Question about Microsoft Windows XP Home Edition
Adoberdr 7 as soon as it comes it freezes & have to close & start over-------z
    Scholar:
  • 61 Answers
Your virtual memory might not be able to handle the software's demands. the video card too might share the same problem. better use a reader that also requires less disk space. the adobe acrobat reader version 5 may work well, in case you still want to use and adobe software as it only requires 11.5 MB.
another thing, it would be better if you do a little maintenance tasks on your computer. on the control pane, select performance and maintenance. you can defragment for a few times, "pick a task" such as the "free up space on your hard disk", and the "rearrange items in your hard disk to make programs run faster". these simple steps might take a lot of time but will surely lessen the glitches one can have while using the pc especially on important occasions such as reading pdf files.
all the best!
Posted on Feb 04, 2008
  • 56 Answers
I would uninstall that and use FoxIt Reader....much faster. I switched a couple weeks ago, no issues yet. It is a 5MB install compared to adobes 50MB....just to read pdfs.
You can get it here.
Posted on Feb 01, 2008
Inside of icemaker freezing up where ice drops threw door have cleaned it out a few times but it starts freezing again soon.
I am convinced there is supposed to be a seal of some type on the little plastic doot that closes up over teh openindg. MY ice maker has never worked right, it freezes up, the dispenser doesn't work and it leaks.
I'm on a mission to figure this out today.
May 18, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
As soon as i ckick to open it my screen freezes when i close it my taskbar and desktop disappear
I had the same problem before, if you're using laptop build in card reader, try to download the driver first, also try to reformat your windows.. I had these problem in windows vista but now I've changed to windows 7 and these problem solved :)
Mar 05, 2010 | SanDisk 2GB microSD Memory Card
Ice maker tray over flows and clumps ice, water freezes in drain at bottom and water will come out of the front of freezer door. this does not occur all the time just when it gets a hankerin too. could it...
Good day,
The normal operation is for the ice maker to harvest a batch of cubes, and then just before competing it's cycle, to open the valve to add more water for 7 seconds then shut off smartly.
At least 50% of water valve problems cause an overfill problem, because of internal wear etc. that does not let the valve close on time. This causes an overflow problem to the ice maker, and all the problems you described.
It should be corrected as soon as possible, since they have been known to throttle open and never close. Should it be overnight or while away, the damage can become quite serious.
Feb 12, 2010 | Maytag Freezers
I recently had the water pump replaced on my truck and today on my way to work the "Service Engine Soon" light came on. I watched the odometer closely and everything seemed to be fine during the trip to...
very unlikely that those two things are related. if you can stop by an autozone they will scan the codes for free and tell you why the light is on.
Dec 03, 2009 | 1997 Chevrolet S-10 Pickup
Acer aod250-1042 touchpad freeze
just disconnect the battery
its a ACER bug that is haunting all us poor souls who was crazy enough to believe that they would find some pride in making a quality product. No, they just want you to buy a new computer
Oct 18, 2009 | Acer Aspire 5670 Notebook
Freezing Screen
it sounds like a cooling issue, just to verify this it's best to put a standard fan next to the system and see if the system works properly, if it dose then their is insufficient cooling of the internals, best bet is to get a add on fan to keep it cool. they are notorious for failing and causing the ring of death due to overheating. hope this help you.
Aug 20, 2009 | Microsoft Xbox 360 Console
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Dodge stratus R/T 2002 antifreeze problem(antifreeze coming out the cap)
First the "service engine soon" light is a manufacturer installed reminder for you to get an oil change or other pre-determined maintenance service done. It is different than the "check engine" light which indicates a sensor malfunction. Secondly, when the engine is cold the thermostat is closed and the antifreeze or coolant is not circulating. The cooling system is a closed system and the tank that the cap is on is not an overflow tank but rather an expansion tank. This tank allows for the expanding coolant that is now hot to leave the engine coolant jackets, that won't expand, into a tank that can expand slightly. When your engine got to normal operating temp., aka.. hot, the thermostat opened allowing coolant to circulate and fill the expansion tank probably over flowing with the cap off. This is a normal operation for your car.
Oct 05, 2008 | 2002 Dodge Stratus
Freezing up
grr someone better come up with a solution soon mines the same !just let the battery die
Jul 15, 2008 | Creative Labs ZEN V Plus MP3 Player
Microsoft Windows XP Home Edition Logo
90 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
