Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Hotpoint aquarius dwf31
How do I get to the heating element- got error code 2H appearing.
I s it an element or is there anything else I can do??
  • Anonymous Jun 26, 2008
    have a dwf 32 with 2h dont no if is element the best way is to take the hole unit of the bace than you can pop out the element out the holder
2 Suggested Answers
SOURCE: Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Posted on Jan 12, 2010
MODEL DWF31 START PROGRAMME DISPLAY SHOWS 2H AND STAYS ON 2H ANY IDEAS
Hello. First, try to reset the control board. There are 2 buttons with arrows underneath. Press and hold them both for several seconds, maybe a little longer--this will perform a reset on the control board. See if that clears up the problem. Also, are there any lights blinking? Dishwashers will flash error codes(in binary format) by blinking certain lights in a pattern(i.e. The "sensing" light will blink 2 or 3 times, then the "cycle complete" light will blink 2-3-4 times--something like that) It could be any combination of lights depending on the component that has failed or has a problem. Components can be the drain pump, main wash motor, float switch(if present), heater circuit, inlet water valve, flood switch(if present), etc...
Sep 26, 2015 | Hotpoint Dishwashers
I have a Hotpoint Aquarius FDW 60 dishwasher. Crockery was with greasy smear on it. Since then the drying does not appear to be working. Seems the drying element has malfunctioned, can we replace this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Hotpoint Dishwashers
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
F-08 error message on Hotpoint Washing machine WT761? The original fault on the machine was that it was tripping out and taking out a resetable fuse in my fuse box a few seconds after turning the machine...
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Oct 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Not working right
Hi
Thanks for using FixYa. E14 error code means water heating error has occurred and failed heating element.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Dishwasher Hotpoint 7885 Aquarius Ultra Plus
sounds like the heater for sure. engineer job.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint ultima 1200 Wm72 Erroe E14
I think you will find that the error relates to the heating element.
E14 on the Hotpoint WM75E means that there is a problem with the water heating.
Jun 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Jan 03, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
199 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
