Question about Dell Inspiron 2600 Notebook
Black screen on start up
When i switch it on i get the dell emblem for like two seconds then the screen goes black. i can se the desktop icons VERY VERY faintly but it is unusable. can this be fixed at home or do i have to pay big bucks to get it sorted out ?
    Genius:
  • 1,067 Answers
Big bucks lol bad mobo usally the video is on the mobo so it would all hav eto be repleced or power resiters re solider in wich is tuff best sell it for parts on ebay get 200 or so toward new oen
Posted on Feb 01, 2008
My 1905FP Dell monitor powers up and the screen is normal for about 3 - 5 seconds and then goes black. Turn it off and then on and the screen goes thru the same routine as many times as you want to turn...
si al encenderlo dura unos cuantos segundos encendido y luego se apaga
revisa los condensadores en la fuente del alto voltage casi siempre se inchan y no dan el voltage correcto tambien podria ser una de las lamparas se quema el cable negativo de la lampara que es el mas delgado donde solda con ella.
Aug 16, 2011 | Dell UltraSharp 1905FP LCD Monitor
When my computer boots up sometimes the screen is ok, but more often the screen fades and goes black. If I switch the monitor off and then on again the screen shows the icons etc for about 2 seconds and...
This could be that the screen topback light or bottom back light is bad or the inverter.
the topback or bottom back light could also be seing as the flouricent of the screen that light up the screen to enable display visible.This top back light or botom back light as the name implies is positioned at the top and bottom side of the screen.It takes an expertize knowledge for one to be able to change the flouricent when comfirms bad.The same is applicable with Inverter.
Jan 06, 2011 | Proview PL913S 19" Flat Panel LCD Monitor
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
DELL 800 TRIES TO BOOT
To enable those icons and more, right click on your desktop and choose Properties. Click on the Desktop tab and hit the Customize Desktop button. Next, under the General tab, check off any of the icons you want to appear on your desktop.
Mar 31, 2009 | Dell Latitude D800 Notebook
Start up problems with Sony Vaio VGN-A517S
remove your screen saver program form computer.go to control panel in settigns u se dispaly open it then set desktop as win xp.
Feb 03, 2009 | Sony VAIO PCV-J200 PC Desktop
Cant get to windows
Is it XP or Vista? I would load the recovery cd and attempt a repair( not an install).
Sep 06, 2008 | Dell Dimension C521 PC Desktop
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Black screen
you restore the pc back when it was working fine,you can do in safe mode
May 30, 2008 | Dell Inspiron 1501 Notebook
Where Dell Flat screen 15" monitor has not been used for a period of time or on boot up the screen displays for a seond then goes black (although in a certain light you can see the icons and programs...
You most likely have a bad connection inside the unit. Specifically, there are a couple of "backlights" that provide the light that will pass thru the LCD panel. If you can open up the unit, with the screen facing up, there should be a small PC board on the right. Check the connections on that board. Be careful as there is high voltage there.
Keep us posted.
Dan
Apr 08, 2008 | Computers & Internet
Dell Inspiron 2600 Notebook Logo
66 people viewed this question
Alun Cox
