my screen has a 4' black band down the left side of the picture. the picture is offcenter. it also cuts off ther bottom. its not in zoom mode, i have run manual and auto convergence. the black band also has a sightly curve arch running vertically thru 50% of the band. otherwise the picture is very good.
I have a 1997 GE Projection Television 46" model 46GW945 and it will work fine for about a...
(More)
I have a 1997 GE Projection Television 46" model 46GW945 and it will work fine for about a month and then it will go blank and make a popping sound in the speakers . I can unplug it for about a week and then plug it back in and it will work fine, So what could it be? please help.
Proscan model 61000 - green color is not aimed correctly - it is too far to the right when looking...
(More)
Proscan model 61000 - green color is not aimed correctly - it is too far to the right when looking at the tv screen -- I opened the back cover and I can see the color projectors -- how can I get the middle green one back into alignment -- the auto focus did not fix it
Power light flashes - no picture - unplugging doesn't resolve it. Any had the power supply problem...
(More)
Power light flashes - no picture - unplugging doesn't resolve it. Any had the power supply problem fixed? What is cost?
I am having an issue when I connect my Sony Grand Wega to the Monitor Out port on my new Denon AVR...
(More)
I am having an issue when I connect my Sony Grand Wega to the Monitor Out port on my new Denon AVR 2310 via a DVI to HDMI cable. I get a picture however I receive no audio through my speakers via my receiver. My PS3 is telling me that the HDMI audio is not supported. I have seen that there is some discussion that the EDID returned from the TV to the receiver is the cause of this problem and it appears the DVI to HDMI cable is the culprit. Other TV's connect via the DVI to HDMI cable to the Denon with no issue. Is there any setting on the TV I can do to fix this issue? Otherwise I have to return this Denon. Thanks
