Question about Maytag Legacy Series Top Load Washer
MAYTAG LEGACY MODEL # SAV205DAWW
My problem has been the plastic agitator itself - this unit has some sort of a free floating or free agitating agitator that just slips on. Problem is that the agitator floats off and then the clothes do not move very much while in wash cycle. I can only slip the agitator back on - there doesn't seem to be a permenant way of keeping the agitator on the machine ( no bolts, or way of securing it on ). Can anyone help - else I have to throw the whole thing away.
  • frankdes Feb 05, 2008
    I found out that there are two sections to their agitator - the bottom one is bolted on - howver the second ( top agitator part just floats off - since the plastic tips are worn away )
  • Anonymous Sep 16, 2008
    I have been going insane with this exact problem. Thanks for the idea to bend the tabs a little. I'll try it before I order the new part.
I've got the same problem. The diagram is a bit deceiving because it appears to show the agitator/auger as one piece. However, the bolt only holds the agitator (lower portion) and then the auger slips in place over that. The fabric softener cup then snaps to the top of the auger.
Best I can tell is that the slotted 'ears' on top of the agitator are worn thus preventing a secure fit between the agitator and auger. I just finished putting some hard thumb pressure on each of the ears and bent them outward some. The auger fits much tighter now and I'm doing a test run of clothes. It is holding but I will probably have to replace what they describe as the agitator / auger assembly, costs $53.54. I don't see any other fix but would appreciate further input.
Thanks
Posted on Apr 09, 2008
Same problem. I noticed that the upper portion was caked with fabric softener, inside and out. I let it soak in a bucket of very hot water to loosen it up. Then I had to scrub it. The fabric softener residue had become a lubricant and the upper portion just slides right off.
Posted on Aug 19, 2009
There is no bolt that holds the second part (upper portion of the agitator ) in place. It just slides over the bottom agitator part. The upper part has no way of attaching itself to the lower portion - it just slides on
Posted on Feb 02, 2008
  • 240 Answers
There should be a bolt underneith the fabric softener assembly that holds the auger section and agaitator in place. Sending a link with a diagram.
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=3048&modelDesc=WASHER&modelNumber=SAV205DAWW&documentID=M0610186&documentTypeID=PLDM&documentClassCode=PV&titleType=TUBS&titleID=00007&
If you still dont find the bolt (#14 on the diagram), give me a shout back and try to figure out something else. Good Luck!!
What is the position of the belt on a Maytag Legacy SAV205DAWW? On the right or left of the idler pulley?
Sounds like the pump pulley is not in the rotation. Since there's only 2 options if its not working on the way you have it now, it must be the other.
Aug 31, 2014 | Maytag Washing Machines
Maytag Washing Machine Model SAV205DAWW not agitating
The transmission is broken on the inside due to Maytag using plastic gears. Designed to break with age and overloading abuse.
It's a pain to replace and expensive, too. Average repair cost $300. and 2 hours + labor
Feb 07, 2014 | Washing Machines
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Legacy Series Top Load Washer
Agitator doesn't agitate
Hi. your agitator has a drive shaft and a shift link inside that uses plastic gears as well. all this is attached to the drive assembly and transmission clutch assembly. the main issue here is that the clutch and transmission has stripped the agitator kit. you will need to replace or order a new agitator kit and clutch for this unit.
May 21, 2009 | Maytag Washing Machines
HI - We have a Maytag Legacy Series top load washer. When it agitates and spins it sounds like something is trapped underneath the agitator. Is their anyway I can easily remove the agiator and see if there...
Usually nothing will get trapped beneath the agitator. The posibility that something has gotten caught btw the tub and spin basket is higher. Please feel free to subscribe and I'll help you further.
Dec 01, 2008 | Washing Machines
Loose Agitator
Usually, there is a bolt that holds the agitator on. If you remove the cap off the center of the agitator, you should find a bolt underneath that you can tighten back down. Adding a little thread lock to the bolt wont hurt.
Jul 10, 2008 | Maytag PAV2300 Top Load Washer
MAYTAG WASHER SAV205DAWW
i can step you through it in a live chat session
Sep 27, 2007 | Washing Machines
Washing Machines Logo
1,541 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
