Question about Sharp Actius A250 Notebook
Hard drive i need a replacement hard drive for my sharp pc250 wich ones will work
    Sergeant:
    Champion:
  • 244 Answers
Open your machine, check if the hdd is SATA of PATA (with pin). From here you can buy hdd that supported by your machine
Posted on Feb 02, 2008
6ya staff
SOURCE:
Pls can change my hard disk? with any other hard dist
Probably any hard drive of appropriate capacity (large enough), has the correct electrical interface (SATA or IDE), and is physically the correct size will work.
5.November.2015
Sep 01, 2015 | Sharp Computers & Internet
Replace hard disk
IT HAD BEEN MUCH MOORE EASY IF YOU WROTE WICH KIND
OF DESK-TOP.AND BRAND.
Apr 11, 2015 | Computers & Internet
Computer can no longer show my Imation hard drive. When I plug the External hard drive in, it says that the device is found but cannot show contents.
Your harddisk drive is bad. The external drive enclosure is still working and still sending a signal to your computer, but it is not reading the harddrive disk. There is nothing you can do to fix this, unless you replace the hard disk itself. For the data content that is stored in this damage disk, you can recover the files by sending it to bestbuy or office depot where they will have to send it off to a recovery company where it will cause you couple of bills large. Before so, you can try to take the harddisk inside the external harddrive enclosure and test it with a desktop computer via the sata cable connections. If you still get nothing, then yes it is a 110% your hard disk drive is damaged.
Jan 30, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Every time you turn it on it gives an error about the device in the modular bay, if you press escape to continue it says no boot devices, but if you reboot by pressing ctrl, alt + del it boots fine...
I need more info, can you get into the bios? Then there is a sellection bootoptions, sellect the hard drive put it as first bootdevice. You might have a empty bios battery so the bios can remember wich settings to use. I surgest replacing that battery anyway.
If its an older model laptop you can try hitting f8 f9 at the start, it will give you a bootmenu sellect the hard drive.
Still i need more info, wich type of pc or laptop!
Jan 21, 2018 | Dell Latitude 110L Notebook
I want a converter for Hitachi HTS541612J9SA00 120 GB SATA Hard Drive to usb do you know wich one I need..?
You need a 2.5" inch SATA to USB external harddrive enclosure.
since its a laptop hard drive you need a small case.
for example this one http://www.amazon.com/2-5-SATA-HDD-Enclosure-Black/dp/B0018TCB0O
Aug 07, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Does not recognize hard drive
hi
thank you for using fixyz
chack your HDD cable wich conacted with your motherboard may it's not working or replace that then try
still there is prob then may you HDD is not working
May 13, 2010 | Dell Dimension 8250 PC Desktop
PS3 Formating 500GB Internal Hard Drive?
hi, you should be able to do it with just windows once you connect the drive. but i dont think the ps3 can support 500gb
Apr 24, 2009 | Sony Playstation 3 (PS3) Console
Additional hard drive instalation.
Did you check the boot sequence?
Just make sure that the HDD wich is set to boot from is the same wich is containing the OS.
Nov 26, 2008 | HP Pavilion a1610n PC Desktop
Hdd bad sectore problim
bad sectors are not fixable as far as hard drives go.
you mmight find software that claims ti fix bad sectors but the claim is false as they only temporarily overwrite the sectors and unmark the bad and remark to good but the problem remains to be the sectors are bad.
The best thing to do is to replace the hard drive with a good used one or a new one.
Sorry but as a technician I know what bad sectors are and what happens when you get them.
Jan 22, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Hard Drive Crash - how do I disassemble my PCMP-30 to replace it?
You will get a better response if you pay for the expertise we have to offer!
Oct 24, 2007 | Sharp ACTIUS EFF/1.6 512MB 40GB (PCMP30)...
Sharp Actius A250 Notebook Logo
103 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ekse
Siul Oyaratgam
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
