Question about Cyberhome DVR 1600 DVD Recorder
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
I attached the DVR 1600 to the AV2 of the TV and the audio/video output on the DVR 1600 and I can play DVDs, put I can't record from the TV or the ATT uverse recorder. How to I connect and set up the DVR 1600 to record?
  • 1 more comment
  • Anonymous Mar 30, 2008
    cannot connect dvr to tv with satellite cable
  • Anonymous May 24, 2009
    I have a Sony Bravia 48 in LCD TV with Motorolla dvr receiver from Charter Cable. I wish to record the movies that I have saved from my DVR onto DVD. How do I do this? I also have another DVD Player that is hooked up to the TV as well just to play movies. I would like to have both hooked up. I also want to record live movies as well from my cable service to my dvr.
  • Anonymous May 11, 2010
    I am not setting it up with satallite but with regular cable. Also, I do not understand what scarts are. Thanks in advance.
Use 2 scart leads from av1 and av2 of the dvd via a spliter .
With the out put from spliter pluged into tv.
(DVR 1600 output is 1/2 of a scart socket and the input is
the other 1/2).
ps:- no auto switching on o/p or i/p!
Posted on Jun 09, 2008
    Problem Solver:
  • 6 Answers
Has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Posted on Apr 08, 2008
6ya staff
SOURCE:
Why does the DVR 1600 play some DVD's and not other DVD's
It does not play all DVDs because that is how it was program just like play stations the only option i think is worth it is to change the lens
Apr 11, 2010 | Cyberhome DVR 1600 DVD Recorder
I have a 8 mm camera connected to the front inputs I have the Insignia plugged in and av2 mode i have a dvdr in the machine I simply hit the record button and nothing happens? I just want to plug my camera...
can't do it that way. you'll need to plug it in to the tv, play it on the tv, and the video output from the tv to the dvd player. make sure you have the correct format of the dvds for that player. some formats of dvds does not work for certain dvd recorders.
let me know what other issues you have
Oct 18, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
How to connect dvd recorder to tv????help
if youre going to be recording programs from the TV , it cant be , normally TV s have A/V
inputs and NOT outputs , the only way is to connect it thru a VCR A/V outputs , hope it helps , AJ
Jul 12, 2009 | Cyberhome DVR 1600 DVD Recorder
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
Can't record from tv to dvd
I think you would have to run your sat line through the DVR-1600 first (Line In) then connect directly from the DVR to one of your TV Line-Ins (Audio R, Audio-L, S-Cable Video).
And then use the Cyberhome TV Tuner to record off your sat.
Jan 24, 2009 | Cyberhome DVR 1600 DVD Recorder
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Cannot timer record with Insignia HD TV and LG DVR/VCR
Make sure when you do the process two things: one, a blank tape or If it is a dvd recorder, a blank disk is inserted, in the tape make sure the tab that prevents recording is not broken.Two, before exit the timer recording menu, make sure that there is not a instruction that says "done" or "confirm" or any word meaning that all the steps went through.
Nov 20, 2008 | Insignia IS-LCDTV32 32 in. Television
PioneerDVR-225 recorder
A lot of the functionality you are wanting is tied to the remote that you have misplaced. You can go to the Pioneer support site and order a new remote, though it is like $30.
As for wiring options to record, it depends on the inputs and outputs that are available on your television.
- Ideally, connect VCR to TV input "1", connect DVR output to TV input "2", and conect TV output to DVR. This will help you avoid any copy protection issues you run into, but not all TV sets have both audio and video output.
- If you don't have TV outputs, connect VCR out to DVR in, and then DVR out to TV in. This will definitely work, but you will have to have the DVR turned on to watch a VCR tape.
Nov 24, 2007 | Pioneer DVR-225 DVD Recorder
Recording from vhs to dvd with a dvr
You can get a standard audio/video cable from any Radio Shack or audio equipment store. It will most likely come as a single 3-part cable with a yellow (video), white (audio left), and red (audio right) set of connectors on each end. Most equipment that's not too old will have matching color-coded sockets marked input/output. Simply plug the video/audio cable into the vcr output and the other end into the dvr input. then connect a second cord from the vcr output to the tv input. Then with everything turned you will be seeing the final signal on the tv and you can start the dvr when you are ready to start recording.
Nov 22, 2007 | Cyberhome DVR 1600 DVD Recorder
No video Output
Try changing video cords and if u are using vcr as i am try selecting diffrnt channe on the unit that may help u solve or ay not juss update your posts if it worked (the vid I am reffering to video,audio plugs red white and yellow it worked out for me if it is dealing with when recording make sure proper video selection as well as audio
Aug 06, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVR 1600 DVD Recorder Logo
541 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
