Question about Dryers
How to fix Hotpoint CTD00 Tumble Dryer?
About 12 months ago my tumble dryer started to blow the power after a few seconds of turning it on. After vacuming it all out, including heating elements it has been fine. However it has started to blow the power again, but now does this the instant I press the on button. I have cleaned it all out again and it did work for a while, but the problem has re-occured and I have had no luck with the previous methods. I have searched this problem and found one answer to say it is the heating element that needs to be replaced. Could someone please tell me me if this is the case, and how easy this is to replace.
  • suzywoozie Jan 18, 2009
    I've had exactly the same problem with my tumble dryer, same make and model. I have followed the advice given by Picton and so far everything is ok again. We found that the little inlet was blocked inside the water reservoir, as he described. We used to clean the bottom filter about once a month (which is what Hotpoint recommended in instructions), and empty the water unit after every use, but now we will clean the bottom filter weekly. It's not easy to clean properly, I've found, as it doesn't come apart.
    Anyway, many thanks for the advice. I have been pleased with the dryer otherwise.
Http://www.fixya.com/support/t232066-hotpoint_ctd00_trips_power
The link above should solve your problem. I have the same problem and my parents who bought the same tumble dryer also had the same problem. Its water backing up to the fan then its hitting the heating element which is tripping the electric off.
At the back of the Tumble dryer near the bottom you'll see a panel that has about 8 screws that you can taqke off as well as a small panel that cover the pivet for the drum. If you unscrew this you will see the fan and heating element and no doubt a small puddle of water and damp dust that has clung onto the panel. You should dry this with kitchen roll and clean the old dust off then carefully turn the tumble dryer on (at your own risk lol) or you can take the advice of the person who posted the link above and use a hair dryer. This will stop the element getting wet and tripping off.
Also there is a water reservoir to the right of the panel i mentioned. If you prise the clips open and remove the top section you will see the water in the reservoir. If you look inside it on the bottom left hand side there is a little **** that the water drains in from. If you use something like pipe cleaners or a knife and wiggle it about you may have some fluff or hair trapped there that is making the water back up to the fan and causing the tumble dryer to trip off.
Hopefully this willsolve your problem for the time being but the filter in the bottom of the dryer needs to be cleaned thoroughly every week or so to stop this happening again.
Personally i think this is a major design flaw and the tumble dryer should be recalled but Hotpoints aftercare service is awful to say the least so lesson learnt, don't buy a hotpoint tumble dryer!
Posted on May 07, 2008
Hotpoint aquarius keeps tripping fuse box and getting too hot at the back
Posted on Mar 09, 2013
Hotpoint tumble dryer CDT00
found the water pump impeller is broken - can I get a spare one or do I have to replace all pump / housing - seems a shame having gone to the trouble to strip it all down - tiny piece of rubber is all I need!!!
Posted on Jan 10, 2013
  • 3 Answers
I would pay the gas bill--that should solve the problem.
Posted on Feb 02, 2008
apart4u
  • 213 Answers
SOURCE: hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Posted on Jan 08, 2010
Testimonial: "yes this problem was the thermostats now fixed thank you"
SOURCE: hotpoint tumble dryer tdl31p
i have a 2nd hand hotpoint aquarius Autodry Model tdl31 tumble drier. I need an instruction manual. Can anyone help with emailing me one?
Posted on Aug 11, 2009
hunter19_46m
  • 7482 Answers
SOURCE: hotpoint tumble dryer CTD00 timer
It is not a difficult job...the thing to keep you out of trouble is to make sure you get the right timer switch, then remove one wire at a time.
Remove one wire from the old timer and put it on the new timer, there is not that many wires for your timer.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Nov 06, 2009
heatman101
  • 43501 Answers
SOURCE: Tumble dryer (Hotpoint TDC62p) No Heat
Here is a tip that explains the troubleshooting2_bing.gif for electric dryers
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Mar 26, 2010
richroth
  • 9472 Answers
SOURCE: how do i get access to the elements at the back of the tumble dryer my hotpoint aquarius ctd00
Sorry, I am not familiar with that model.
Posted on Nov 17, 2011
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
Why is my hotpoint ctd00 condenser dryer leaking water from underneath and turns the electricity off''
you are not on your own we have the same problem we are going to convert back to the old fashion tumble dryer
Dec 23, 2009 | Hotpoint Dryers
Dryer revolves but no heat on any settings . hotpoint aquarius tumble dryer CTD00 7Kg.
fixed using posted advice on resetting thermostat.
Many thanks
Dec 10, 2009 | Hotpoint Dryers
Hotpoint tumble dryer CTD00 timer
Good luck,
I hope this helps
Nov 05, 2009 | Hotpoint Dryers
How do I replace bearing on a CTD00 Hotpoint tumble dryer
front bearing on drum felt bearing the whole front has to be removed from machine .. if felt back bearing same applies .. if the plastic drum bearing guides this can be done by removing side panel .... always disconnect from mains before attempting any repair
Jun 11, 2009 | Hotpoint NWXR473EV Dryer
My hotpoint aquarouis ctd00 tumble dryer is heating but no air is blowing through. also there is no water collecting in the water tray
Check all filters and air vents at front and rear of m/c, to make sure they are all clear., do not overload, make sure you have selected right heat setting, and the correct drying time.
It is not usual to feel air blowing out of dryer, because it is a condenser dryer.
Plz rate my solution.
Thanks.
Dec 27, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Dryers Logo
4,672 people viewed this question
Top Dryers Experts
Marvin
Marvin
