Question about Philips 19MF337B/27 19 in. LCD Television
Vertical height adjustment on Magnavox 19 inch LCD HDTV
I have a new Magnavox model 19MF337B. All images are too tall, even watching HDTV. How can I adjust the vertical height?
  • Anonymous Mar 14, 2014
    Timed recording doesn't work even after setting the time and speed. what can be wrong? It is the 2nd Magnavox that does this to me.
    Scholar:
  • 70 Answers
What you're looking for is what is called an "option byte" code,as to how to get to it,im not sure,but you could look around online and try to find it.
Posted on Jun 10, 2009
  • 30 Answers
Try to adjust at the vertical section.hope this will help
Posted on Feb 02, 2008
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
Adjust vertical height kg 55lh55
To adjust the height of the picture, you have to enter its service mode option, and should adjust the vertical amplitude data value, accordingly. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 24, 2014 | LG 55LH55 55 in. HDTV LCD TV
Top of screen disappeared...cant see score of game
The Height adjustment is off... look in the back of the TV set, it has some knobs in the back, one should be vert.lin for Vertical Linearity adjustment, and there is another call Vert.Hgt. for Vertical Height adjustment. try adjusting the Vertical Height first with someone watching in the front of the big TV to see if the top comes back into view, you might have to adjust the knob very slowly one way then the other way, to make this adjustment. If it doesnot adjust take it to a TV shop to get it repaired.
Good Luck.
Nov 11, 2010 | Hitachi 57F500 57" Rear Projection...
Magnavox 19mf337b/27 will turn off and back on with loud noise through the speakers until it warms up. approx 30 to 40 min. What is the part causing this common problem?
Check the 2200uF capacitors for bulging. You can get the schematic here to really toybleshoot: http://www.electronica-pt.com/index.php/component/option,com_remository/Itemid,34/func,download/id,15048/chk,6022df47696641c1c064cb27f2bd7d11/no_html,1/
May 20, 2010 | SNK Magnavox 19MF338B/27 19 in. LCD TV
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
TALL PICTURE
On most TV units, there would be two (2) adjustments that affects your concern:
  • vertical Linearity (VLin); and
  • Vertical Height (VHt)
However, newer designs no longer have these adjustments since they are automatically done by the circuitry. If for some reason height is incorrect in such a system, then chances are that there is a leaky/defective capacitor in the vertical section.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 24, 2008 | Televison & Video
New Magnavox 19" LCD HDTV
need model number and you should also post under tv not projections.
Feb 01, 2008 | Televison & Video
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Philips 19MF337B/27 19 in. LCD Television Logo
436 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
