Hp deskjet 6988dt bottom paper tray
I have a hp deskjet 6988dt mypaper tray the one that holds 250 sheets has 2 black clips and 2 springs that have came out of the bottom of tray/ How do I hook these parts back on the tray?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Usually every clips has a certain way to sit on it's place, and it's can't be explained well enough through text, but you can try to learn it's way, by observing few important things:
- Is it reachable enough (visible & holdable)
Don't force it if it's not reachable, perhaps you have to open some screw first, and you've got to be careful
- Is there any broken mark on the clips or on the printer, coz if it is, then you have to fix it first, or get a new one
- Try to learn to put the clip back on it's place without the spring first, coz it will be more difficult, then after you got the idea, try using the spring.
Good luck :)
Posted on Feb 02, 2008
My printer will not print. The status says out of paper, but there is paper loaded in the bottom
Printers with photo tray have a nominal input tray capacity of 10 mm, or 100 sheets of plain paper. If the tray is loaded above its normal capacity, the printers will not pick up paper.
Aug 22, 2011 | HP DeskJet 950c InkJet Printer
Can I print envelopes on my Bizhub 250
BYPASS TRAY is sed when printing onto paper with a size not loaded into a paper tray or onto thick paper, overhead projector transparencies, postcards, envelopes or label sheets Can be loaded with up to 150 sheets of plain paper, 50 overhead projector transparencies, postcards, label sheets or sheets of thick paper, or 10 envelopes referred to as the "bypass tray" throughout the manual. (See page 2-60....ATTACHED )
ftp://207.18.56.26/software/BPG/Userbizhub200250350CopyOperPh2_5.pdf
Feb 15, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
Paper tray doesn't raise on my brothers hl5250dn printer. Says papertray empty
I have had the same exact problem; make absolutely sure that the exit chute is seating properly. With the exit chute open (as if to clear a paper jam) actuate the white spring loaded clips that hold the exit chute, mine were not traveling to their full extension and by moving them a few times this resolved and the exit chute was held more firmly and the rollers spin the right direction.
Jan 30, 2011 | Brother Lower Paper Tray Feeder / Tray for...
Hp9300 not feeding thick paper
Based on the Media weight for a HP Deskjet 9300
The Main Tray can support up to 36 lb bond.
The Manual Tray in the Back can support up to 70 lb bond via a single sheet.
You must check the weight of the thick paper you are using to make sure your using the correct weight.
Oct 15, 2010 | HP DeskJet 9300 InkJet Printer
Duplex paper jam . i thought i took out the paper that was jammed and i am still getting that message, PLUS now I cannot the top tray back.
The duplexer, which flips the paper to automatically print on the back side, slides into the back of your printer. Unplug the printer and slide the duplexer out to check it for jammed sheets. You might have pulled out a sheet or two in the main printer section and left one in the duplexer.
As for the top tray, the paper feed wheels ride on the end of a long lever that drops down to rest on the paper. It should be held up out of the way by a spring until the drawer is inserted, but sometimes the plastic nub that the spring pulls on breaks off. Lexmark sells a little kit of the spring and "bellcrank" to fix it. If your paper tray holds 500 sheets - a whole **** - you need part no. 56P1331 "Parts packet, bellcrank and spring, 500 sheet." For 250-sheet trays the part number is 56P1337. A web search for either part number will find you a seller.
Sep 20, 2010 | Lexmark T632 Laser Printer
HP deskjet 3845 will not feed paper to print. Is the green light suppose to blink? Not sure where paper needs to go to get proper feed
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Jul 12, 2010 | HP Deskjet 3845 InkJet Printer
What is the maximum paper weight allowable for the HP LaserJet 2840 printer? I am printing recipe cards but 4x6 or 3x5 cards are too heavy and the printer won't take them.
Handle a variety of business needs. Spend less time loading
paper with an input capacity of up to 375 sheets. A 125-sheet
multipurpose tray and a 250-sheet paper tray offer easy
access to a variety of paper finishes, sizes, and types,
including labels and envelopes, at weights of up to 47 lb
(177 g/m2) and HP laser glossy and photo papers up to 70 lb
(220 g/m2).1
Jun 08, 2010 | HP LaserJet 2840 All-In-One Printer
Hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
Jun 18, 2009 | HP DeskJet 5652 InkJet Printer
Missing Tool box software for HP Deskjet 690C
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=58156&lang=en& Check the paper feed area for loose debris or a stuck piece of paper. Good Luck, Tim
Feb 10, 2007 | HP DeskJet 690c InkJet Printer
Error
1. Verify the following: * There is sufficient paper in the paper tray (at least ten sheets). * The paper tray is not overly full. * The paper stack is touching the back of the paper tray. 2. Slide the paper guides so they fit firmly against the edges of the paper. 3. Press the Resume button to continue printing. good luck :-)
Jan 11, 2006 | HP DeskJet 5652 InkJet Printer
132 people viewed this question
k24674
jasbo
jasbo
