Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Crisper door/water line freeze problem
Everything in the left crisper door freezes, and line that you can draw a cup of water from is also froze up. Other crisper (on right) is fine!
  • Anonymous Feb 28, 2008
    Similar problem, My water dispenser is frozen most of the time. Freezer temp is set to minus3F and fridge to 40F. Veggies are not freezing in either bin.
  • 833 Answers
Mar...you're box is set too cold. Use -17 C/38 F on the freezer side which is about 38F/4C on the fridge side. Use an outdoor thermometer and let it sit closed for at least a few hours. Adjust accordingly and this will work out. One adjustment is often the cold vents from the freezer into the fridge. If set too wide, too much cold air gets into the crisper and water lines.
Posted on Feb 01, 2008
Why is everything in the crisper drawers freezing?
Crisper draws are at bottom of fridge, cold air collects at the bottom and warmer air rises. Turn thermostat dial down, mine is set on 2 out of 6 and every thing stays fresh and doesn't freeze. In very hot weather I do sometimes turn it up to 3.
Dec 03, 2016 | Refrigerators
Water in veg crisper freezing
You have a white cover in the back of your fridge it says twin cool on it. Behind that cover is a drain for your defrost cover that is probably frozen and water is leaking through that cover. Wrap a piece of copper wire around the heater and fish it down the drain and it
will fix the problem
May 09, 2014 | Samsung RF265AA Bottom Freezer French Door...
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Can I take the freezer door apart and wrap the water line with more insolation
No, you can't. The line goes into the mold of the machine with no access there.You have either an air leak in the dispenser area, around the ice shoot possibly, or the resevoir, which is located on the refrigerator side in the lower area behind the drawers is freezing, which is most likely the case. There are vents on the lower section for the crisper drawers. If you take out the drawers you'll find a roll of 1/4 " tubing which they call a resevoir that cools the water down. This is probably frozen,and you can insulate this, but I would raise the temperature in the fridge side or close the vents to the crisper area.
May 08, 2012 | Whirlpool ED2FHEXN Side by Side...
I have an ED2KHAXVS02 model and the ice maker works but no water out of the refrigerator. Any Ideals on how to fix the problem
Could be a bad water valve or the reservoir has froze. do you have things freezing in the crisper drawers?. If so try turning the temp down a little. The reservoir is behind the crispers.
Mar 21, 2011 | Whirlpool GS6NBEXR Side by Side...
The food in the refrigerator drawers (crisper and meat) are freezing and the waterline froze. What is causing this and is it worth repairing?
I have Ge GSS25XSQA SS side by side and the food in the refrigerator drawers (crisper and meat) are freezing. Also the ice dispenser is frozen closed. The water dispenser still works.
Want can I do to fix it. Would dirty coils have anything to do with this?
Terry
Nov 10, 2010 | GE GSS25SGPSS Side by Side Refrigerator
Freezing in left crisper drawer.
If you have had a DOE upgrade the fix is availiable from LG
Here is the service buliten # CREF20090877.
Contact LG @ 1 800 243-0000 for repair.
In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
Jan 19, 2010 | LG LFX25960 Bottom Freezer French Door...
Water in the crisper drawers, condensation line clogged
if condensation stays in there, it'll freeze up on the evaporator coils. when the defrost cycle goes on, it'll melt but stay in the fridge, only to eventually freeze up again. so, unclog that line. also, check your door seals for leaks. that may be where the warm, moist air is getting in.
Dec 04, 2009 | Admiral Refrigerators
Water despenser is apparently frozen
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Aug 14, 2008 | Amana AFD2535DES French Door Refrigerator
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
403 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
