Question about Sharp LC-26D6U 26 in. LCD Television
Sound Trouble After 2 years of owning this TV, the sound goes off after 10 to 20 minutes of being on. We've read the posts of people having this problem with this TV and taking it to be repaired which hasn't helped them--it just goes off again after a short while. Help!
    President:
  • 4,402 Answers
Sharp has a firmware upgrade for this problem
go here
Posted on Feb 01, 2008
    Scholar:
  • 163 Answers
Do you have any info other than the exact model number? I'll see what I can come up with and go from there. Audio Chip failure is not uncommon but I need a starting place. If these turn out to be an across the board issue where Mass numbers are failing I'll investigate this also And provide a solution for all affected. Also if you could forward the info to get to Postings where others have had the same issue I'd like to see these as well. www.ikenfixit.com
  • Anonymous Feb 07, 2008
    Ive noticed these are well known for problems from Video, to Dead, to audio problems.. 100uf caps seem to be one of the problems in manufacturing as they had installed 10uf instead? .(I Can understand this)... Numerous software upgrades, Numerous postings I would love to have 50 of these on my bench and figure out between the different revisions/ Models and problems.. If interested yell back to me.... Theres a problem forming here and [email protected] is all I can say you folks should do. Not my baby as I do not own nor did not buy one..
    www.ikenfixit.com
    consultant
    Genius:
  • 1,067 Answers
Care uusing hdmi cable i would upgrade the cable to hdmi wallmart 28 bucks 5 ft ok version 1.3 only says on box latest speeds and bandwith so u dont get cut off ok
6ya staff
SOURCE:
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
2 year old plasma on 5 minutes no pic, but sound
yes take it to a tv tech would be your best bet.
regards
shaun
Apr 20, 2014 | Samsung PN Televison & Video
Intermittent sound on vizio vp322
hi, you could try spraying some freeze spray around the smd capacitors on the main board, around the audio chip see if the sound comes and goes or heat the board up hope it helps
regards
shaun
Apr 06, 2014 | Vizio VP322 32 in. Plasma TV
Tv loses sound after around 45minutes of being swiched on
there may be problem in your amplifier or the mute signal or the input signal from processor or speakers, First you have to check the audio output from the processor by using another external amplifier... connect it to the correct audio out pin of processor( these are R,L audio written in pcb near the processor lead that carry) if there is sound moreover than 45 minute....... replace the external amplifier and connect it to its own amplifier.... disconnect the own cabin speakers and connect another sp. and check... if there is sound break after45 minute.... replace the amplifier ic(may beTDA7297) if there is still have the problem, check the amplifier circuite suitable for your ic and dissconnect the mute connection from processor and make a connection to the +ve or ground follows as the circuit(means give external mute signal to amplifier dont from processor)......
Nov 09, 2013 | Televison & Video
New device not found usb1 power overload
Dear inVaUSA, I followed your action and contacted 1-800-SAMSUNG but did not fare as well as you did. I was told there is not a firmware update nor a patch to fix the "New Device Not Found USB1 Power Overload" even after I read your post to the support representative I was dealing with. She told me that it is a PlayStation issue even though I have never connected any USB device to any USB Port on my Samsung TV. Could I Please trouble you to send me the firmware update you received from Samsung `in a private message or to my email address if you prefer. Thank you!
Nov 17, 2012 | Samsung LE40B553 40 LCD TV
Buzzing sound after only 2-1/2 years of service
I suspect you have a bad set of capacitors in the control module. This problem usually starts out as a high pitched noise but can lead to the TV not turning on. Please see the link below, posted by StivO. It gives step by step instructions on how to replace the capacitors. This is a very inexpensive fix.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Apr 13, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
It gives an excellent reception but only for a while
There is a problem with the tuner section. I would first suspect poor solder connections. If resoldering the ground connections on the tuner fails to resolve the problem, a replacement can be purchased for $38.40 using part number: 8-598-594-30
Dan
Jan 05, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Sharp LC-26D6U 26 in. LCD Television Logo
60 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
