Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Ballast problem on PT-40LC12
I have a 2002 model PT-40LC12 Panasonic projection LCD set. The other night, I stopped getting a picture, I thought the lamp was burned out, but then the next night it came back on, although the picture was dimmer. Then last night, again, nothing. I've already gone through one lamp, the first one lasted about 3.5 years. But I don't think it's the lamp.
I talked with Panasonic tech support and the person said my Ballast control is probably shot or going. He indicated that the first gen HDTV sets only last about 5 years anyways and suggested I replace it. I'm not going to do that just yet- If it is the Ballast control, can it be fixed? Is it worth it?
  • free11 May 13, 2008
    Hi. I've just encountered the same problem, but I just replaced a new lamp a couple months ago and then whamo...my ballast went. Hate to part with such an $$$ tv (at the time). Wish we could at least sell the good parts or something... KILLS ME!!!
  • mikeygstl Nov 06, 2008
    Same exact thing here - I tried the ballast repair kit with no joy. Even tested the components as they came off and went on - they all tested out the same.
    Good news is that the kit provided parts all are correct for the PT40LC12 - the bad part is that the problem still exists. I wonder - the black box on the igh voltage lamp leads - is it a relay, and could the contacts burn out over time?
    Problem Solver:
  • 16 Answers
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Posted on May 22, 2008
  • 19 Answers
Panasonic makes a Ballast Repair Kit LSUC0022 for the PT-50LC13 for around $20, to correct the same problem with that model.
I wonder if Panasonic has a Ballast Repair kit for the PT-40LC12, or if the LSUC0022 would work with the PT-40LC12?
Anyone know?
Posted on Jul 23, 2008
  • xeliam Aug 09, 2008
    Panasonic Ballast Repair Kit LSUC0022 can maybe be used on the Panasonic PT-40LC12 and PT-45LC12 TVs. Seehttp://www.avsforum.com/avs-vb/showthrea...
IT CAN BE FIXED YET NOT CHEAP. MINE WENT COMPLEATLY OUT YOU CAN BUY A NEW TV FOR WHAT IT WILL TAKE TO REPLACE YOUR BOARD
Posted on Apr 08, 2008
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
Okay, so my Panasonic PT-43LC14 went black in mid show last night. The bulb is approximately 18 months old. The LED indicators upon Power On are; Power LED blinks green for approximately 70 seconds; Then...
Check the bulb again and look at the root of where the main stem comes out inside and be sure you don't see any bubble like appearence around the stem at the bottom there. If you do see this then the bulb is bad. Otherwise try this: Hold volume down on front of unit and pip on remote for about 5 seconds. Message will come on screen that timer has been reset to zero. This sets the lamp timer to 0
May 17, 2011 | Panasonic PT-43LC14 43" Rear Projection...
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
My Panasonic LCD had a little pop sound and we completely lost our picture. I just bought a new lamp TY-LA1000 and I turn on the TV and the switch color goes from flashing Green to flashing yellow 2 blinks...
You probably need a new ballast.It is a high failure part.If you listen at the back of the set you can hear the ballast make a short buzzing noise every time it tries to light the lamp.If you don't hear this then your ballast is probably bad.
Dec 07, 2009 | Panasonic PT-52LCX65 44" HDTV
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reset Time Problem on Panasonic TV (PT-50LC13)
Power on the set, listen for afaint buzzing sound as the set tries to fire up. If you do not here it then your lamp driver, or ballast is most likely faulty. Also make sure you have the door and all covers back in place and secure. And make sure you insatlled an orginal panasonic lamp because some generic will not work.
Jan 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13
It could be the ballast that is bad. A bad ballast also shortens the Lamp life .
Jun 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
1,592 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
