Question about Cambridge Soundworks Seventeen Speaker
4 speakers with games
Hi I have two front, two rear speakers and a sub, they all work fine for music and movies, but when I go to play games, only the front works.
Any help would be greatly appreciated
    Scholar:
  • 103 Answers
For the rear surround speakers to work, the sound must be encoded in surround sound, and most games, if any, are not. The amp doesn't 'see' and information encoded in the sound signal for the rear speakers, therefore you get no sound.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Posted on Feb 05, 2008
6ya staff
SOURCE:
Subwoofer
I'm not familiar with your unit. However, this is normal, since the "sub" is encoded separately in movies. I have a separate sub for my front speakers. Or if you know what you're doing you can redirect the front signal to your sub by using a switcher when you're listening to cds, then switch back to surround when watching movies. But again, you have to be experienced in the principle of A/V configuration.
Mar 26, 2014 | Denon AVR-788
BH7520TW cordless rear speakers not working
if you having this problem when playing music, this is perfectly normal 'cos music only gets played through 2 speakers (2.0 audio format)..if this happens when playing a movie, you have to check if the movie (through the disc menu) is in 5.1 audio format which is surround sound through all the speakers..
Feb 10, 2013 | LG Audio Players & Recorders
Harmon kardon avr-520 keeps turning itself off
I have a avr 520 and had put it away for about 6 months to reno the theater room when it was done I hooked it all back up and it started to shut down. Not when the radio was on but when I was playing a blue ray movie after reading all the pages of info there was on this subject I went home and disconnected the speakers and sub and then played the movie with no sound for 30 minutes. Then hooked up one rear at a time let that run for 20 minutes each then the other rear. Restarted movie moved to sub then right front center then left front and it went off. Unhooked left speaker and it ran fine. ran new speaker wire to left front and it ran fine ran 2 full movies through it. The speaker wire I use is not cheap either 12 gauge 99 percent oxygen free wire. Somewhere in the reno it was snagged or pinched and was grounding out causing the unit to overheat and turn the unit off. Thanks everyone for their input that info help a lot. hopefully these helps someone
Dec 17, 2012 | Yamaha Audio Players & Recorders
Hi! I have purchased a JAMO S608 HCS 3 and a SUB 650 using an OKYO TX-SR508 Receiver. I can't set it up correctly. When I played music I've heard a lot of bass, I think there are some high...
The TX has speaker setup and test tones for setting the balance and distance with test tones and proving the hardware works. If that all works the difference is probably external or settings.
What is different between the music source(s) audio and the HD movie source(s) audio? Ask yourself, how would a sub make high frequencies go missing? It can't.
Your other speakers are responsible for conveying the high frequencies.
Sep 08, 2011 | Jamo SUB-650 Subwoofer
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
Hiya i have recently moved my computer from the front room to a bedroom and plug everything in, i thought everything was fine until i tried to play some music so i checked all the connections/leads and...
Hi try looking over it again with the help of this https://www.download.p4c.philips.com/files/s/spa7300_79/spa7300_79_dfu_eng.pdf just make sure all connections are pushed in properly as those plugs have a tendency to not plug in all the way
May 04, 2017 | Philips SPA7300 2 Speakers
Rear Speakers dont work
THe rear speakers are usually for the surround sound experience. What kind of movies do you watch? Usually the action movies have a lot of surround sound, calm movies not so much. And for the music, the same thing applies. Atleast for my system.
Hope this helps.
May 09, 2009 | Televison & Video
Rear surround sound speakers not working during movie.
Look on your manual, page E16. Go into your speaker setup. Select your speakers (Front,C,Surround, Sub) and make sure each are selected as "small" (make sure you go through each one). If the surrounds are selected as "none" the rear will not activate and will light up as red on the display. Let me know if this helps.
May 02, 2009 | Koss KS3102 System
Surround speakers work in test mode but won't come on during play
Check that you set it to Pro logic and check the speaker set-up. Set it to 5.1 Sounds like somthing is in the wrong setting.
Dec 22, 2008 | Yamaha HTR-5830 Receiver
No sounds from rear speakers..... Yamaha HTR-5650
Select different modes on the remote or front panel and make sure all speaker that you have hooked up are showing on display. Are the Lt & Rt channels at least playing audio? If you want, i can step you thur some steps to try in live chat if you want today. Let me know as i have experience in this area! Sincerely Guru Jay
Jan 03, 2008 | Yamaha HTR-5650 Receiver
Cambridge Soundworks Seventeen Speaker Logo
94 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Ekse
Marvin
Marvin
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
