Question about Sony PlayStation 2 Slimline Console
Ps2 not able to read disk
You turn it on and it says its unable to read disk.Put a new one in and get the same result.Clean the lens same thing.
  • dtv2 Feb 05, 2008
    Ok I tried to grease the rails.Still nothing.But I put an old ps. disk i had from the original ps. and it worked.Im thinking time to buy. thanks.
I put in a game and it says disc read error. and then i put in a new game and it says the same again.and i try cleanig it and that dosn't work.
Posted on Feb 06, 2008
    Genius:
  • 1,175 Answers
Find someone who can take the unit apart SAFELY.
There are 6 screws under 6 square tabs . you also need to slice thru one label.
Take the top off ( right side might take some extra work)
Clean the drive rails ( both the shiny one and the flat one) Use cotton tipped applicators with some WD40 ( or similar) Clean the drive screw ( long brass screw from small motor) with the same stuff. Put a small quantity of lithium grease on the rails and drive screw.
Use some isopropyl alcohol to "VERY" lightly clean the lens surface of the optics.
Put it back the way you found it.
Posted on Feb 02, 2008
  • Scott Frye
    Scott Frye Feb 05, 2008
    Is the post that moves the disk brake still intact?
    It's on the underside of the lid towards the rear.
  • 4,102 Answers
Hi this is the commonist fault on all ps2 and even ps3 their is no way of repairing the laser itself the only option you have is to replace the laser unit the problem with doing this is that if you buy a new laser you will need to get it calibrated and to do this you will need oscilscope and these cost about £300 or if in us about $600 so thats the problem of buying new ones its often cheaper to buy new ps2 than go down that route.
The other option is buying second hand ps2 of an auction site but the problem with this also is that it might have same problem as yours.
What i did that made mine work for few months extra was to use ask.com and type in :Disk read error on ps2
or try this How to repair ps2 disk error or just try repairing ps2
On doing this i came across a site but i cant remember what it was called but this site showed you step by step instruction on how to adjust the laser slightly so that it played games again after following these instructions mine worked again for about three months.
It basically told you to remove the case off the ps2 then where the laser is its like a black plate but you cant see the laser remove this black case i think their was about two little black screw on the top of the black lid covering the laser it covers the disk so you cant see the disk with case removed.
Anyway remove this black lid then if you look at the back of the laser tray not at front where the game goes in but towards the back their is a white disk about the size of a coin now this site told me to first mark with marker the white disk so you know where you started from put line on the white disk then on something else but not the disk so you know where it was located before you turn it doing this lets you go back to how it was before you moved it.
After doing this if you turn the disk slightly it raises and lowers the laser lense now you need to do this a bit at a time and then but the black lid back on with screws then try a game in it you can hold the black lid ontop of the laser unit if you want but dont push to hard and dont hold it to soft else game wont spin properly.
Just turn this white disk a bit at a time then try loading a game keep doing this you can turn it either way if your lucky you might find that adjusting the laser hight might get it working again if not then the laser needs replacing but remember if it dont work then you need to turn the whit disk back to where it started from ie where you marked because if you replace the laser this white disk needs to be back where it was originally.
If you are going to do this search the net first you should find the complete instructions on doing this ok also make sure you dont shine the laser in your eyes or other peoples eyes as its dangerous and can blind you in the future so make sure the case is on the laser before its switched on.
If you cant find the site let me know and ill have a look for you ok also let me know if you need further assistance
Posted on Feb 01, 2008
Disk read error
The reason your play station 2 keeps reading disc error is either because the lens is weak, dirty, or the disk is not compatible with the console.
You can try to use a lens cleaner to clean the lens or totally replace the lens with a new one.
You can also try other disc to see if its the same thing it will show.
Take care
Oct 09, 2010 | Sony PlayStation 2 (PS2) Console
Disc read error
its either a dirty lens inside the drive or a dirty disk. start with trying a lens cleaner.
Jun 12, 2008 | Sony PlayStation 2 (PS2) Console
My playstation 2 makes a weird clicky sound when I try to play some of my dvds or games and sometimes it comes up with disk error or unable to read disk and its a brand new disk
Your PS2 lens is displaced from its original position that is what scratching your Discs and makes weird noises too.There can possibly be another reason for them ,your PS2's reading lens is dirty and it is covered by a layer of dust that scratches your Discs and makes sounds too.
You should first clean the lens of your PS2 watch this video to know how to clean your PS2's lens:
Disk read errors are mainly due to dirty or worn out lens,so clean your PS2's lens to get rid of this problem and as for that sound that will get fixed by cleaning lens if still it makes that sound then you will have to take your PS2 to repairer to set the lens height.
Thank you!
Nov 30, 2009 | Sony PlayStation 2 (PS2) Console
Can u put a lens clearner in a ps2
Yes you can as the lens reading the disks or cds are just the same with the other cdroms.
It is also advisable that if after using a lens cleaner and your ps2 still cannot read, you can clean the lens inside with a soft cotton bud damped in an alcohol.
Sep 10, 2009 | Sony PlayStation 2 (PS2) Console
My PS2 wont read any disk.
HI, the optics assembly has failed. the actual optical lens assembly will need to be replace in this case. you can try to clean the lens with a cleaning disk.. this may wake the laser. if the cleaning doesn't produce results, replacing the optical lens assembly will be the next move.
Jul 21, 2009 | Sony PlayStation 2 Slimline Console
PS2 won't read disk sometimes
I've helped someone else with a similar problem here: http://www.fixya.com/support/t1300166-playstation_2_console_keeps_freezing
It's not enough to use a disk to clean the laser lens. You have to take the PS2 apart and clean the lens manually. Nicotine, Incense, diffusers, and other smokes and just time itself clouds the lens. Not only that but the part that the disk sits and spins on needs to be cleaned over time as well to assure the disk is in proper alignment and Is not just kinda spinning on the spindle.
In that link i posted above you be led to directions on how to take apart your PS2 and what parts to clean. The instructions I have posted in that tutorial is for the (FAT) PS2 model not SLIMLINE. If you have a slimline model you don't have to take apart anything just open your cover and clean the parts in the video.
Hope that helps,
9x|
Nov 30, 2008 | Sony PlayStation 2 (PS2) Console
Unable to read disc
just clean the lens or contact shopkeeper
Nov 04, 2008 | Sony PlayStation 2 Slimline Console
Ps2- disk cannot be read is it just scratched?
hello try cleaning disc and lense..if disc has scratches .ones that go straight across disc are not to bad but if they follow disc in a circle ,lens will follow scratch as it is reading.when cleaning disc use a cleaner as any thing else will scratch..also try another game to see if your lens is okay .they can fail for no reason.
Mar 03, 2008 | Sony PlayStation 2 (PS2) Console
Disk reading error
Hi Tyrell,
What kind of disc is it? The PS2 can sometimes have a dirty lens and not read discs. It does not matter if the Disc is new and unscratched.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. REmove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. REmove the little white disc from the Cd tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
133 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
