answers
Make sure the RAM is seated, the CPU, any video card and the Power supply is properly connected.
If you power it on, still get no POST (beep at startup from the PC speakers) its time to replace the motherboard.
Posted on Feb 01, 2008
  • Brandon Hanes Feb 05, 2008
    The board may have a green light, indicating it is getting power, but this is not a sign of working components on the board.
    The cost of replacing the board around 40 dollars, vs the up to $100 dollars an hour a tech with that much experience will charge you to replace diodes and capacitors on your system board... you make the call.
    I told you already, order a new board
Emachine t6216 will not boot, fans stay on high and thats it. I do not hear hard drive spinning. It shut down a couple times while in use before this and came back on. also, it did not boot before and did...
hi Rpbarnhart.
this could be a few things wrong here.
the first thing i would get checked is the power supply.
Most likely either Motherboard or the CPU. Does this have a graphics card or built-in.
Standard procedure is to:
Clear the CMOS - chk manual for procedure.
Disconnect all cables from all drives and test.
Pull RAM and try with one module at a time in slot 1. Then try 1 in what might be slot 3, the 1st slot of second pair of slots.
Before giving up, I'd pull all the drive cables at once. Even carefully mark the front case wiring and pull everything but power switch if you can. You really want to remove all complications that might be an issue. Take it down to PSU, motherboard power, cpu fan and RAM.
Ok, there is Good news, and bad news. FIRST the bad news. You are not getting any power to the CPU. Fans and lights indicate motherboard power, BUT, power supplies ALSO provide power straight to the CPU, and if the CPU is not getting powered properly, it will not function.
or you could check these links out if the above does not work for you.
https://it.toolbox.com/question/my-emachines-model-t6216-does-not-boot-into-bios-061810
Build PC Emachine will not boot up
https://forums.techguy.org/threads/emachine-wont-start-up.1198007
Dec 08, 2017 | Computers & Internet
Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply: my cpu fan is running but at a low speed. When i t...
In my opinion you have a faulty power supply, replacing only the fan may not solve your problem. Try replacing the power supply.
May 16, 2010 | E-Machines Emachine T5026 power supply **...
Machine won't turn on . Period
Could be a bad power supply or a dead cpu. I would start by changing power supplies with one that is working if you have a spare computer with an ATX power supply. It is nolt very common but could be as simple as a defective power switch. How does the switch feel when it is pushed? Does it spring back or feel like something is broken. Most of the time when I have repaired a PC that does absouloutley nothing when the power button is pressed....dead CPU. You could also try leaving the plug disconnected for 20 minutes....maybe something in the powers supply is heating up. They will store power even when the computer is off.
Sep 13, 2009 | E-Machines eMachines Desktop PC
Emachine T6216 will not start
Ok, there is Good news, and bad news. FIRST the bad news. You are not getting any power to the CPU. Fans and lights indicate motherboard power, BUT, power supplies ALSO provide power straight to the CPU, and if the CPU is not getting powered properly, it will not function, and the result is what you see.
Now, the GOOD news is, Power supplies are relatively inexpensive (about 30-50 bucks) and MOST pc shops will install the power supply FREE (if you bring your tower to them, and purchase the power supply from them in their store, but call before going). If you want to save about 10 bucks, order the power supply yourself and install it yourself, but if you are not comfortable doing that, have a pro do it.
Aug 31, 2009 | E-Machines eMachines Desktop PC
Gateway 3310
are u having any beeps at all if not unplug the power supply cord and look at the wires that go from the power supply to the mother board and plug the powercord back into the powersupply and try to start the pc if the powersupply still does not start the fusible link in the power supply probably has blown depending on what kind of power supply you have some of these fuses are replaceable as long as they are not soldered i just replaced the one for my dell saved about 130 bucks please keep me posted on this if you get anywhere ok best regards mike
Aug 11, 2008 | E-Machines eMachines Desktop PC
Wont boot up
try to change your RAM,if same also
try to change your graphic card if u use it...
happy trying..
good luck..
Apr 17, 2008 | E-Machines eMachines Desktop PC
Emachine T2742 - Will not power on
Check the ram and make sure is securly in it's place.. Unplug everything else from the mobo except power and fan/cpu and power button..
Do the fans come on?
Mar 26, 2008 | E-Machines eMachines Desktop PC
Noisy machine
very likely it is the power supply fan. I also had a noisy fan and replacing it was a solution. try to get the measurement for the screw mounting dimensions and the height (thickness) and also the driving voltage then search ebay's site. it can be cleaned and lubricated however...
Sep 16, 2007 | E-Machines eMachines Desktop PC
Emachines 1900+ gets power to the monitor and computer but wont boot
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Desktop PC Logo
175 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
