Question about Dell UltraScan P1110 21" CRT Monitor
Monitor displays signal cable disconnected
I have an Epro monitor connected to the ASRock mother board, it keeps displaying signal cable disconnected. I have changed the mother board but the problem persist. I have placed the same monitor on anothe pc it is working. Any help please
  • Bri4n85 Jan 21, 2009
    mi monitor when i start say "cable signal disconect"
    how i can repair it please. im from venezuela
    email: Bri4n85@hotmail.com
    thanks
  • 58 Answers
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Posted on Feb 13, 2008
LG monitor displays "D-SUB POWER SAVING MODE" when it is starting
The message it is displaying indicates that a VGA cable is connected and is not sending signal, or is sending a Monitor Off signal across the VGA cable. The motherboard battery will have no impact on this. If you are using something other than a VGA cable to send the signal to the monitor, then you should ensure that no VGA cable is plugged into the monitor, or the source on the monitor is not using the VGA connector.
Mar 28, 2014 | Computers & Internet
Not showing normal display to Dell LCD monitor
If you look at the resolution on the monitor and match it with the windows resolution or download a driver for your monitor from Dell
Mar 17, 2014 | Asrock P4I45GV R5 Motherboard
K8NF4G MOTHERBOARD IS NOT WORKING
Your Video Card (Graphics Card) is probably bad. To isolate the problem connect another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays the same NO Signal Message then your video card is bad. If the Borrowed monitor displays and works correctly, then your original monitor is bad. The fact that your monitor displays the No Signal Message on it shows that the monitor is ok.
If you have a laptop, the video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 30, 2012 | Asrock K8NF4G-SATA2 Motherboard
I hav a asrock p4i45dv mother board , its cpu lights appear but nothing is displayed in monitor may i know the cause of this problem and soluton
This is either a bad monitor, a bad video card (if you're using a stand-alone card), or a bad motherboard. Test the monitor by connecting it to another computer. If the monitor works, then it's the video card or MOBO. Use a stand-alone (PCIx/AGP) video card that you are certain works. If this does not work, then the MOBO is not working. I hope this is helpful and best of luck!
Sep 21, 2011 | Asrock P4I45GV R5 Motherboard
THE MONITOR DISPLAYS MESSAGE-- NO SIGNAL INPUT
Check your signal cable from the system unit, if this persists, then its the display that is not working or try opening the computer, replace is ram with another chip, again if this fails, remove its cmos battery, unplug all the power cables from the mother board, leave it for atleast 20minutes, replace everything and power it on.
Jan 07, 2011 | Videoseven L17PS 17" LCD Monitor
I have a motherboard 775i65G so light but gives no signal with the monitor, I've tried with another monitor but the same thing :(
Welcome to FixYa
Dear USer,
Check your Cable Connecting between PC and Monitor.Check your Display Card.Check your Connectivity.Your Problem Should be Solved{if your Error is NO Signal in Monitor}
I hope you got it...I like to Rate ME...Thanks for Connecting FixYa..
Aug 20, 2010 | Asrock 775i65G Motherboard
Can 775i65GV model support NVIDIA 6200 graphix card?
well you should connect monitor signal cable to the vga out of the nvidia graphix card only then you will get the monitor to work, try it.
Good Luck.
Jan 06, 2010 | Asrock 775i65G Motherboard
Check your VGA connector (from monitor to PC), namely the pins in the connector. It's pretty easy to bend a pin, so that it doesn't make the connection. If you happen to do this to the connection present pins, then the monitor won't know that it is connected and will just display the message you are seeing.
Mar 15, 2009 | Dell UltraScan P1110 21" CRT Monitor
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Dell UltraScan P1110 21" CRT Monitor Logo
1,010 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
