Dell Inspiron 9100 Notebook Logo
Posted on Jan 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Received I received "7327 MB disk 0 at ID 0 on bus 0 on atapi setup cannot access this disk" message at WindowsXP SP2 Gold setup. Windows setup could not be continued.
Steve Sweetleaf
Level 3:
  • Dell Master 1,212 Answers
  • Posted on Jan 03, 2010
Steve Sweetleaf
Dell Master
Level 3:
Answers
1212
Questions
5
Helped
433647
Points
3475
Bad sectors on the hard drive.possible bad hard drive. run the xp cd and hit R when asked what you want to do r R is for repair and it should fix the sectors.
Anonymous
Level 2:
Sergeant:
  • Expert 218 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
218
Questions
0
Helped
58278
Points
641
Try deleting all the partitions and perform the complete format instead of the quick format. Maybe this will help you.
Problem setting up windows XP
D to Delete all the partitions on the drive to get all the space into one big contiguous space. Then try installing.
Setting up windows XP on Systemax venture computer says set up can not access this disk
If you installing a new windows you should first delete all partititons and then create one and install windows on that. Remeber all data on your harddisk gonna get deleted. So press d to delete and then c, then enter on the new partition
Only 7554 MB on a 320 GB western digital harddrive
you need to performe check dsk command on ur hard drive
1helpful
PXE-E61 media test failure on Acer Aspire 5050 laptop
Yes, your analysis of the problem is correct. The problem could be with the hardware & while you are trying to reinstall the Windows OS, the software checks on all hardwares before installing. The best solution would be to take your system to a nearest service provider & get the problem rectified. Once the problem is rectified by them, try to reinstall the OS along with them, so that if there is any other problem apart from the above they will be able to help you.
5helpful
3answers
No Display in ASRock 775i45GV Motherboard
Try cleaning the RAM as shown in the image below:
also you can try resetting the CMOS, here's how it's done on your motherboard:
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes system
setup information such as system password, date, time, and system setup parameters. To
clear and reset the system parameters to default setup, please turn off the computer and
unplug the power cord, then use a jumper cap to short the pins on CLRCMOS0 for 3
seconds. Please remember to remove the jumper cap after clearing the CMOS.
The location of the CLRCMOS0 on the motherboard can be seen on the image below. (labeled no.10)
If problems persist. Replace the RAM. Hope this helps.
I have a compaq presario sr1103wm and it won't load windows. i turn it on and it goes to screen saying windows wasn't shut down properly and lists the options: start in safe mode, with networking, with...
re install or repormat your system to fix all problem will return into normal operation... but before that dont forget to save your data if you have important data dont'want to loss it..
if can't open the program or operating system remove your Hdd then insert into another computer to back up the data ot be sure that you have back up all important data. except those programs cant make back up... you need to re install again from the source..
Computer will not boot.
Form the info you provided, you have a RAID (Redundant Array of Independent Disks) disk array. RAID 0 (striped disks) distributes data across several disks in a way that gives improved speed and full capacity, but all data on all disks will be lost if any one disk fails. Apparently Diagnostics has determined that “Drive 2” is defective. You will have to replace the defective hard drive and reload the Windows operating system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Load os
There is a problem with the hardrive,on your computer. Have you got any Hardderive diagnostics cd given acer to you ?
Kindly contact Acer support if the system is still under warranty.
Thanks
proton
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
