Question about Canon ZR300 Mini DV Digital Camcorder
It won't record anything properly,and is making a wierd sound.
It is having tape problems. It will reconize a tape is in it, and seemingly record. But when i rewind to view what I have just recorded the footage is erased. It also makes a humming sound like a reving motorcycle but in a humming tone. I think the two are connected because I noticed the sound the same time as the recording stoped workinging properly.
Maybe something is loose. Maybe you can try the "Fonzie Fix" below which is actually for problems with the tape compartment not closing all the way when a tape is inserted. I know it sounds silly but it's worth a try.
ericemartin
Rank:nonexpert_s.gif Apprentice
Rating: 100%, 1 votes
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
Posted on May 28, 2008
6ya staff
SOURCE:
I have an old Sony CCD TR55E Handycam, I bought from new. Now I want to transfer my tapes to DVD, and seem to have lost sound output playing tapes to TV/Recorder. Tried running tape cleaner, no succes
What is your signal path? The question you need to answer is, "Where are you losing the audio?" Are you losing it between the tape and the playback head, or are you losing it in the cable, or are you losing it at the TV/Recorder?
Does the camera have an audio out into which you can plug ear buds to test the audio from the camera playback?
Nov 28, 2014 | Sony Cameras
Tip
How a VCR and Videotape Work and the Most Common Problems
A common complaint about videotape is that over time, playback becomes unstable and often deteriorates to the point that the tape becomes unplayable or that the tape works on one VCR, but not another. All of these problems can be traced to tape path alignment in the VCR and damage to the tape itself. I will address each issue separately.
First you need to understand a little about the tape media. When you record on VHS videotape, the recorder lays down three (four for stereo sound) magnetic tracks on the ½ inch wide tape. Analog audio is recorded along the top edge as a thin horizontal stripe (or parallel stripes for stereo) for the entire length of the recording. In the center of the tape, video is recorded as diagonal parallel stripes by two or four heads that rotate on a drum at 360 RPM. On the bottom edge (the most vulnerable place for damage to occur) there is another horizontal track that is critical to playback. It is the sync track and it's purpose is provide the VCR with the feedback it requires to maintain the tape speed within extremely tight parameters. If the tape does not move at a precise speed, the picture and sound can become unstable to the point that it will be unusable.
As you record, a fixed frequency sine wave is recorded on the sync track. If during recording, the tape speed increases or decreases, it will be reflected on the sync track. During playback, the VCR's circuitry senses the small millisecond-to-millisecond speed fluctuations of the tape movement over the heads and adjusts the speed so the tape speed always matches the speed at which it was recorded. If the sync track is ever damaged, your tape can become useless.
Unfortunately, videotape is a very delicate media. It is easily damaged and once damaged, it usually cannot be repaired. The most common failure is due to tape stretch. Videotape is not very elastic. Anything more then slight tension during use can stretch the tape to the point that it cannot rebound. If the sync track is stretched, the recorded frequency will change and the VCR will react accordingly by making incorrect speed corrections resulting in picture and sound disruptions. Your recorder has tensioning arms that control tape tension as it moves through the system. If the tension in the tape path is incorrectly adjusted, the tape will be damaged as it is recorded or played.
Improper storage is the other common cause of edge damage. If you lay your cassettes flat for prolonged periods, the weight of the tape above will press against the sync track and can damage it. Always store your tapes vertically. Extremes in temperature and humidity can cause stretch. Store tapes in a cool dry place. Also, periodically restack your tapes. To restack a tape, put it in your recorder and fast-forward it to the end and back to the beginning. That will redistribute the tension on the tape. After playing a tape, always restack it once or twice. I have a large collection; over 1,000 tapes. I cannot restack them all on a regular basis. But when I play them, I take that as an opportunity to restack them.
Now that you understand some basics about the media, I will now turn you attention to your VCR. As I hope you are starting to understand, proper playback requires precise alignment of many moving elements. The two broad categories are tape path alignment and head alignment. None of this is a do it yourself job. In addition to specialized electronic test equipment, VCR alignment requires specialized tools along with expensive custom made for the brand and model alignment jigs along with (again expensive) alignment tapes. The alignment tape is important beyond the obvious. In order for a tape recorded on one machine to play properly on another, the two machines must have matching alignment. VCR manufacturers record their own alignment tapes using precisely and frequently aligned recorders. The tapes are used to align a specified number of VCRs and then discarded because each time a tape is used it wares. Since there is a uniform standard for these tapes, a tape recorded on one brand of VCR should play on another. That is the theory.
Now for the real world; the consistent interchangeability we all wish for is hard to maintain. Consider this. The tolerances that must be maintained at every point in all of the processes relative to VCRs and tapes are very close to what is possible; little room for slight variations. Since the tolerance for one part of the process may accumulate with another part of the process either mathematically positively or negatively, it is often the case that each individual part of the chain is within tolerance, but the sum total is out of tolerance.
What in plane language does this all mean? Two alignment tapes made on the same machine will be different. Tapes from different manufactures will be different. The tape you local technician or factory service center uses will have inconsistencies. The net effect is that two seemingly properly aligned machines may not be able to properly play each other's tapes.
I do not mean to suggest that you should not have your VCR properly aligned and maintained by a professional. My point is that videotape is an old technology with flaws that could not fully be overcome in the time frame that it would have been profitable for manufacturers to do so. That is why we have moved on to digital technologies. My advice is to enjoy your videotapes while you can. They will not last forever. If you have important tapes, transfer them to digital media to protect your memories as soon as possible.
on Jul 03, 2015 | Televison & Video
Won't turn over... just makes a clicking sound... and a wierd humming sound.
Try cleaning your terminals at the battery, even if not corroded. In my years as an alarm/radio installer I have come across this problem constantly, especially on GM vehicles.
Jun 21, 2012 | 1995 GMC Sonoma
My Panasonic pv-gs180 doesn't record.
If you have Head Cleaning Cassette play it at 10 seconds or use new Cassette for 10 minutes play or record. Otherwise Video Head damage
Mar 10, 2010 | Panasonic PV-GS180 Mini DV Digital...
Cannot play my recorded films
if the camera is not showing recently recorded clips then the problem is fith the recording system, but if you are not able to view the old recorded tapes the there may the simple defect of head getting dirty. a head cleaning tape would solve the problem
Feb 12, 2008 | Canon ZR300 Mini DV Digital Camcorder
DRC 8335 Playing Back VCR Recordings in a Fast Forward State
I bought mine yesterday and am having the same issues. No solution listed in the user manual to fix this and I have a rather extensive VHS tape library that I was hoping to move to DVD using this unit. Unable to watch any VHS tapes taped on my Panasonic VCR and it seems as if the tape is slipping. Tracking buttons don't fix anything. I found a blank spot at the end of the tape and taped something and it comes out fine. Could this have something to do with it being a 6 head VCR? Tapes are in SLP mode.
Jan 08, 2008 | RCA DRC8335
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
Tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Aug 05, 2007 | Maxell 109069 Audio Cassette (Type 1)...
Sony MHC-RV888D - TAPE Recording to Laptop as mp3
on laptop, ensure the following: 1. go to Volume control (look for icon on system tray). 2. under Options tab select Properties. 3. under Adjust volume for recording option, ensure that microphone is is check-boxed if no luck, borrow a second amp and connect your L/R jacks (red and white colour) to the borrowed amps line in jacks and test whether you hear anything to confirm your line out capability.
May 27, 2007 | Sony MHC-RV888D Shelf System
Canon ZR300 Mini DV Digital Camcorder Logo
53 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
