Codes for ford escort 99 odb
P1506 p0303 p0171
Ok,
I have a 1999 Ford Escort and the transmission slips out of gear when either going around a corner or slamming on the brakes when going down the freeway.
I took it in to have a checked out and code PO734 came up for GEAR 4 INCORRECT RATIO.
So far looking on the net I have found ideas such as retaining clip or forward clutch control valve. Do you think this may be the case here?
Unfotunately for me where I live nobody knows what they are doing when it comes to tranmission work.
Can someone please tell me what it is I need to do and/or how much this will cost me to either buy the parts and fix myself or take it to the people I do not want to to fix and just hope and pray I get the car back by 2010. Basically what I would really like to know if anybody knows is how serious this code is and what is recommended to fix.
Any help would be much appreciated!
Thank you,
Chad Adams
San Jose Del Cabo Mexico
Posted on Oct 02, 2008
    Champion:
  • 208 Answers
Www.batauto.com top right ecu
Posted on Feb 02, 2008
98 dodge ram 1500 5.9L 2wd codes P0300, P0301, P0302, P0303, P0171. What all do I need to do to resolve??
the p0300--p0301-p0302=p0303 are misfire codes and can mean needs tune up or wiring problem and p0171 is system to lean bank 1 with this code if you correct it will probably correct the misfire codes your receiving
http://www.obd-codes.com/p0171 Fixing Hesitating Car P0171 Code YouTube P0171 System Too Lean Bank 1
Aug 26, 2016 | Dodge Cars & Trucks
P1506, p0171, p0174
is this a ford ? . try cleaning the iac its on the top of the engine and easy to get to .and let me know how it works
Feb 12, 2012 | Cars & Trucks
98 ford escort check engine light is on the code comes up p1506 how do i fix
This code refers to the Idle Air Control Overspeed Error, I would clean the IAC, and if cleaning does not work I would replace it. It is located directly on top of the throttle valve on the intake manifold. Hope this helps, let me know.
Aug 09, 2010 | 1998 Ford Escort
Check engine lights on 99 ford ranger ODB codes 3- need solutions before in shop takes me to the bank help #1- P1506 #2- P1131 #3- P0171 I already know what they mean, got them written down. Need...
DTC P1506 is set when the PCM detects the engine idle speed is greater than the desired rpm. This is most commonly caused by a dirty or bad IAC valve. Cleaning the throttle body will, most likely, cure this problem.
p1131 means that the bank #1 O2 sensor, the bank closest to the firewall, cylinders 1-3 is showing a lean mixture. Could be a vacuum leak, a misfire on that bank, an exaust leak upstream of the O2 sensor, fuel control or injector problem on that bank, a faulty O2 sensor, faulty PCM, faulty wiring in the engine control wiring harness.
P0171
In the vast majority of cases, simply cleaning the MAF sensor does the trick. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling also Inspect all vacuum and PCV hoses, replace if necessaryCheck for a dirty fuel filter and proper fuel pressure
May 19, 2010 | 1999 Ford Ranger SuperCab
P0302 #2 cylinder miss fire code. Replaced plugs and wires but at 40 mph runs very rough. Idles smoothly but not when put in gear.
I have a 1999 ford escort 2.0, its got a miss on cylinder 3 and 4. I changed the wires and the coil pack but its still missing. When scanned I get code p1506, p0303 and p0304
Jan 02, 2010 | 2000 Ford Windstar
P0171 code on 99 Ford Escort ZX2 2.0L
Check vacuum hoses to MAP sensor. They can get porous after a while. Also check hose to EGR valve.
Jun 27, 2009 | 2001 Ford Escort ZX2
I have a Ford F250 Extended cab that started running rough and losing power this morning got Codes P0301 P0303 P1151 and P0171 What should i Do?
P0301 = Misfire cylinder #1P0303 = Misfire cylinder #2
P0171 = System too lean cylinder #1
Are you sure on the P1151 code? I am thinking this may be a P0151 which is O2 sensor related.
This looks like you have a fuel system related misfire. I would do a fuel injection cleaning service and then clear codes and see if the codes regenerate.
Jun 05, 2009 | 1997 Ford F250 SuperCab
Televison & Video Logo
554 people viewed this question
Top Televison & Video Experts
