Question about Polaroid FLM-3734B 37 in. LCD HDTV
Black squares or rectangles over picture
I have a new Phillips Mag HDTV. Every day or two small black squares will appear over the picture. Now sometimes two/thirds of the picture will be covered. You can still see the pic through the black. It goes away when you turn the tv off and back on. Sometimes it will come right back, other times it won't. I use Direct TV, but with Tivo I can tell it's not the satellite signal.
  • Anonymous Oct 19, 2008
    It's the television, not the cable. It will go away, if I press any menu, and return when the menu is gone. Aggravating!
  • Anonymous Mar 18, 2014
    pitcure show when i 1st turn it on but a black square cover most of the pitcure,
It's the closed captioning. The reason it doesn't go away when you press the "caption" button is because there are four option for closed captioning: Text 1, Text 2, Text 3, and Text 4. The fifth option, which has no designation, is the "off" option. Using the remote, just click on the "caption button until the option has no designation.
Mine was a large black rectangle in the middle of the picture. It's not like Nina3's problem.
Posted on Oct 19, 2008
Small black box in upper left corner of Sony TV - need to remove
I had a similar problem on my Toshiba Regza but trying my fix couldn't hurt. I use a satellite dish for TV (if you do the same this might work)... I turned off my receiver, took the programming card out, cleaned it with my shirt (especially the part that looks like a computer chip), put it back in the receiver, turned it back on and when everything reinitialized the black rectangle was gone.
Hope this helps.
Apr 11, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Vizio VX37L HDTV black rectangle in lower right corner
Turn off or modify CLOSED CAPTIONING settings
Jan 24, 2010 | Vizio VX37L Television
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Jun 03, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Vizio 42" LCD - Random appearance of small black rectangles
There is a processing fault that is starting to occure. What you are seeing is a type of aliasing. This can be in the main signal processing or in one of the control areas.
The set will require service. The service rep will test the set by using board substitution. There are typicaly a number of areas in the TV set that can cause this type of fault. Once the defective board is located the fault will be easy to service with a simple board swap and some adjustments.
If the set is out of warranty, it may be expensive to service. With many of the no-name brands, spare parts can be difficult or impossible to have.
Jerry G.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
I have a Phillips Magnavox Model number 42PF9936D/37. A red pixel looking 2" X 7" rectangle has appeared on the plasma screen and can be seen underneath the image. How can I fix this?
We chatted previously, remember to reseat the cables that go to the section of the screen that is distorted. The Y drive boards will be on the left side of the tv (when viewed from back) and there will be about 8 ribbon cables hooking these board to the plasma panel. If you can, look at each square black chip on the board. Each chip drives the picture (row - horizontally) so one chip may be blown causing your issue. It will likely have a small pin sized hole burned in it if bad. You can replace the corresponding board (upper y, lower y) to fix the issue. Hopefully reseating the cables will do it, for a part free fix. Let me know when you get the TV open and I'll assist more. Thanks again!
Dec 09, 2008 | Televison & Video
Mitsubishi 1995 cs31205 32 inch tv
Good Day;
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
Oct 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Black square on tv screen
Turn off your closed caption...
Bill
Mar 20, 2008 | Televison & Video
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Polaroid FLM-3734B 37 in. LCD HDTV Logo
163 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
