Question about Dell Dimension 4600 PC Desktop
Icon i had hit a button and my icon start went to the side of my screen how can i get it back to the bottom of the screen
    Sergeant:
    Champion:
  • 317 Answers
Right click on th taskbar and select lock the taskbar if there is a check next to it. then just click and drag it back to where ever you want it.
Posted on Feb 01, 2008
6ya staff
SOURCE:
I hit the wrong button on the remote, and the tv now saids no signal. How do I get back to the channel the tv was on
hit the source button again that is for your scat press down to 1 HD should get you back on.
Jan 10, 2015 | Televison & Video
Tip
How to get on the internet on psp.
To begin you need a wireless connection at home,school,coffee shop,hotel,etc.
1.On top of psp slim wlan switch to right is on position,on older model switch is near memory slot.
2.Under settings scroll to network settings then hit x
3.Select infrastructure mode then hit x
4.Select new connection then hit x
5.Select scan then hit x
6.Access point should highlight,if more than one
choose best for you then hit x
7.Follow prompt at bottom of screen,choose none if no password or choose
type of protection you have.If you have a password you must enter it by
hitting x then entering manually then hit enter .
8.Choose easy,connection name then hit x to save
9.Test connection hit x
10.Hit o to go back
11.Under network scroll to internet browser hit x
12.If screen says communication with the server failed.A DNS error has occurred(80410413) don't worry hit o
13.Now screen should be blank with arrow, hit top triangle button and address bar with icons at bottom should appear.
14.Use right direction button to move through icons on bottom and use x to select.To go to websites click first icon choose address entry type website
then enter twice
15.Depending on service and speed website should now show in address bar and on screen.
16Hit triangle button to remove bar and icons.
17Enjoy internet with no wires
on Sep 13, 2008 | Sony PlayStation Portable (PSP) Console
Desktop screen
try booting in safe mode and see if the screen displays properly.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the 1 inch black space then your video card might be going bad or you might have a virus infection. If the Borrowed monitor displays ok then your original monitor is bad.
May 29, 2012 | Dell Inspiron 530 Desktop Computer...
My HP compact nc6000 laptop went to Hiberating mode and i don't know how to fix the problem. If i could please get help that would be great. i just got this laptop yesterday. it was working but all of...
Hi Jessica,
Hibernation mode usually turns the computer off but saves any work. Then you would start it back up by hitting the power button, it will boot up and you log in like normal and the computer should be as it was before it went into hibernation.
If you can't get it out of hibernation by pressing the power button, try holding the power button for 5-10 seconds. The laptop may actually still be on, and holding the power button will cut if off. Once the computer is back on you can change the battery options(hibernation/turn off settings) in Windows by going to the bottom right task bar and right clicking on the battery icon. Normally you will have an option like "power saving settings", "battery settings". In this setting window you can turn off hibernation due to inactivity.
Let me know if you have any questions.
Regards,
G33k
Jul 09, 2011 | HP Compaq nc6000 Notebook
HAVE NIKON D40 THE LARGE MONITOR AT BACK OF CAMERA HAS BEEN TURNED OFF SOMEHOW HOW DO I TURN BAK ON????
turn on your camera
press the menu button on the back og the camera
using the switch to the left of the screen, hit the left side once to move the screen cursor to the small icon on the left of the menu screen that looks like a "penci".
now click the button to move the highlight back to the right side then move up or down to select "07" Image Review.
hit the 4 way button on the right side to show the two options, on or off.
move the highlight up or down to select the one you want (assuming you want "on"), then press the center of the 4way button, "OK". now when you shoot a picture it will show up on the back screen until you touch the shutter release button again.
Dec 27, 2010 | Nikon D40x Digital Camera
I accidentally turned on the wireless 5000 mouse magnifier and can't get rid of the magnifier. How do I turn it off?
Normal 0 The button on the left side of the mouse when pressed turns the Magnifier on/off. Just press it again and it should turn off.
I kept turning it on accidentally so I went in the control panel and switched the Magnifier to the right side. I added that below so you can set your mouse buttons.
Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
Feb 17, 2009 | Microsoft Wireless Laser Desktop 4000...
Icons
press the "Display" button. It is the 3 button from the bottom on the right side of the remote.
Jan 19, 2009 | JVC LT42P789 42 in. LCD TV
Enlarged icons and text
The following should get you back to normal:
  1. Click the "Start" button
  2. Click "Control Panel"
  3. Click "Display"
  4. Click the "Settings" tab on the top
  5. Near the bottom is a box that says "Screen Resolution" , to make the stuff on the screen smaller , slide the bar toward the right and hit apply. You may need to slide it over a couple of times to make the display look correct on your screen.
That should fix you right up!
Sep 30, 2008 | HP Compaq Presario V6000T Notebook
Microsoft Mouse Model 1058 - can't undo magnifier!
Hi, I have the same problem. I resolved it. The steps are - 1.Go to control panel 2. click on mouse and it will take you to mouse properties . It will display you the Microsoft mouse 3.Go to "buttons" Tab 4.Change the option in the "small thumb button" box to "click" from "Magnifier"..the default is "Magnifier"..that is why if u accidentally push this button..it opens up an annoying magnifier.. 5. then click apply..It works
Sep 30, 2008 | Microsoft Wireless Laser Desktop 4000...
C340
1. Turn unit off, by pressing and holding button on lower right side for 2 to 6 seconds until it goes off.
2. turn unit on, by pressing and holding same button for 3 to 8 seconds until the warning screen comes on (with the small "agree" box at the bottom of the screen. It may not say "agree" in a language you recognize, but either press it and "agree" or wait for it to go away.
3. next screen to appear should have a small "two ended open ended wrench icon"
4. Press the icon. The next screen will have 6 windows, the lower right will have red lips icon.(it is the "language icon")
5. Press this lower right icon.The next window will have two boxes in the upper right corner. one above the other.
6. Press the upper right box, and then use the up and down arrows to select the language you recognize in the language you want it to operate in.
7 having selected the language of choice, hit "back" as many times as you choose, to get to where you wish to operate...
Good Luck.... GB_C
Jan 02, 2008 | Garmin StreetPilot c340 GPS Receiver
Dell Dimension 4600 PC Desktop Logo
46 people viewed this question
Ekse
Clive
Clive
Alun Cox
