Question about Dynasty DGRSC 30 Gas Kitchen Range
Oven often takes half hour to heat up
When oven turned on, ignitor glows but no gas flows for 5 minutes or so. Then it ignites, only stays lit for a minute or so then gas cycles off while the ignitor stays on. A minute or so later the GAS flows and the cycle repeats.
  • JimSaline Feb 02, 2008
    I checked the jet is perfectly clear. Maybe I should have mentioned before that when you turn the oven on, there is no noise of gas flow what-so-ever, until four or five minutes then the gas turns on. It runs perfect fine for a minute or two then quickly shuts off. Like it is getting a false signal from the thermostat. Last night I used the oven and it took 35 minutes to reach 325 degrees because of this cycling on and off. When it is on the gas runs full bore. Also occassionally during the cycling on and off I would hear a muffled boom, which makes me think gas is pooling then igniting.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
It is the problem with your gas supply jet.
well the jet could be blocked
check the gas jet and open it with a pin or needle
Posted on Feb 01, 2008
  • Anonymous Feb 03, 2008
    well it doesnt look like the problem is with the thermostat.
    well check for the highest and lowest temprature the behaviour is the same then no problem with the thermostat
6ya staff
SOURCE:
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
When trying to light my oven, it take more than 5 times igniting it for the oven to work, I do keep the door open and have to watch to see if the flame comes on. Sometimes the flame comes on, but doesn't...
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 06, 2010 | Bertazzoni X30 4 GGV X Gas Kitchen Range
Kenmore 362.75507001 Oven ignitor comes on but gas will not reliably flow in the burner. Had earlier moved all connectors on the upper panel, then gas flowed fine, oven came up[ to temp and seemed to be...
heatman101
Sep 06, 2010 | Kenmore Kitchen Ranges
Igniter will heat up (glow), and oven may or may not light for 5 minutes (with igniter glowing). After heating, and stabilizing...once the oven starts to cool, igniter will glow again, and may or may not...
The stove should not take over 3 minutes to light. Even if the ignitor is glowing it is impossible to really tell if it is ok or not. When the ignitor heats up it's resistance drops, this allows for the amp draw to get to 3.2 amps or better and that opens the bi-metal inside the oven valve. The oven circuit consists of a control to regulate temp, a safety valve, a ignitor, and a burner. Any open component and the oven will not fire off. If all the components have continuity and the ignitor is glowing, but no joy, I would replace the ignitor. Usually the ignitor gets dim when it is weak and it takes a long time to light off and you might even have to bump the stove and get it to come on. Replace that ignitor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 02, 2010 | Ovens
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
Lights once then not again
Hot Surface ('Glow Bar') Ignition System glow-amin.60x20.gif (most common)
This is the most popular system currently in use and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve. What happens in this style control system is that the thermostat or electronic control supplies power to the oven ignitor and gas valve which are connected in series (one after the other). As power flows through the ignitor it heats and allows a specific amount of current to flow to the oven valve which is in the same circuit. If the oven valve senses the proper current flow, it opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Thermostat seems ok, but gas won't flow from oven burner.
Hi, Even tho the ignitor is glowing, it is getting weak and will need replaced. The ignitor is not pulling enough amps to open the gas valve.
This is very common problem with the gas ovens.
If I can assist you further, please let me know.
Vic
May 29, 2009 | Garland H283 Gas Kitchen Range
Oven won't heat up at all.
broiler on top of oven?? if so it might have a second ignitor that is working. Most units now with gas have an electric ignitor to start gas ovens. What they do is send electric current through an electric "wire", when enough current is flowing through wire to open gas valve the wire is hot enough to ignite the gas flowing over it. When you turn on the oven look at the burner and after 1 imute or so you should be able to see an Orange glow in bottom of oven if not I'm sure its the ignitor, if glows then probably oven valve is bad. I'd guess ignitor because most oven makers use this ignitor to mantain a warming temp (around 100 degree's) so since your display doesnt register over inital "start" temp of 75, i'd bet ingitor not coming on at all
May 21, 2009 | Kitchen Ranges
Dynasty DGRSC 30 Gas Kitchen Range Logo
216 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
