Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
Aux inputs i hooked up dvd players in my car and tried to hook audio through my cd player and have no audio?
  • 30 Answers
Chek your wiring and your speaker.nad of coars the sound output of your dvd
Posted on Feb 02, 2008
Please tell me how to hook up my Wii and my cd player and my dvd player to Pioneer VSX-D309 receiver
Greetings and good health to you.
Ok, so on the back of the unit there should be labeled connections, AUX, DVD, etc. These will be your inputs.
If your Wii has RCA connectors (the plug like ends that are usually Red, White & Yellow) then you would connect the Red plug to the AUX right speaker input. The White plug to the AUX left speaker input. If you want to run the video through the unit to the TV, then you would plug the Yellow plug to the AUX video input. If not, the yellow plug with go straight to the TV. If you are using HDMI from you Wii, then you would plug that into one of your HDMI inputs.
You will do the same for CD player but using the inputs labeled CD or whatever you have available. You can use any of these inputs for any of your devices it just helps to know what is connected where.
The DVD player may be a different story. Depending on what type of connection you are using from the DVD player will depend on where you plug it in. If they are red, white and yellow...then follow as above. If they are red & white on half the cable and blue, green and red on the other, you will plug the red & white ones that are close together into the red and white audio inputs under the DVD labeled connections. Then the other 3 will go into their matching colored inputs. If the connection from the DVD player is HDMI, that will go into a HDMI slot.
Finally, connect the unit to the TV. Keep in mind that if you are using any HDMI inputs, you will need to connect the unit to the TV via a HDMI cable.
Hope that helps.
Nov 05, 2015 | Pioneer VSX-D307 Receiver
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
What are the two short female rca cables are that stick out of the back of my deck
Aux Audio Input. Lets say you wanted to hook up a DVD player and have it play through your radio, you could connect the audio portion of the DVD player to these inputs and put you radio on AUX and the DVD audio would play through your radio..
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 12, 2011 | Sony CDX-GT710 CD Player
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
Aux input not working for mp3 player
Hi to you all. CAN YOU HELP ME? i have peugeot 206 and i have new kenwood CD MP3 and i also have aux input but I cant get any sound to come out at all?
Nov 04, 2007 | Alpine CDA-9883 CD Player
Mp3 to aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Oct 31, 2007 | Kenwood Sirius KDC-MP522 CD Player
Mp3 player hook up
Hi are you hooking it up via the CD changer control? or just AUX input?
you may need to enable the AUX input, will check out the user manual and se what i can find out
Regards
Mark
Jul 15, 2007 | Kenwood KDC-MP4032 CD Player
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
82 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
