Question about Car Audio & Video
Citroen c5 video override
I have plugged a dvd player into the av sockets on my 2001 citroen c5 se. Once the car passes 15mph the video mode is prohibited. How do i prevent this?
SOURCE: Pyle override park brake code
You can run the brown wire to a ground and that should work for you. Would you happen to know the importance of the pink wire?
Posted on Feb 12, 2009
  • 3 Answers
SOURCE: cant find headphone socket for rosen in-car dvd player
As far as i know, all Rosen in-car dvd players come with IR (infra-red) headphones so the sound is transmitted that way rather than using a lead from the headphones to the unit, therfore no sockets are neccessary!
Hope this helps....
Posted on Apr 09, 2009
  • 713 Answers
SOURCE: How do I change spark plugs on a 2001 Mazda Protege es model ?
that rubber ring is the bottom of the spark plug wire boot you will have to get this out before you can get the plug out. no special tools needed except socket long extension and ratchet. just remove the wires or coil over ignition coils however your car is setup, install socket and remove the old plug.
Posted on Aug 28, 2009
Testimonial: "Thank you for the info. Just one question. Can I dig the ring out with a screwdriver? "
morse008
  • 1111 Answers
SOURCE: How do I replace the spark plugs on a 2001 Dodge
is it a shroud that covers all of them i know some models it takes a special plug socket to remove them its very thin in diameter so a special socket is used or if possible like i said if its a shroud remove this to gain access
Posted on Sep 07, 2009
  • 14 Answers
SOURCE: why is my playstation 2 in black and white?
For me it sounds like the TV treats the incomming signal as a SVHS signal. I have had the same problem with a SEGA dreamcast back in the days. In my case it was a quite simple setting in one of the TV menus.
Try different video inputs. (and SCART adapters) This is also is a important step. Some older TV's doesn't have SVHS support at some of the SCART inputs, and in your case that will be a good thing.
But as you said, you maybe already have tried this.
Don't know if this was any help for you but i wish you good luck!
(Because PS2 is still really fun playing)
Posted on Oct 10, 2009
Where do I plug in the yellow cable from my DVD player to get video?
Hello
If you have its user manual, it will be easy to connectet this lead. On the back panel of your TV, there is a column marked 'AV IN'. There are two RCA sockets, marked as (Video) and (AV Out). Connect the yello cable to one marked (Video). It is the video IN socket. Select the TV to AV mode will energize this socket. OK.
Jun 16, 2011 | LG Flattron M3201CBA Television
I DON'T KNOW WHERE TO PLUG MY DVD CABLE IN TO MY KV SONY TRINITRON- THERE DOESN'T SEEM TO BE ANY PLUGHOLES
Hello
You can connect the DVD player ot your Sony TV in two ways. One way is via AV cable, and the other is S-Video cable. If you use AV cabel, connect the cable's one side ends to output sockets of the DVD player, marked as Audio-L, Audio-R and Video. Connect the other side of the cable's respective ends ot TV's respective sockets, marked as Audio_L, Audio-R and Video. This socket can be located at the back of your TV. If you expects a beetter picture quality, you can connect the TV-DVD by S-Video cable. If you connect it via Audio Video cabe, switch the TV to get AV-1, AV-2 etc, by input selector option. If you connect S-Video cable, Select TV' to recive S-video input via its input selector option. You can do these selections by the help of TVs remote control. OK.
Feb 23, 2011 | Sony KV-36XBR200 36" TV
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
DVD player Model AD-1000. No video using composite video (3 Py connections) but do get audio. Video and Audio work using component video
When using Component Video you MUST use AV for the Audio in ALL circumstances. Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 03, 2010 | Aspire Digital AD-1000 DVD Player
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
How do you connect the portable dvd player to your big screen tv?
Look on the side of the dvd player you should see a connector that says AV Out or Video Out, you will need a wire that plugs into that which depeding on the model of dvd player can be either the Red / White/ Yellow Phono Plug Leads or a Lead which has the Red / White/ Yellow Phono Plugs and at the other end what appears to be a headphone jack connector with 3 black bands on it indicating that its a 4 Pole Video output cable, then you plug the Phono Plugs into the Phono Sockets on your tv, using your Tv remote you will need to select which input you got the dvd player plugged into this will either be called
Source Or Input Or AV 1-2-3 ect.
jon
Aug 11, 2009 | Initial Televison & Video
How to connect (yellow, red & white) to component video
Connect either DVD player or DTH with the TV. There is only one input on your TV.
May 27, 2017 | Akai DVD-3850S DVD Player
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
New dvd player
Check your TV setup, especially scart socket/AV menu. It is possible your scart menu is on av priority.
Ali
Jan 24, 2009 | Durabrand DVD-1002 DVD Player
Car Audio & Video Logo
175 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
