Question about Mitsubishi WD-52628 52" Projection HDTV
Shut Down Message
My TV works properly most of the time, however, it turns off after the following message is displayed in yellow at the bottom of the screen "TV will shut down in a few seconds. Please check the airflow..." This has been happening off and on for the last year. Right now, as soon as I turn the TV on, the sign is displayed. Therefore I am getting no TV at all. When it shuts down an amber light on the front of the panel turns on. But sometimes it will work fine for months.
I had just read something about this problem at the Mitsubishi Site.
Go to, then Support, then Warrenties, now look for "IF YOU HAVE ONE OF THE FOLLOWING MODELS CHECK HERE". The first one is addressing this problem on specific models. Hopefully you have one of these models.....
Hope this helps
Posted on Mar 01, 2008
  • 4,402 Answers
The repair is to have the DLP engine replaced!!
FYI: The engine also can cause the set to shut down without any display or might even tell you the lamp door is open when it is not.
Posted on Feb 01, 2008
System can't fix restart problem itself
Found this on the GT website:
  1. When Gran Turismo 6 is launched while connected to PSN, a message will appear on screen informing the users that "the latest update data for this software has been found (Version 1.03)".
  2. Once accepted (by pressing the X button while selecting [OK]), a "Please wait..." message will be displayed. After a few seconds, the PlayStation 3 system will emit 3 acoustic signals and restarts automatically.
  3. At this point, some users may receive a message stating that the system was not shut down correctly last time. The system will ask then to perform a system file check and then the reboot is completed.
  4. Users will be prompted again to download Update 1.03, whether they received the message in step 3 or not.
To avoid this issue:
  1. To avoid this issue, please accept to download the Update by selecting [OK] within 2 seconds of its appearance on screen when prompted. This will update the game properly.
  2. If you wait longer than 2 seconds, please decline the Update by pressing the Circle button when the message in step 1 is displayed, then select [Back] in the subsequent "Sign-In to PSN" screen. The game will start, quit the game using the PS button while in the [My Home] screen and follow the procedure described above.
This requires fast fingers and is a "work around" solution only but should fix your issue!
Jan 19, 2014 | Sony Playstation 3 (PS3) Console
Windows has recovred from an unexpected shut down
This message was displayed only because the last time system wasnt shut down properly don't worry and continue to work
Mar 03, 2013 | Dell OptiPlex 780 MT Desktop Computer...
No signal on vizio smart tv from RCA portable DVD player using composite cable
First try another composite cable. Those "in box" ones go bad all of the time. Hook up to another tv or with another style of cable (such as S video) and verify that all is truly working first. If these steps don't work message again.
Jan 20, 2013 | Televison & Video
We have a wd 57732 a solid yellow light on when turn tv on message air flow block shut down in few seconds shuts off with two green lights flashing and solid yellow acks as if room temp to warm. sometimes...
The lamp needs to be replaced. It's on the back and easy to do. I replaced mine about 3 months ago and it was about $182.00. Hope this works, I know it's hard to fork out that kind of money at this time but once you do the TV will be as good as new. Take care
Jun 09, 2011 | Mitsubishi WD-57732 Projection Television
A message flashes at the bottom of the screen
tv is overheating.  possible that fan not working or temperature protection circuit faulty.  check fan for excessive dirt first.  could be as simple as cleaning the fan
Jul 29, 2010 | Mitsubishi WD-57731 57" Projection HDTV
DVI warnings when you connect HDMI cables
Sep 22, 2009 | LG 32LH20 32 in. LCD HDTV
52' DLP Mitsubishi HD T.V. gets an error message on the bottom of the screen ''T.V. will shut down. Check that air flow is not blocked'' T.V. is in the open and air flow is not blocked. There is also a...
most rear projectors will turn themselves off whenever the lamp is dead. what we call protective mode. in this case the yellow light may be for the lamp. otherwise check if all the fan are working properly.
But MAKE SURE you let sufficient time for the tv to cool off before unplugging the main.
hope this helps
please rate me!
Mar 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Mitsubishi WD-52628 52" Projection HDTV Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
