2003 Acura RSX Logo
Posted on Jan 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need stereo unlock code for 2003 Acura RSX. S/N is U4003L5014
K W
Level 3:
Guru:
  • Master 509 Answers
  • Posted on Jan 03, 2010
K W
Master
Level 3:
Guru:
Answers
509
Questions
7
Helped
216029
Points
1369
Here is the website for the codes. Cost is $20.00
http://www.radio-code.com/Acura-Pay-Page-radio-code.htm
1helpful
Stereo code for Acura RSX
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you can provide the necessary information then your ACURA code is available here for free
https://radio-navicode.acura.com/?src=inq
If not then the code will only be available from your local Honda Dealer or a Decoding Service ...who will plug in a laptop to read/recode your memory chip (EEPROM)
How do i enter unlock code in my acura 2002 rsx
if its for radio sometimes dealer will ask for some model no# on your radio and he can give you code to unlock it..sometimes they charge either sometimes you cant win
5helpful
2answers
Acura rsx trunk latch stuck & won't open
I"m having trouble with locking and unlocking my hatch using my remote. I have flipped the white switch in the trunk and it acts as a child safety lock if flipped one direction. However I am not able to open the trunk this way. It acts as a permanent lock. So I figure the switch must be flipped the other direction and need to replace my actuator. Is this hard to do. It looks to me like it two switches holding a bracket to hold the actuator itself after plugging in the actuator from both sides. Is it really this simple?? Is there more to it???
SAR STEREO UNLOCK CODE
open glove box code is on the outside left hand side
4helpful
could be the spring release in the lever on the trunk itself. If you can hear the acuator locking/unlocking(that is all it's ment to do) then the spring release is the problem. you need to unbolt the latch from inside the trunk and once the trunk is open you can trace from there. I had the same problem due to a minor fender bender and I just fixed mine last week.
2003 acura rsx cough sputter
Regarding the heating issue, sounds like your thermostat is stuck open so the coolant isn't heating up. (May need replacement) Does your engine temp guage show it running colder than normal?
2answers
Unlock radio code
look on the side of your glove box on the casing of the glove box compartment and if there is a sticker with i think it is a 4 or 5 digit code press that code in. and it should unlock. if not you can always pull the stereo out and get have the dealership look it up and give you the code. if you have the owners manual they normally put the code in the back pages of the owners manual as well. if you cant find it post another problem i will try to help
B
4answers
Stereo code
check log books or you can get it from the dealership
Top Acura Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Acura Expert? Answer questions, earn points and help others
