Question about Estate TAWX700JQ Top Load Washer
This machine is leaking as the tub fills
In the front end area...not the back. I've checked it twice. How do I explore the sequence of what could be wrong. This machine is only two years old with no kids in the house. Thankyou
My machine does the same thing. I have checked all the hoses and none of them are leaking. My machine is a TAWL650AWO A. I have pulled out my machine and taken all the screws off the back but still can`t remove the panel. Is it possible that I am trying to enter the wrong way? I cannot afford a repairman or a new washer so I wanted to fix it myself. I have looked at a million websites for info and they all usually come down to some charge, never an answer. If I could even download a manual on this machine that would help me to repair it now and in the furure I would be very grateful. I wear uniforms to work everyday so it is impairative that I have a workable washing machine. My machine also does not aggitate as well as I think it should be. Help me there too?! Please and Thank You....
  • Barbara Warriner Feb 02, 2008
    Extremely helpful. Thank you for the details, you absolutely went the extra mile. I am off work on Wednesday, lokks like it`s going to be me and THE MACHINE all day long!!!!
  • 5,911 Answers
If you're trying to open this machine from the back, you're going about it the wrong way. Here is a much easier way:
First of all, unplug your washer, then you will need to remove the console. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up.
Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
Once you have the casing removed from the machine, you can access under the washer and inspect everything. If you take some alligator clips and short the two black wires together at the lid switch connector on the console, you can temporarily plug the washer back in, set the timer to a fill cycle and add some water to the tub. Fill it enough the be able to see where the water is coming from. If you said the leak is coming from the front of the machine, I would strongly suspect the drain pump (located in the front under the wash tub with two hoses connected to it) is probably leaking. They are made of plastic and it is common for them to go bad. It is not a repairable unit and will have to be replaced. The part number for the pump is 3296 and costs about $40. Also take a good look at the drain hoses and make sure they are intact and that the hose clamps are properly secured to the bottom of the wash tub and to the pump. Just in case you need them:
The hose to the pump is part number 907866 and costs about $13.
The hose from the pump to the drain is part number 2732 and costs about $23.
This is a repair that you can easily perform with minimal cost in replacement parts (if needed) and can save you the expense of added labor costs.
Worst case scenario: You may have a cracked tub. Make sure you check the tub real good.
Once you've completed any repairs, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
PS You also mentioned agitating problems, is this simply and agitator issue, or does the washer not spin very well, either? Does the agitator slip while washing? This could be the difference in a $5 repair or a $150.00 repair. Let me know.
Posted on Feb 02, 2008
  • Jeff Rockwell
    Jeff Rockwell Feb 02, 2008
    Let me know if you get stuck and need further assistance.
I have a Maytag Neptune Model #MAH5500BWW, and it leaks water only while it's filling. It's almost like it would rather fill my floor than the tub. When I start a spin only cycle to get the water...
Sounds like a leak either in the bottom, connector or water valve for your water inlet line. Visually finding the leak is your best bet, then you know what parts are to be replaced.
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
I have a twenty year old Maytag washing machine that is leaking water out of the bottom of the machine. I have checked the hoses and it is not coming from there. Any ideas
hello. i can help you. unfortunately, your problem has numerous possible causes.
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jul 02, 2009 | Washing Machines
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
Water Leak
While I do agree with eagle338 that water could be leaking from the fill hoses and the pump area, the rest of the instructions apply more for a top load Maytag washer, instead of the front load Whirlpool washer you reported.
Most likely you will have a hole in the front boot area (grey rubber seal around where the door seats). If you find such a leak, send me a note back and I'll write you up a how to to change it out.
The second most common source of leaks come from holes in the tub. This is the white outer part that holds most of the water in the machine. You will easily be able to see it when you remove the panel as listed above in the clarification instructions.
On rarer occasions, you can have something stuck in the fill tube that goes from the dispenser to the tub. Somehow small items become lodged in there. There will be a water inlet about the 10 o'clock position of your boot (grey rubber seal). Probe gently in there with your finger to see if a sock or similiar item got spun into this area.
Jul 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaks water frim front of the machine
make sure the tub is pushed back , not leaning foward. this fills from back of tub possible splashing on and over the tub rim, anorhersource of leak could be from pump assy removing front cover and lookng at pump will tell (if its been leakin its quite obvious)
Feb 24, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore Elite Washing Machine leaking water
Okay...my experience with this model front loader leads to the following possible problems:
CAUTION: UNPLUG the washer if you plan to service the interior. It is dangerous to have your hands inside the unit with moving parts and energized. Plug the washer back in and stand back if you plan on doing any operation checks.
1. Door bellow ripped or torn (this is the gray rubber boot around the door - open the door and inspect along the entire door boot. Including the areas behind the rubber fold where the rubber meets the wash tub. It is common for them wear out and tear. NOTE: Make sure the fill hose on the left-hand side of the door boot is fully snug in place. Sometimes it will come loose and leak BEHIND the door boot.
2. Drain pump or hoses leaking - You will need to remove the lower panel under the door to see inside the washer. Remove the three torx type screws under the front lip at the bottom of the panel. For easier access, place a small block of wood under each front foot. The washer is heavy so you may need assistance to lift the front slightly. CAUTION: Do not lift on the door, push on the door panel or control panel. If the panel sticks, slightly tap on the sides and it will drop down and come off. The pump is located in the front under the wash tub. Make sure the clean out trap is snug and all your hoses are tight and not torn. Check the drain hose that leads out of the back of the washer from the drain pump to ensure it is not cracked.
3. Air Dome hose has come loose from the tub - This will be a small rubber hose connected to a plastic piece (called an air dome) on the right-hand side of the wash tub as you are looking in from where you removed the bottom panel. It should be located behind the drain pump and mounted physically to the wash tub. The other end of this hose runs to the pressure switch, which turns the water flow off when the washer tub fills to the approriate level. If this hose comes off, the washer will start to leak on the FILL cycle and will not shut off. I don't think this is what you are talking about, but it is still worth a look since you have the panel opened.
4. Tub seal leaking or tub cracked - These would be the most undesirable of all possible problems because it would require the removal of the entire wash tub in order to correct. Inspect the wash tub seam and make sure there's no water coming from around the tub.
I hope this gives you a few possible items to work with. Inpsect the washer interior when you get the panel off and post back if you can determine where the leak is coming from.
HELPFUL HINT: Put the washer into diagnostics mode if you plan to leak test. At the control panel select DRAIN/SPIN, NO SPIN and press any key under OPTIONS 4 times (it must be the SAME key, however). "C00" will be displayed on the operator console, and you will hear the door latch engage. The washer will run through a series of tests by filling using hot and cold water, checks all your dispenser features, tumbles the drum, spins and drains. This diagnostics can be stopped at any time by pressing the PAUSE/CANCEL button twice. The drain pump will come on and drain the washer.
I hope this helps you...
Feb 20, 2008 | Kenmore Elite 45986 Front Load Washer
Water coming from bottom of machine
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
Nov 30, 2007 | Zanussi FJS1225W Front Load Washer
Leaking from my MaytagPAV2300AWW
Had this problem. In my case the leak was comming from the fill indicator tube. It is a small tube running from the side of the tub to the control panel. Air pressure built up in this tube activates a pressure sensor that will shut off the fill valve at different levels depending on the pressure. The tube had become dry and cracked at the joint where it met the tub. I didn't discover the source of the problem unitl the hose actually tore loose and the thing overflowed. Remove this tube and inspect it and I bet you will find a small crack or tear.
Jan 15, 2007 | Maytag PAV2300 Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
122 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
