Question about Samsung Digimax 4010 Digital Camera
Formatting Memory Card
My camera says that I need to format my memory card when I turn it on, but regardless of whether I say yes or I say no, it says there is a card error. How do I fix this?
  • Ken Anderton Mar 31, 2008
    Just got my daughter's Digimax 4010 put in a new card and get "card error"
    I don't have a manual to format the card
  • 47 Answers
Did you format your card? try going into the set-up menu on your camera and you should find a format option - THIS WILL ERASE ANYTHING YOU MAY HAVE HAD ON THE CARD...so if you have anything on there use a memory card reader and transfer it to your computer before formatting. If the formatting doesn't fix the card error message you could try formatting it on your computer (if you have a pc, go to 'my computer' and under 'removable devices' you should see the memory card, right click and choose format - i don't know the process for macs, but i would guess do a ctrl+click on the memory card when it appears on the desktop). If that still doesn't work the card is probably corrupt and you may need a new one.
Posted on Feb 01, 2008
2 Suggested Answers
SOURCE: camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
Posted on Oct 25, 2009
When I turn on my camera it says "Format Formatting the memory will delete all data (images/voicefiles) yes no" What does this mean?
You are getting this because you have inserted a new memory card or a memory card which was used on a different device into your camera.
In order for your camera to use this card, it needs to format it. In this process the camera makes changes to the card's data storing structure to suit the camera.
If the memory card doesn't contain any data you need, answer yes.
Apr 28, 2011 | Samsung TL100 Digital Camera
When I put the memory card in and turn on the camera, it keeps saying memory card error.
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 03, 2010 | Canon Power-shot S1 IS Lens Converter
When i turn the camera on it says memory ard error
Mar 01, 2010 | Optics
Put new memory card in camera but has formatting problem. When memory card is put in it says the new memory card requires formatting. When I continue it states that formatting will delete everything in...
New batteries first!! Make sure they are "GOOD"
May have a bad or incompatible card.
Will you camera take pictures without a card in it?
If yes, you have a bad or incompatible card.
Try another card
Here is all the information you'll need to solve this:
Read it.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=8814&product=EKN031714
Dec 24, 2009 | Kodak EasyShare Z612 Digital Camera
V530 camera continue to ask formatting needed.
Navigate to the 'Format' section of the menu then try each option ('Yes' 'No') separately---checking the advisories between each trial.
Crat
Oct 25, 2009 | Kodak EasyShare V530 Digital Camera
My Z740 won't format my memory card. When I turn
My Z740 won't format my memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message.
Aug 15, 2009 | Kodak EasyShare Z740 Digital Camera
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
When i turn the camera on....it saids memory card requires formatting. then continues to say formatting will delete everything on memory card. i press continue and nothing happens. goes back to say memory...
Use a computer with memory card reader, and read the card using a computer.
If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
If you need to use the camera tonight, then buy a spare memory card.
If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
Regards
Jun 18, 2009 | Kodak EasyShare C875 Digital Camera
Formatting memory card
A new SD card shall be firstly formatted before use.
a.) Select (Format) to enter into property list.
b.) Select “NO” to cancel the formatting. Select “YES” and press (OK) to execute the
formatting.
c.) All the contents in the memory will be cleared after formatting.
About Memory Card
The external card supported by this camera is SD card.
To use a new SD card, you have to format it firstly.
Maloperation may cause damage to or deletion of the data recorded.
The loss arising from deletion of recorded data will not be the manufacturer's
responsibility.
Electrical interference, static electricity and failure of video camera or memory card
might damage the data in the card. Therefore, it is suggested to transfer the data to
your computer timely.
Never take out the memory card or turn off the video camera when reading or writing
the data.
Never put the card under high temperature or high humidity.
Never modify or tear down it.
Cheers.
Dec 03, 2007 | Mustek DV520T Digital Camera
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Samsung Digimax 4010 Digital Camera Logo
211 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
