Question about RCA DRC8335
Unit won't open compact disc door
My unit will not eject a DVD and will not play it. The disc is brand new, so I would like to get it out of this piece of junk. Display has been reading "open" for several days now, but it is not doing anything. I have tried cutting the power and plugging it in again to allow it to recycle through its' start-up program, but that has not helped.
Any ideas will be appreciated.
Also... any suggestions of another brand to purchase. I still want to transfer some VHS to DVD, but I think I can do this through my computer, so I'm just looking for a multi-format DVD player/recorder.
Thanks!
  • 4,102 Answers
Hi your problem sounds like the flap has come off the runners or become jammed if you remove the case by undoing all the screws if you cant get to the dvd with the case off then plug it in and it will open as the flap will be conected to the case the screws should be located down either side might be 2 or 3 screws running down either side towards the bottom also on the back their might be a couple of screws also but look first in case their isnt you should see the screww going through the outer casing.
Once you have removed all the screws then the case will either lift off by pulling upwards or some of them will slide off if it dont lift off the hold the case either side and pull the case towards you from the front not the back it should slide of forwards let me know how you get on ok or if you need further assistance
Posted on Feb 01, 2008
6ya staff
SOURCE:
2004 Ford F150 rear entertainment system will not eject dvd, will play the dvd and will run when eject button pushed but will not eject the dvd any ideas on how to get the unit to eject the dvd?
The unit is connected by small set of gears that push tray /disc out. As tray comes out it either pushes disc out of slot or pops open door (depending on which style of face you have). If you have kids I would not be surprised if something is caught in between disc and face or jamming edge of door. (know this from own experience). The face of player can usually be carefully popped off by gently prying at corners. If you get face off you may be able to see if something is stuck in unit that does not belong, or see if a piece is broken loose near face. If unit has door that opens you can try using a slim but stiff piece of plastic and keep tension on door with plastic while hitting eject button. On some units there is a small hole on face that is manual release that ejects disc - even if no power. Usually takes a long straight push in hole (straightened paper clip or dental pick) and it manually pushes gear set to go out. So many of these units are different but most do have a manual release. Check owners manual to see if it shows a picture of face and possible release hole. Have had kids fight over changing a disc and pushed in on it while it was ejecting so it stripped gears, and had kid hang on ceiling mount unit that tore screen totally off. I feel your pain....
Jan 21, 2015 | 2004 Ford F150
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
Will not read disc or eject disc
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
REGION 2 DVDS ON REGION 1 PLAYER
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
Enjoy
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
DVD door won't open
It's likely the drive belt that controls the sledge the disc goes on has perished or fallen off. It should just need replacing.
Jan 07, 2018 | Samsung DVD-V1000 DVD Player/VCR
Won't eject DVD
I was able to fix this problem by disconnecting the Bose power cord from the back of the unit. When I reconnected it the door functioned again. Cleaning the disc helped avoid further lock ups.
Apr 02, 2008 | Bose (321GS) System
Disc removal
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Feb 03, 2008 | LG LDA511 DVD Player
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Dvd
does it act like or sound like it wants to open? This could be a small belt drive that is broken or slipping and not letting the door open. Also theres a cam inside thats driven by a belt or worm gear that if that dosent turn then the disc clamper wont raise up and let the door open or you could have a problem with the motor drive circuit that controls the tray motor and last but not least does the eject button feel like its making contact with the little swith inside or is it a flat feeling as maybe the switch could be broken or out of alighnment with the eject switch? Anywho if you unplug the unit it woulnd hurt for you to open the unit to check the belts worm gear or eject switch but if your not handy andy then I would seek a pro for assistance. Good Luck
May 25, 2006 | RCA DRC108N DVD Player
RCA DRC8335 Logo
56 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
