Question about Canon MP610 Photo All-In-One Printer
Coping from Canon MP610
Hi, quick question. It says I can copy 31 ppm mono, using this printer. Can you tell me if there is a quick way to feed the paper into the printer to copy instead of having to scan each sheet at a time as it is very slow doing it this way.
Regards Barry.
  • 30 Answers
Unfortunately this model does not have document feeder on top. So you can only do it one sheet at a time. I think the 31ppm indicates that you can print 31 copies of one document in one minute. The models above this tend to have document feeders for this purpose but not the mp610.
Good luck.
Please rate my advice, good or bad.
Posted on Feb 04, 2008
Canon ic-1320 toner rubs off copies
if toner rubs off then fuser unit is not heating paper to fuse toner to paper. You may notice paper printed on is not hot .
Jul 14, 2016 | Canon imageCLASS D1320 Laser Multifunction...
How to print envelopes
Please specify your machine's model
Mar 20, 2015 | Canon imageCLASS MF8280CW Laser...
How do i get my mg6350 to work with ubuntu 14.04
if it doesn't work you may be able to use ndis wrapper
Jan 03, 2015 | Canon PIXMA MG6350 Inkjet Multifunction...
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
I have changed my toner, and keeps on sending misfeed of paper, and now it states SERVICE CALL SC650 ???
You need to call Rich, and tell them what service call you get. They will tell you exact, what to expect. If you can solve the problem yourself, they will tell you, but most likely they will tel you you need a service technician.
Oct 20, 2014 | RICOH CORPORATION Ricoh Aficio SP C242SF -...
Why does my HP OfficeJet L7780 print blank copy with the regular copy
This is normally caused by a driver issue. Check that your device driver is correct for this particular machine.
Oct 19, 2014 | HP Officejet Pro L7780 All-in-One -...
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
Will not print in color
You can find answers to your Xerox questions at
If the machine will copy in color it should print in color.
After verifying that it will copy in color, verify your driver is capable of being switched from black and white to color. If there are no color settings then you have the wrong driver. The link above will take you to the support page where you can download new drivers.
Mar 26, 2013 | XEROX MULTIFUNCTIONS Xerox Phaser...
Lost instructions. What cartridges does printer
Here is the manual for your printer with instructions:
Here is the full spec info on your printer.
Print Resolution:
4800x1200 dpi best mode - Photo paper
2400x1200 dpi best mode - All other media
Print Speed:
mono draft mode 22 ppm
color draft mode 15 ppm
Copy Speed:
color draft mode 14 ppm
Fax Speed:
33.6 Kbps
Cartridge Compatibility:
  • Black: Moderate Yield – 32
  • Black: Standard Yield – 34
  • Color: Moderate Yield – 33
  • Color: Standard Yield – 35
  • Photo: Standard Yield – 31
USB only
Media Handling:
Paper: Up to 150 sheets (20 lb or 75 g/m2 bond)
  • Envelopes: 15 envelopes
  • Labels: 35 sheets
  • Transparencies: 75 transparencies
  • Hagaki: 45 cards
  • Card stock: 35 sheets
Size & Weight:
490.8mm x 422.7mm x 305.4mm (W x D x H)
Scan Resolution:
  • Optical: 1200ppi
  • Interpolated: 19,200 x 19,200
Jan 08, 2010 | Lexmark X7170 All-In-One InkJet Printer
Canon MP610 Photo All-In-One Printer Logo
59 people viewed this question
old marine
old marine
